ESP32-S3-Korvo-2 V3.0开发板编译i2s_es7210_tdm这个demo无法运行
Moderator: Bob
qinhao399
Postby qinhao399 » Fri Nov 17, 2023 12:52 pm
从官网上购买了ESP32-S3-Korvo-2 V3.0这个开发板,编译i2s_es7210_tdm,开发板运行时打印错误信息,发现ES7210这个芯片写寄存器报错了,这是什么原因导致的?
I (349) example: Configure I2S receive channel to TDM mode
I (359) example: Init I2C used to configure ES7210
I (359) example: Configure ES7210 codec parameters
E (369) ES7210: es7210_write_reg(144): error while writing register
E (369) ES7210: es7210_config_codec(289): i2c communication error while writing ES7210_RESET_REG00
ESP_ERROR_CHECK failed: esp_err_t 0xffffffff (ESP_FAIL) at 0x42009454
0x42009454: es7210_codec_init at F:/ESP32_VSCode/project/i2s_es7210_tdm/main/i2s_es7210_record_example.c:192 (discriminator 1)
file: "./main/i2s_es7210_record_example.c" line 192
func: es7210_codec_init
