ESP32 as Wlan Repeater
Is a full functional script out there, whichs shows how ot use the ESP32 as a WLan Repeater? AP+STA should be possible, right?
Re: ESP32 as Wlan Repeater
That would need forwarding in the lwip layer; I don't think anyone has made that work yet, let alone in a 'script'.
anandvilayil
hi,
can we able to make esp32 as a wifi repeater. some where i seen that esp not supporting nat in lwip. is there any way to tranfer data between ap netif and sta netif in apsta mode ?. thank u
anandvilayil
humptydumpty
I have been able to receive UDP packets in promiscuous AP mode and then send them out again with esp_wifi_80211_tx() function. It is fairly easy if you limit it to a particular protocol. Probably it would be a lot of work if you wanted it to do more than that. And sending seems to be limited to about 800 packets per second.
Users browsing this forum: Google [Bot], PerplexityBot, Semrush [Bot] and 2 guests
