ESP32S3 SPI主机模式下发送第一帧数据老是出错什么问题?
393877719
Postby 393877719 » Tue Nov 07, 2023 11:01 am
大家好
我使用ESP32S3的SPI master模式控制一个SPI器件,配置为mode=3,但是初始化完成后,时钟线一直保持在低电平。
我查了是在spi_bus_initialize函数调用spicommon_bus_initialize_io里面再调用esp_rom_gpio_connect_out_signal(bus_config->sclk_io_num, spi_periph_signal[host].spiclk_out, false, false);之后时钟线即被拉低。无论SPI模式mode=0~3任何情况。
尝试了各种配置,没找打解决办法,不知道大家有遇到过吗?
信号我用saleae logic2采集了波形,测试了多次,每次都是上电后第一帧数据出错。
数据和代码见附件。
MCU:ESP32S3
IDE:ESP-IDF V5.1
Code: Untitled.c Select all
void CSLOW(void)
gpio_set_level(48, 0);
void CSHIGH(void)
gpio_set_level(48, 1);
void app_main(void)
spi_device_handle_t spi;
char buf[] = {1, 2, 3, 4, 5, 6, 7, 8};
gpio_config_t ioconfig = {
.mode = GPIO_MODE_OUTPUT,
.intr_type = GPIO_INTR_DISABLE,
.pull_up_en = GPIO_PULLUP_ENABLE,
.pin_bit_mask = (1ULL << 48),
gpio_config(&ioconfig);
spi_bus_config_t busconfig = {
.mosi_io_num = 19,
.miso_io_num = 20,
.sclk_io_num = 21,
.quadhd_io_num = -1,
.quadwp_io_num = -1,
spi_bus_initialize(SPI2_HOST, &busconfig, SPI_DMA_CH_AUTO);
spi_device_interface_config_t devconfig = {
.spics_io_num = -1,
.clock_speed_hz = 1000000,
.mode = 3,
.queue_size = 3,
// .post_cb = CSHIGH,
// .pre_cb = CSLOW,
spi_bus_add_device(SPI2_HOST, &devconfig, &spi);
spi_transaction_t t = {
.length = 8 * 8,
.tx_buffer = buf,
.rx_buffer = NULL,
while (1)
vTaskDelay(pdMS_TO_TICKS(3000));
CSLOW();
spi_device_transmit(spi, &t);
CSHIGH();
vTaskDelete(NULL);
ESP32S3_SPI.zip
(21 KiB) Downloaded 661 times
393877719
Re: ESP32S3 SPI主机模式下发送第一帧数据老是出错什么问题?
Postby 393877719 » Wed Nov 08, 2023 1:02 am
ESP32S3_SPI Master mode issue.jpg (376.29 KiB) Viewed 1946 times
波形如图
Users browsing this forum: PetalBot, Semrush [Bot] and 1 guest
