Getting Wake Cause in Wake Stub not working on S3
PeteDD
Postby PeteDD » Tue Nov 21, 2023 5:37 pm
I have switched a project from ESP32 to ESP32-S3 and can't figure out why I can't get a correct wake cause in my wake stub. It only returns 0 for the wake cause value when waking from EXT0 input. Can anyone see what I am missing here? Again, this code works fine on the ESP32 such as the TTGO T-Display. I am thinking it must be in the line:
uint32_t _wakeup_cause = REG_GET_FIELD(RTC_CNTL_WAKEUP_STATE_REG, RTC_CNTL_WAKEUP_CAUSE);
but why is that working on other processors but not on the S3?
(I have googled extensively on this and tried many alternative approaches, but to no avail).
Here is a reduced code example:
THANKS!
#include <Arduino.h>
#include "esp_sleep.h"
#include "esp_cpu.h"
#include "esp_rom_sys.h"
#include "rom\rtc.h"             // needed for rtc_get_reset_reason, DEEPSLEEP_RESET, RTC_ENTRY_ADDR_REG
#include "driver\rtc_io.h"       // needed for rtc_gpio_pullup_en
#include "soc/rtc.h"             // needed for RTC_EXT0_TRIG_EN, RTC_EXT1_TRIG_EN, RTC_TIMER_TRIG_EN, RTC_TOUCH_TRIG_EN, RTC_ULP_TRIG_EN
void setup()
    	rtc_gpio_init(GPIO_NUM)_17;
    	rtc_gpio_set_direction(GPIO_NUM_17, RTC_GPIO_MODE_INPUT_ONLY);
   	rtc_gpio_pulldown_dis(GPIO_NUM_17);
 	rtc_gpio_pullup_en(GPIO_NUM_17);
 	esp_sleep_enable_timer_wakeup(wakeup_time_sec * uS_TO_S_FACTOR);
 	esp_sleep_enable_ext0_wakeup(GPIO_NUM_17, 0); // 1 = High, 0 = Low
 	esp_set_deep_sleep_wake_stub(&wake_stub);
 	esp_deep_sleep_start();
 RTC_IRAM_ATTR esp_sleep_wakeup_cause_t stub_esp_sleep_get_wakeup_cause()
  if (_wakeup_cause & RTC_EXT0_TRIG_EN)
    return ESP_SLEEP_WAKEUP_EXT0;  // 2
  else if (_wakeup_cause & RTC_EXT1_TRIG_EN)
    return ESP_SLEEP_WAKEUP_EXT1;  // 3
  else if (_wakeup_cause & RTC_TIMER_TRIG_EN)
    return ESP_SLEEP_WAKEUP_TIMER;  // 4
  else if (_wakeup_cause & RTC_TOUCH_TRIG_EN)
    return ESP_SLEEP_WAKEUP_TOUCHPAD;  // 5
  else if (_wakeup_cause & RTC_ULP_TRIG_EN)
    return ESP_SLEEP_WAKEUP_ULP;  // 6
  else
    return ESP_SLEEP_WAKEUP_UNDEFINED;  // 0
//! Begin Wake Stub content
static const char RTC_RODATA_ATTR wakeup_cause_number_str[] = "Wakeup cause = %d\n";
static RTC_DATA_ATTR uint32_t wakeup_cause;
static void RTC_IRAM_ATTR wake_stub(void)
	esp_default_wake_deep_sleep();
	wakeup_cause = stub_esp_sleep_get_wakeup_cause();
	ets_printf(wakeup_cause_number_str, wakeup_cause);
	//... the rest does not really matter.... if ext0 is the wake cause, I wait for it to return high, then go back to sleep
	// ... and if the cause is the timer or undefined, I wake up completely with a "return"
and my platformio.ini
[env:esp32-s3-devkitc-1]
platform = espressif32@6.4.0
board = esp32-s3-devkitc-1
board_build.arduino.memory_type = dio_opi
monitor_speed = 115200
framework = arduino
board_build.partitions = default_partitions.csv
build_flags =
	-I./src/
	-DCORE_DEBUG_LEVEL=5
	-DBOARD_HAS_PSRAM
	-mfix-esp32-psram-cache-issue
	-fmax-errors=5
ESP-Marius
Re: Getting Wake Cause in Wake Stub not working on S3
Postby ESP-Marius » Wed Nov 22, 2023 3:29 am
Looking at the TRM,
does not seem to be the correct register for reading the wake-up cause on S3.
