error: reference to 'map' is ambiguous
Posted: Sun Nov 05, 2023 9:47 pm
hello, I have a message :
I don't understand who to avoid that error.
Could you help me please ?
In file included from Project\Boite\BoiteAHistoires_v8\Export\BaH6\ui\ui.ino:53:
Project\Boite\BoiteAHistoires_v8\Export\BaH6\ui\touch.h: In function 'bool touch_touched()':
Project\Boite\BoiteAHistoires_v8\Export\BaH6\ui\touch.h:163:20: error: reference to 'map' is ambiguous
In file included from arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0\xtensa-esp32s3-elf\include\c++\8.4.0\map:61,
from Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\BluetoothSerial\src/BluetoothSerial.h:27,
from V:\Jérôme\Productions\ESP32\Projects\BoiteAMathilde\Project\Boite\BoiteAHistoires_v8\Export\BaH6\ui\ui.ino:12:
arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0\xtensa-esp32s3-elf\include\c++\8.4.0\bits\stl_map.h:100:11: note: candidates are: 'template<class _Key, class _Tp, class _Compare, class _Alloc> class std::map'
class map
In file included from Projects\BoiteAMathilde\Project\Boite\BoiteAHistoires_v8\Export\BaH6\ui\ui.ino:1:
Arduino15\packages\esp32\hardware\esp32\2.0.14\cores\esp32/Arduino.h:153:6: note: 'long int map(long int, long int, long int, long int, long int)'
long map(long, long, long, long, long);
^~~Could you help me please ?
* Touch libraries:
* FT6X36: https://github.com/strange-v/FT6X36.git
* GT911: https://github.com/TAMCTec/gt911-arduino.git
* XPT2046: https://github.com/PaulStoffregen/XPT2046_Touchscreen.git
/* uncomment for FT6X36 */
// #define TOUCH_FT6X36
// #define TOUCH_FT6X36_SCL 19
// #define TOUCH_FT6X36_SDA 18
// #define TOUCH_FT6X36_INT 39
// #define TOUCH_SWAP_XY
// #define TOUCH_MAP_X1 480
// #define TOUCH_MAP_X2 0
// #define TOUCH_MAP_Y1 0
// #define TOUCH_MAP_Y2 320
/* uncomment for GT911 */
#define TOUCH_GT911
#define TOUCH_GT911_SCL 20
#define TOUCH_GT911_SDA 19
#define TOUCH_GT911_INT -1
#define TOUCH_GT911_RST 38
#define TOUCH_GT911_ROTATION ROTATION_NORMAL
#define TOUCH_MAP_X1 800
#define TOUCH_MAP_Y1 480
#define TOUCH_MAP_Y2 0
/* uncomment for XPT2046 */
// #define TOUCH_XPT2046
// #define TOUCH_XPT2046_SCK 12
// #define TOUCH_XPT2046_MISO 13
// #define TOUCH_XPT2046_MOSI 11
// #define TOUCH_XPT2046_CS 38
// #define TOUCH_XPT2046_INT 18
// #define TOUCH_XPT2046_ROTATION 0
// #define TOUCH_MAP_X1 4000
// #define TOUCH_MAP_X2 100
// #define TOUCH_MAP_Y1 100
// #define TOUCH_MAP_Y2 4000
int touch_last_x = 0, touch_last_y = 0;
#if defined(TOUCH_FT6X36)
#include <Wire.h>
#include <FT6X36.h>
FT6X36 ts(&Wire, TOUCH_FT6X36_INT);
bool touch_touched_flag = true, touch_released_flag = true;
#elif defined(TOUCH_GT911)
#include <Wire.h>
#include <TAMC_GT911.h>
TAMC_GT911 ts = TAMC_GT911(TOUCH_GT911_SDA, TOUCH_GT911_SCL, TOUCH_GT911_INT, TOUCH_GT911_RST, max(TOUCH_MAP_X1, TOUCH_MAP_X2), max(TOUCH_MAP_Y1, TOUCH_MAP_Y2));
#elif defined(TOUCH_XPT2046)
#include <XPT2046_Touchscreen.h>
#include <SPI.h>
XPT2046_Touchscreen ts(TOUCH_XPT2046_CS, TOUCH_XPT2046_INT);
#endif
void touch(TPoint p, TEvent e)
if (e != TEvent::Tap && e != TEvent::DragStart && e != TEvent::DragMove && e != TEvent::DragEnd)
return;
// translation logic depends on screen rotation
#if defined(TOUCH_SWAP_XY)
touch_last_x = map(p.y, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width());
touch_last_y = map(p.x, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height());
#else
touch_last_x = map(p.x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width());
touch_last_y = map(p.y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height());
#endif
switch (e)
case TEvent::Tap:
Serial.println("Tap");
touch_touched_flag = true;
break;
case TEvent::DragStart:
Serial.println("DragStart");
break;
case TEvent::DragMove:
Serial.println("DragMove");
break;
case TEvent::DragEnd:
Serial.println("DragEnd");
break;
default:
Serial.println("UNKNOWN");
break;
#endif
void touch_init()
Wire.begin(TOUCH_FT6X36_SDA, TOUCH_FT6X36_SCL);
ts.begin();
ts.registerTouchHandler(touch);
Wire.begin(TOUCH_GT911_SDA, TOUCH_GT911_SCL);
ts.begin();
ts.setRotation(TOUCH_GT911_ROTATION);
SPI.begin(TOUCH_XPT2046_SCK, TOUCH_XPT2046_MISO, TOUCH_XPT2046_MOSI, TOUCH_XPT2046_CS);
ts.begin();
ts.setRotation(TOUCH_XPT2046_ROTATION);
#endif
bool touch_has_signal()
ts.loop();
return touch_touched_flag || touch_released_flag;
return true;
return ts.tirqTouched();
#else
return false;
#endif
if (touch_touched_flag)
touch_touched_flag = false;
return true;
else
return false;
ts.read();
if (ts.isTouched)
touch_last_x = map(ts.points[0].y, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
touch_last_y = map(ts.points[0].x, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
#else
touch_last_x = map(ts.points[0].x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
touch_last_y = map(ts.points[0].y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
#endif
return true;
else
return false;
if (ts.touched())
TS_Point p = ts.getPoint();
touch_last_x = map(p.y, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
touch_last_y = map(p.x, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
#else
touch_last_x = map(p.x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
touch_last_y = map(p.y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
#endif
return true;
else
return false;
#else
return false;
#endif
bool touch_released()
if (touch_released_flag)
touch_released_flag = false;
return true;
else
return false;
return true;
return true;
#else
return false;
#endif
