new 5 seconds delay during boot
felixcollins
Postby felixcollins » Fri Nov 03, 2023 1:21 am
I have a strange delay during boot - long enough to be quite noticeable (see log timing):
Has anyone else seen this? Is there a fix?
W (70) HOOK: Latching Power On
W (35) HOOK: This hook is called AFTER bootloader initialization
I (5710) cpu_start: Multicore app
I (5711) cpu_start: Pro cpu up.
I (5711) cpu_start: Starting app cpu, entry point is 0x400815c0
WROOM-32E module MGN16
ESP32 Chip rev: v3.1
IDF :v4.4.6
ADF :2.0.3
Running Windows and VSCODE
This has just started happening. I have just changed from ADF master bcad553 and idf release/4.4 cc71308e2f.
felixcollins
Re: new 5 seconds delay during boot
Postby felixcollins » Fri Nov 03, 2023 1:38 am
I have bootloader hooks installed.
void bootloader_before_init(void) {
    /* Keep in my mind that a lot of functions cannot be called from here
     * as system initialization has not been performed yet, including
     * BSS, SPI flash, or memory protection. */
	ESP_LOGW("HOOK", "Latching Power On");
	// Latch power on.
	gpio_ll_output_enable(&GPIO, POWER_LATCH_GPIO);
	gpio_ll_set_level(&GPIO, POWER_LATCH_GPIO, 1);
	//Turn On green LED
	gpio_ll_output_enable(&GPIO, GREEN_LED_GPIO);
	gpio_ll_set_level(&GPIO, GREEN_LED_GPIO, 1);
void bootloader_after_init(void) {
    ESP_LOGW("HOOK", "This hook is called AFTER bootloader initialization");
felixcollins
SOLVED: new 5 seconds delay during boot
Postby felixcollins » Tue Nov 07, 2023 12:21 am
It was my own dumb fault. I was fiddling with some SDKCONFIG settings and changed the factory reset gpio to be active high instead of active low (which is necessary for my board). This meant that a factory reset was triggering every boot.
Users browsing this forum: Baidu [Spider], Qwantbot and 23 guests
