ESP32 Selfie/HID Volume Control
josh-gc
Postby josh-gc » Tue Oct 17, 2023 7:57 pm
I am working on code to adjust the volume on a phone as a way of triggering the camera. I started with the esp_hid_device code in the esp-idf v4.4 branch but made a bunch of changes so that both a BT and a BLE connection launch the same demo script (run_example). This looks for a keyboard input and then will raise and lower the volume based on the input.
On an iPhone13 I get a BLE connection and this works well. On a PIxel7 it connects over BT and then I try to run this command:
esp_hidd_dev_input_set(s_bt_hid_param.hid_dev, 1, HID_RPT_ID_CC_IN, buffer, HID_CC_IN_RPT_LEN);
I get these errors:
I (16648) bt_hidd_event_callback: CONNECTED
W (21848) BT_HCI: hci cmd send: sniff: hdl 0x81, intv(10 18)
W (21868) BT_HCI: hcif mode change: hdl 0x81, mode 2, intv 18, status 0x0
I (21868) ESP_HID_GAP: BT GAP MODE_CHG_EVT mode:2
W (21928) BT_HCI: hcif ssr evt: st 0x0, hdl 0x81, tx_lat 360 rx_lat 720
I (22078) esp_hid_device_main: send_volume_up
E (22078) BT_HIDD: index out of range[0-0]
E (22078) BT_HIDD: HID device not connected!
E (22178) BT_HIDD: index out of range[0-0]
E (22178) BT_HIDD: HID device not connected!
Here is a link to my code. Please help explain what is going on in this command and how I can make it work for BT.
https://github.com/josh-gc/esp_selfie
Boblane
Re: ESP32 Selfie/HID Volume Control
Postby Boblane » Fri Oct 20, 2023 10:43 am
Hi @josh-gc,
For the original example, it acts as a media device for BLE transport and acts as a mouse device for BR/EDR transport.
If you just want to use the BLE part, you can just disable the ER/EDR HID functionality by setting menuconfig as following.
1. Component config → Bluetooth → Controller Options → Bluetooth controller mode (BR/EDR/BLE/DUALMODE) (BLE Only)
2. Component config → Bluetooth → Bluedroid Options → Classic Bluetooth(Disabled)
If you want to create a media device for each transport. Please modify your code like following.
Code: Untitled.c Select all
	ESP_GOTO_ON_ERROR( esp_hidd_dev_init(&ble_hid_config, ESP_HID_TRANSPORT_BT, bt_hidd_event_callback, &s_bt_hid_param.hid_dev), error, TAG, "esp_hidd_dev_init failed" );
josh-gc
Postby josh-gc » Tue Oct 24, 2023 4:23 pm
I applied the patches to the demo code as shown in this thread: https://github.com/espressif/esp-idf/issues/12397 and then updated the config as you suggested for BLE only and this works. I will cleanup when time allows and post an update then.
Thanks for your help.
Users browsing this forum: PetalBot, Semrush [Bot] and 1 guest
