Create a partition in code
chruge
Postby chruge » Fri Oct 27, 2023 11:36 am
Dear all
Is there a IDF call to create new partition (out of the program code)?
After OTA I want to use a data partition, that the previous FW-Version did not have...
Kind regards
Chris
mbratch
Re: Create a partition in code
Postby mbratch » Mon Oct 30, 2023 1:17 pm
I found this with a little searching. Is this helpful?
ESP32: Partition Table Update Through OTA
chruge
Postby chruge » Mon Jan 15, 2024 12:57 pm
Thank you for the reply.
It's interessting but not what I was looking for. Of course I can modify the Flash using the SPI interface. I was hoping that there's an API in the IDF to create and delete partitions.
Kind regards
Chris
adokitkat
Postby adokitkat » Mon Jan 15, 2024 2:35 pm
Hello. There in no official higher-level API for this at the moment.
Postby Sprite » Tue Jan 16, 2024 1:26 am
For what it's worth: the reason is that the partition table is not safe to rewrite on the fly: if the partition table gets corrupted because someone switched off the ESP during the write, it can render the chip unbootable.
chruge
Postby chruge » Fri Jan 19, 2024 7:02 am
Dear all
Thank you for the clarification.
I'm not sure where to make that suggestion... or maybe it's stupid anyway.
With OTA there is a similar integrity issue and it has been solved with the ota data partition and two ota partitions. Could that mechanism be used here too?
Regards
Chris
Postby Sprite » Sat Jan 20, 2024 1:23 am
It could, but it's not currently implemented.
Users browsing this forum: Semrush [Bot], YaCy [Bot] and 3 guests
