Can't use an E-INK display and Wifi at the same time ?
funfake
Postby funfake » Sat Oct 21, 2023 3:19 am
Hi !
I'm tinkering with an ESP32-Wroom-32 on a school IoT project.
The goal is to create a device with an e-ink screen that displays a qr code which url can be changed through a webpage hosted by the esp32 wifi hotspot.
Both functions work separetely : I can manage to display the qr code and connect to wifi on two different arduino sketches.
But when I try to join them and make the display refresh once an user submits the new url to display, nothing changes on the e-ink monitor. I get a confirmation from the Async web server though.
The setup loops initiliazes the display with a predefined url : when placing the block of code aftet hotspot / server init, nothing happens either but when initilizing the display first and then starting the rest, then it works.
I really don't understand the issue.
The display is a 1.54inch model made by HELTEC https://heltec.org/project/154-e-ink/
Librairies used :
- https://github.com/me-no-dev/ESPAsyncWebServer
- https://github.com/me-no-dev/AsyncTCP
- https://github.com/todd-herbert/heltec-eink-modules
- https://github.com/ricmoo/QRCode/tree/master
Here is my code :
// Pick your panel  -  https://github.com/todd-herbert/heltec-eink-modules#supported-displays
#define  USING_DEPG0150BNS810        // 1.54" V2 - BW - Red Tab
// #define  USING_DEPG0154BNS800        // 1.54" V2 - BW - Red Tab
// #define  USING_GDEP015OC1            // 1.54" V2 - BW - Blue Tab
// #define  USING_DEPG0213RWS800        // 2.13" V2 - BWR - Red Tab
// #define  USING_QYEG0213RWS800        // 2.13" V2 - BWR - Red Tab
// #define  USING_DEPG0290BNS75A        // 2.9" V2 - BW - Red Tab
// #define  USING_DEPG0290BNS800        // 2.9" V2 - BW - Red Tab
// #define  USING_GDE029A1              // 2.9" V2 - BW - Blue Tab
#define DISPLAY_RES 200
// Find your wiring  -  https://github.com/todd-herbert/heltec-eink-modules#wiring
#define DC_PIN 2
#define CS_PIN 4
#define BUSY_PIN 5
// (Example automatically picks the correct class, and color palette)
#if     defined USING_DEPG0150BNS810
    #define     PANEL_CLASS     DEPG0150BNS810
#endif
// IMPORTS
// e-ink lib
#include "heltec-eink-modules.h"
// custom qrcode lib
#include "ricmoo_qrcode.h"
// Find your colors
static unsigned int BGCOLOR = WHITE;
static unsigned int ACCENT1 = BLACK;;
static unsigned int ACCENT2 = WHITE;
// DISPLAY PROPERTY
PANEL_CLASS display(DC_PIN, CS_PIN, BUSY_PIN);
// Shortcut to save typing: Dimension information about fullscreen panel
FullBounds f = display.bounds.full;
// DRAW QR CODE
// class QRCodeHandler {
//   public:
//     // GENERATE THE QR CODE FROM URL
//     QRCode qrcode;
//     int module_size;
//     int offset;
//     void genQRcode(const char *url) {
//       uint8_t qrcodeData[qrcode_getBufferSize(3)];
//       qrcode_initText(&qrcode, qrcodeData, 3, 0, url);
//       // dynamic qr code module size and centering based on the size provided by qrcode.size
//       module_size = DISPLAY_RES / qrcode.size;
//       offset = (DISPLAY_RES - (module_size * qrcode.size)) / 2;
//     void displayQRcode() {
//       // DISPLAY THE QR CODE
//       // ONE DRAWING FRAME
//       DRAW (display) {
//         for (uint8_t y = 0; y < qrcode.size; y++) {
//           for (uint8_t x = 0; x < qrcode.size; x++) {
//             // a qr code is comprised of an array of modules (x and y), each one is given a filling, either empty or filled
//             // we deal with that using a ternary expression
//             display.fillRect(offset + x * module_size, offset + y * module_size, module_size, module_size, qrcode_getModule(&qrcode, x, y) ? ACCENT1: ACCENT2);
// IMPORTS FOR WIFI AND SERVER
// wifi ap + web server libs
#include <DNSServer.h>
#include <WiFi.h>
#include <AsyncTCP.h>
#include "ESPAsyncWebServer.h"
// WIFI PORTAL CONFIG
DNSServer dnsServer;
AsyncWebServer server(80); // server defined on port 80, typical http port
// VARIABLES TO BE UPDATED BY THE USER THROUGH THE SERVER
String user_name;
String proficiency;
bool name_received = false;
