Cannot Move Components Outside of Project Tree
BoCoKeith
Postby BoCoKeith » Sat Nov 25, 2023 6:59 pm
I am having a problem moving components outside of a project folder. With the following directory structure...
C:\ESP\sprinkle
└─sprinkle-sensor
  ├─CMakeLists.txt
  ├─sdkconfig
  ├─build
  ├─components
  │ └─sprinkle_common
  │   ├─CMakeLists.txt
  │   ├─component.mk
  │   ├─sprinkle_common.c
  │   └─include
  │     └─sprinkle_common.h
  └─main
    ├─CMakeLists.txt
    └─sprinkle-sensor.c
... and the project CMakeLists.txt file containing ...
# For more information about build system see
# https://docs.espressif.com/projects/esp-idf/en/latest/api-guides/build-system.html
# The following five lines of boilerplate have to be in your project's
# CMakeLists in this exact order for cmake to work correctly
cmake_minimum_required(VERSION 3.16)
project(sprinkle-sensor)
... for the almost trivial sprinkle_sensor.c of ...
#include <stdio.h>
#include "sprinkle_common.h"
void app_main(void) {
    printf("MESSAGE_MOISTURE_SENSOR=%d\n", MESSAGE_MOISTURE_SENSOR);
... I can build the project just fine. (No errors.) But if I try to move the components folder "up" one level ...
C:\ESP\sprinkle
├─components
│ └─sprinkle_common
│   ├─CMakeLists.txt
│   ├─component.mk
│   └─include
└─sprinkle-sensor
  ├─CMakeLists.txt
  ├─sdkconfig
  ├─build
  └─main
    ├─CMakeLists.txt
    └─sprinkle-sensor.c
... and then change the project CMakeLists.txt to ...
set(EXTRA_COMPONENTS_DIR ..)
... I keep getting the error ...
C:/ESP/sprinkle/sprinkle-sensor/main/sprinkle-sensor.c:15:10: fatal error: sprinkle_common.h: No such file or directory
   15 | #include "sprinkle_common.h"
compilation terminated.
I've tried all sorts of variants of the extra components directory: "..", "..\..", "..\components", but no change.
What am I doing wrong?
MicroController
Re: Cannot Move Components Outside of Project Tree
Postby MicroController » Sun Nov 26, 2023 2:45 pm
You're setting the wrong variable.
The thing is (maybe unintuitively) called EXTRA_COMPONENT_DIRS. (Because there can be multiple extra component-directories...)
Postby Sprite » Mon Nov 27, 2023 2:21 am
Good catch! I stared at the post for a few minutes but couldn't find anything wrong, even cross-referencing with my own setup.
BoCoKeith
Postby BoCoKeith » Tue Nov 28, 2023 4:37 pm
Thanks a ton, @Microcontroller. That did it! (And thanks for looking @ESP_Sprite.)
Users browsing this forum: Baidu [Spider], Bing [Bot], DuckDuckGo [Bot], Google [Bot], PerplexityBot, Semrush [Bot], YisouSpider and 1 guest
