cant' open SD card file
salahenp
Postby salahenp » Wed Oct 18, 2023 10:10 am
I want to use my ESP32 board to write on my SD card. using the example that comes with the esp32 board package, all things are OK. But when I wrote my own code, It can not open the file to write in it.
#include "FS.h"
#include "SD.h"
#include "SPI.h"
bool sdInitSuccess = false;
#define SDWRITETIME 60000
char CurrentFileName[128];
#define SD_CS_PIN 5      // Le lecteur de SD card sera branché sur les pins G5 (CS)
bool sdfileOpend = false;
void WriteSDcard()
  File myFile;
  static unsigned long T = 0;
  if(!sdInitSuccess){
    Serial.println("Initializing SD card...");
    if (!SD.begin()) {
      Serial.println("Initialization failed!\n");
      return;
     }  //failure
     else {
      Serial.println("Intitialization success.\n");
      sdInitSuccess = true;
  if (millis() < T) return;
  T = millis() + SDWRITETIME;
  char FileName[128];
  char fileHeader[] = "Date;Time;T1;H1;T2;H2";
  sprintf(FileName, "test30.txt");
  if (strcmp(CurrentFileName, FileName)) {
    strcpy(CurrentFileName, FileName);
   if (sdfileOpend == 0) {
    bool myFileExist = SD.exists("test30.txt");
    myFile = SD.open("test30.txt", FILE_WRITE);
Serial.println(myFileExist);
Serial.println(myFile);
    // if (myFile) {
      if(!myFile) {
      Serial.print("can not open File for Writing:  ");
      Serial.println(CurrentFileName);
      return;
    Serial.print(F("File opened for Writing successfully:"));
      sdfileOpend = 1;
      if (!myFileExist) {
        myFile.println(fileHeader);
  if(myFile.print(16))
  Serial.println("Written");
  else
  Serial.println("Failed to write");
  myFile.print("/");
  myFile.print(10);
  myFile.print("/");
  myFile.print(2023);
  myFile.print(";");
  myFile.print(10);
  myFile.print(":");
  myFile.print(48);
  myFile.print(":");
  myFile.print(7);
  myFile.print(";");
  myFile.print(40);
  myFile.print(";");
  myFile.print(35);
  myFile.print(";");
  myFile.print(3);
  myFile.print(";");
  myFile.print(2.5);
  myFile.print(";");
  myFile.print(40);
  myFile.print(";");
  myFile.print(25);
  myFile.print(";");
  myFile.print(30);
  myFile.print(";");
  myFile.print(35);
  myFile.print(";");
  myFile.print(45);
  myFile.print(";");
  myFile.print(20);
  myFile.print(";");
  myFile.close();
  sdfileOpend = 0;
  Serial.println("Data written to SD card");
  WriteSDcard();
The output give me:
0
0
can not open File for Writing:  test30.txt
0
0
I use VSPI, beacause HSPI is reserved for other modules.
what could be the problem?
lbernstone
Re: cant' open SD card file
Postby lbernstone » Thu Oct 19, 2023 6:13 am
Filenames need to be absolute. Start with a slash.
salahenp
Postby salahenp » Thu Oct 19, 2023 8:30 am
Thank you very much, That solved it. I didn't know that before. With Arduino boards I never used the slash.
Users browsing this forum: Bytespider, Qwantbot and 2 guests