bool proficiency_received = false;
// HTML TEMPLATE FOR index.html
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html><head>
  <title>Captive Portal Demo</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  </head><body>
  <h3>Captive Portal Demo</h3>
  <br><br>
  <form action="/get">
    <br>
    Name: <input type="text" name="name">
    <br>
    ESP32 Proficiency:
    <select name = "proficiency">
      <option value=Beginner>Beginner</option>
      <option value=Advanced>Advanced</option>
      <option value=Pro>Pro</option>
    </select>
    <input type="submit" value="Submit">
  </form>
</body></html>)rawliteral";
// REQUEST HANDLERS
class CaptiveRequestHandler : public AsyncWebHandler {
  public:
    CaptiveRequestHandler() {}
    virtual ~CaptiveRequestHandler() {}
    bool canHandle(AsyncWebServerRequest *request){
      //request->addInterestingHeader("ANY");
      return true;
    void handleRequest(AsyncWebServerRequest *request) {
      request->send_P(200, "text/html", index_html); // send_P used instead of send because we are fetching a large web page from the Program memory (PROGMEM)
// ASYNC WEB SERVER CONFIG
// to respond to various requests, process the data received and send a response
void setupServer(){
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
      // Serial.println("Client Connected");
  server.on("/get", HTTP_GET, [] (AsyncWebServerRequest *request) {
      String inputMessage;
      String inputParam;
      if (request->hasParam("name")) {
        inputMessage = request->getParam("name")->value();
        inputParam = "name";
        user_name = inputMessage;
        // Serial.println(inputMessage);
        name_received = true;
      if (request->hasParam("proficiency")) {
        inputMessage = request->getParam("proficiency")->value();
        inputParam = "proficiency";
        proficiency = inputMessage;
        proficiency_received = true;
      // send 200 code : OK, sucess + html code
      request->send(200, "text/html", "The values entered by you have been successfully sent to the device <br><a href=\"/\">Return to Home Page</a>");
// INTERRUPTS
// void IRAM_ATTR isr() {
// 	button1.numberKeyPresses++;
// 	button1.pressed = true;
//   updateQRCode();
  // CONFIGURE THE DISPLAY
  display.setRotation(4);     // Alternatively, PINS_RIGHT
  // SET THE BACKGROUND (WHITE IN THIS CASE)
  display.setDefaultColor(BGCOLOR);
  // QRCode
  QRCode qrcode;
  qrcode_initText(&qrcode, qrcodeData, 3, 0, "https://google.fr");
  int module_size = DISPLAY_RES / qrcode.size;
  int offset = (DISPLAY_RES - (module_size * qrcode.size)) / 2;
  DRAW (display) {
          // Serial.print(qrcode_getModule(&qrcode, x, y) ? "\u2588\u2588": "  ");
  // WIFI + DNS WEB SERVER SETUP
  // Serial.begin(115200);
  // Serial.println();
  // Serial.println("Setting up AP Mode");
  // set ap mode
  WiFi.mode(WIFI_AP);
  // ap name
  WiFi.softAP("qr-code");
  // Serial.print("AP IP address: ");Serial.println(WiFi.softAPIP());
  // Serial.println("Setting up Async WebServer");
  // configure the server
  setupServer();
  // Serial.println("Starting DNS Server");
  // start the dns server to redirect all requests to the server
  dnsServer.start(53, "*", WiFi.softAPIP());
  // add an event handler when a new request arises
  server.addHandler(new CaptiveRequestHandler()).setFilter(ON_AP_FILTER);//only when requested from AP
  // start the server when everything is ready
  server.begin();
  // Serial.println("All Done!");
  // QRCodeHandler qrhandler;
  // // Input the default URL
  // qrhandler.genQRcode("https://google.fr");
  // // display it
  // qrhandler.displayQRcode();
void loop(){
  // HANDLE NEW REQUESTS
  if(name_received && proficiency_received){
    // Serial.print("Hello ");Serial.println(user_name);
    // Serial.print("You have stated your proficiency to be ");Serial.println(proficiency);
    // Serial.println("We'll wait for the next client now");
  dnsServer.processNextRequest();
Thank you very much for your help.
Kind regards,
William
Users browsing this forum: Bytespider, meta-externalagent and 3 guests
