2 way communication using ESP-WROOM-32 not working
keshavshankar
Postby keshavshankar » Tue Nov 28, 2023 6:23 am
I am trying to make a 2 way communication for my own IOT device. I have one esp32 acting as a hub, and one esp32 acting as an end device for a sensor. Ideally, my hub will always be on. Once my end device turns on, I want it to ping its mac address to be picked up by the hub, and once the hub receives it and stores it as a "paired device", it sends an acknowledgment to that end device with the hub's mac address. This enables a replicated pairing structure so that once paired, I can send signals to the specific devices connected.
My issue right now is that I am able to send my initial signal from the end device to the hub, but the hub does not send back the acknowledgement to the end device. When I debug the code, it looks like in the Hub.ino, it does get past line 36, and my flag updates. Additionally, I printed out the mac address of the end device received in the hub and it is correct. I suspect the problem is with the EndDevice.io in the loop(), since it is constantly sending data to the channel, thus it cant receive data from the hub on that same channel? Maybe I am misunderstanding how 2 way communication works with esp-now. Any help is appreciated!
Hub.ino
Code: Hub.cpp Select all
#include <esp_now.h>
#include <WiFi.h>
// Device data object
typedef struct {
uint8_t device_mac_address[6]; // mac address of device
int device_type; // 0 = smart flusher, etc.
} device_data;
device_data device_info; // local storage of paired device
// Hub data object
typedef struct {
uint8_t hub_mac_address[6]; // mac address of hub
} hub_data;
hub_data hub_info; // local storage of hub data
// Device pairing flags
bool pairedFlag = false;
bool sentAck = false;
// Handler for when data received using esp-now
void on_data_received(const uint8_t * mac, const uint8_t *incomingData, int len) {
if(pairedFlag == false){
// copy received device data to local
memcpy(&device_info, incomingData, sizeof(device_info));
// set as paired
pairedFlag = true;
Serial.println("Paired device " + String(device_info.device_type) + " with ");
for(int i = 0; i < 6; i++){
Serial.print(device_info.device_mac_address[i], HEX);
Serial.println();
// get hub mac address
esp_read_mac(hub_info.hub_mac_address, ESP_MAC_WIFI_STA);
// send paired acknowledgement back to device
if(pairedFlag == true && sentAck == false){
esp_now_send(device_info.device_mac_address, (uint8_t *) &hub_info, sizeof(hub_info));
sentAck = true;
// Handler for when data sent using esp-now
void on_data_sent(const uint8_t *mac_addr, esp_now_send_status_t status) {
Serial.print("\r\nLast Packet Send Status:\t");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
WiFi.mode(WIFI_STA);
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
// call handler when data received
esp_now_register_recv_cb(on_data_received);
// call handler when data sent
esp_now_register_send_cb(on_data_sent);
Serial.println(WiFi.macAddress());
EndDevice.ino
Code: EndDevice.cpp Select all
#include <WiFi.h>
typedef struct {
} device_data;
// Hub data object
typedef struct {
uint8_t hub_mac_address[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};; // mac address of hub
} hub_data;
esp_now_peer_info_t peerInfo;
memcpy(&hub_info, incomingData, sizeof(hub_info));
// set as paired
pairedFlag = true;
Serial.println("Paired to hub");
return;
// register peer
memcpy(peerInfo.peer_addr, hub_info.hub_mac_address, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
// add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK){
Serial.println("Failed to add peer");
return;
// set device mac address and type
esp_read_mac(device_info.device_mac_address, ESP_MAC_WIFI_STA);
device_info.device_type = 0;
// call function on data send
// call function on data receive
// run pair sequence if not paired
// send data to pair to hub
esp_now_send(hub_info.hub_mac_address, (uint8_t *) &device_info, sizeof(device_info));
Users browsing this forum: Applebot, Bytespider, meta-externalagent, Semrush [Bot] and 3 guests
