error: reference to 'map' is ambiguous
headquaker
Postby headquaker » Sun Nov 05, 2023 9:47 pm
hello, I have a message :
In file included from Project\Boite\BoiteAHistoires_v8\Export\BaH6\ui\ui.ino:53:
Project\Boite\BoiteAHistoires_v8\Export\BaH6\ui\touch.h: In function 'bool touch_touched()':
Project\Boite\BoiteAHistoires_v8\Export\BaH6\ui\touch.h:163:20: error: reference to 'map' is ambiguous
In file included from arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0\xtensa-esp32s3-elf\include\c++\8.4.0\map:61,
from Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\BluetoothSerial\src/BluetoothSerial.h:27,
from V:\Jérôme\Productions\ESP32\Projects\BoiteAMathilde\Project\Boite\BoiteAHistoires_v8\Export\BaH6\ui\ui.ino:12:
arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0\xtensa-esp32s3-elf\include\c++\8.4.0\bits\stl_map.h:100:11: note: candidates are: 'template<class _Key, class _Tp, class _Compare, class _Alloc> class std::map'
     class map
In file included from Projects\BoiteAMathilde\Project\Boite\BoiteAHistoires_v8\Export\BaH6\ui\ui.ino:1:
Arduino15\packages\esp32\hardware\esp32\2.0.14\cores\esp32/Arduino.h:153:6: note:                 'long int map(long int, long int, long int, long int, long int)'
 long map(long, long, long, long, long);
I don't understand who to avoid that error.
Could you help me please ?
 * Touch libraries:
 * FT6X36: https://github.com/strange-v/FT6X36.git
 * GT911: https://github.com/TAMCTec/gt911-arduino.git
 * XPT2046: https://github.com/PaulStoffregen/XPT2046_Touchscreen.git
/* uncomment for FT6X36 */
// #define TOUCH_FT6X36
// #define TOUCH_FT6X36_SCL 19
// #define TOUCH_FT6X36_SDA 18
// #define TOUCH_FT6X36_INT 39
// #define TOUCH_SWAP_XY
// #define TOUCH_MAP_X1 480
// #define TOUCH_MAP_X2 0
// #define TOUCH_MAP_Y1 0
// #define TOUCH_MAP_Y2 320
/* uncomment for GT911 */
 #define TOUCH_GT911
 #define TOUCH_GT911_SCL 20
 #define TOUCH_GT911_SDA 19
 #define TOUCH_GT911_INT -1
 #define TOUCH_GT911_RST 38
 #define TOUCH_GT911_ROTATION ROTATION_NORMAL
 #define TOUCH_MAP_X1 800
 #define TOUCH_MAP_Y1 480
 #define TOUCH_MAP_Y2 0
/* uncomment for XPT2046 */
// #define TOUCH_XPT2046
// #define TOUCH_XPT2046_SCK 12
// #define TOUCH_XPT2046_MISO 13
// #define TOUCH_XPT2046_MOSI 11
// #define TOUCH_XPT2046_CS 38
// #define TOUCH_XPT2046_INT 18
// #define TOUCH_XPT2046_ROTATION 0
// #define TOUCH_MAP_X1 4000
// #define TOUCH_MAP_X2 100
// #define TOUCH_MAP_Y1 100
// #define TOUCH_MAP_Y2 4000
int touch_last_x = 0, touch_last_y = 0;
#if defined(TOUCH_FT6X36)
#include <Wire.h>
#include <FT6X36.h>
FT6X36 ts(&Wire, TOUCH_FT6X36_INT);
bool touch_touched_flag = true, touch_released_flag = true;
#elif defined(TOUCH_GT911)
#include <Wire.h>
#include <TAMC_GT911.h>
TAMC_GT911 ts = TAMC_GT911(TOUCH_GT911_SDA, TOUCH_GT911_SCL, TOUCH_GT911_INT, TOUCH_GT911_RST, max(TOUCH_MAP_X1, TOUCH_MAP_X2), max(TOUCH_MAP_Y1, TOUCH_MAP_Y2));
#elif defined(TOUCH_XPT2046)
#include <XPT2046_Touchscreen.h>
#include <SPI.h>
XPT2046_Touchscreen ts(TOUCH_XPT2046_CS, TOUCH_XPT2046_INT);
#endif
void touch(TPoint p, TEvent e)
  if (e != TEvent::Tap && e != TEvent::DragStart && e != TEvent::DragMove && e != TEvent::DragEnd)
    return;
  // translation logic depends on screen rotation
#if defined(TOUCH_SWAP_XY)
  touch_last_x = map(p.y, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width());
  touch_last_y = map(p.x, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height());