is from
RTC_CNTL_SLP_WAKEUP_CAUSE_REG
You can take a look at
rtc_cntl_ll_get_wakeup_cause()
to see how it is done on different chips (you could use this in function in your stub) and see if that solves your issue.
PeteDD
Postby PeteDD » Wed Nov 22, 2023 1:41 pm
@ESP_Marius, Thank you.
PeteDD
Postby PeteDD » Wed Nov 22, 2023 11:33 pm
@ESP_Marius... I am finding LOTS of things that work on ESP32 but not on ESP32-S3. I wish there were a list of these things somewhere...
Here is what I ended up with for the capture of the wake reason in a wake stub. But, I still have an odd problem that I will write about separately.
#include "esp_sleep.h"          // needed for ESP_SLEEP_WAKEUP_* values
#include "soc/rtc_cntl_reg.h"  // needed for  RTC_CNTL_SLP_WAKEUP_CAUSE_REG
// (other includes that are needed are possibly not listed here)
static const char RTC_RODATA_ATTR wakeup_cause_EXT0_str[] = "WAKE_STUB: Wakeup Cause EXT0\n";
static const char RTC_RODATA_ATTR wakeup_cause_TIMER_str[] = "WAKE_STUB: Wakeup Cause TIMER\n";
    uint32_t _wakeup_cause = REG_GET_FIELD(RTC_CNTL_SLP_WAKEUP_CAUSE_REG, RTC_CNTL_WAKEUP_CAUSE);
  else
  esp_default_wake_deep_sleep(); // If supplying a custom wake stub, the first thing it does should be to call
  //  https://docs.espressif.com/projects/esp-idf/en/latest/esp32s3/api-guides/deep-sleep-stub.html#implementing-a-stub
  switch (wakeup_cause)
    // If we woke up from the power button, and we're not critical voltage just boot up
  case ESP_SLEEP_WAKEUP_EXT0:
    	ets_printf(wakeup_cause_EXT0_str);
	// do stuff here
	// and go prepare to go back to sleep
	// Wait for pin level to be high.
    	// If we go to sleep when the pin is still low, the chip
    	// will wake up again immediately. Hardware doesn't have
    	// edge trigger support for deep sleep wakeup.
   	 while (GPIO_INPUT_GET(RAIN_CNT_GPIO_NUM) == 0)
      		// feed the watchdog
     		 REG_WRITE(TIMG_WDTFEED_REG(0), 1);
      		 ets_delay_us(RAIN_COUNT_PULSE_DEBOUNCE_US);
	    // Set the pointer of the wake stub function.
    	REG_WRITE(RTC_ENTRY_ADDR_REG, (uint32_t)&wake_stub);
    	// Go back to sleep.
    	CLEAR_PERI_REG_MASK(RTC_CNTL_STATE0_REG, RTC_CNTL_SLEEP_EN);
    	SET_PERI_REG_MASK(RTC_CNTL_STATE0_REG, RTC_CNTL_SLEEP_EN);
    	// A few CPU cycles may be necessary for the sleep to start...
    	while (true)
    	// never reaches here.
   	 break; // case ESP_SLEEP_WAKEUP_EXT0:
   case ESP_SLEEP_WAKEUP_TIMER:
   	 ets_printf(wakeup_cause_TIMER_str);
	  // Return from the wake stub function to continue
    // booting the firmware.
    return;
    break; // case ESP_SLEEP_WAKEUP_TIMER:
Users browsing this forum: ChatGPT-User, PerplexityBot, Qwantbot, YisouSpider and 7 guests