#else
  touch_last_x = map(p.x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width());
  touch_last_y = map(p.y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height());
#endif
  switch (e)
  case TEvent::Tap:
    Serial.println("Tap");
    touch_touched_flag = true;
  case TEvent::DragStart:
    Serial.println("DragStart");
  case TEvent::DragMove:
    Serial.println("DragMove");
  case TEvent::DragEnd:
    Serial.println("DragEnd");
  default:
    Serial.println("UNKNOWN");
#endif
void touch_init()
  Wire.begin(TOUCH_FT6X36_SDA, TOUCH_FT6X36_SCL);
  ts.begin();
  ts.registerTouchHandler(touch);
  Wire.begin(TOUCH_GT911_SDA, TOUCH_GT911_SCL);
  ts.begin();
  ts.setRotation(TOUCH_GT911_ROTATION);
  SPI.begin(TOUCH_XPT2046_SCK, TOUCH_XPT2046_MISO, TOUCH_XPT2046_MOSI, TOUCH_XPT2046_CS);
  ts.begin();
  ts.setRotation(TOUCH_XPT2046_ROTATION);
#endif
bool touch_has_signal()
  ts.loop();
  return touch_touched_flag || touch_released_flag;
  return true;
  return ts.tirqTouched();
#else
  return false;
#endif
  if (touch_touched_flag)
    touch_touched_flag = false;
    return true;
  else
    return false;
  ts.read();
  if (ts.isTouched)
    touch_last_x = map(ts.points[0].y, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
    touch_last_y = map(ts.points[0].x, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
#else
    touch_last_x = map(ts.points[0].x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
    touch_last_y = map(ts.points[0].y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
#endif
    return true;
  else
    return false;
  if (ts.touched())
    TS_Point p = ts.getPoint();
    touch_last_x = map(p.y, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
    touch_last_y = map(p.x, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
#else
    touch_last_x = map(p.x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
    touch_last_y = map(p.y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
#endif
    return true;
  else
    return false;
#else
  return false;
#endif
bool touch_released()
  if (touch_released_flag)
    touch_released_flag = false;
    return true;
  else
    return false;
  return true;
  return true;
#else
  return false;
#endif
lbernstone
Re: error: reference to 'map' is ambiguous
Postby lbernstone » Mon Nov 06, 2023 2:51 am
Make a minimal example that demonstrates it. This is obviously not your actual code, since you aren't including BluetoothSerial.h, which is the source of the conflict.
headquaker
Postby headquaker » Mon Nov 06, 2023 3:42 pm
the main code is crashing just with the include touch.h and include BluetoothSerial.h
I don't need to add any code further...
include <BluetoothSerial.h>
include touch.h
setup()
loop()
lbernstone
Postby lbernstone » Mon Nov 06, 2023 4:48 pm
You can define your own map function with a different name
https://github.com/espressif/arduino-es ... pp#L76-L85
headquaker
Postby headquaker » Mon Nov 06, 2023 4:49 pm
yes I tried but it seems to crash the ESP32.
the screen cannot initiate :(
headquaker
Postby headquaker » Mon Nov 06, 2023 9:43 pm
I called
#include <esp_wifi.h>
#include "esp_bt.h"
  // Disable Wi-Fi
  esp_err_t results = esp_wifi_stop();
  // Disable Bluetooth
  esp_bt_controller_disable();
  esp_bt_controller_deinit();
no more conflits...
Users browsing this forum: Amazon [Bot] and 5 guests
