Ran into issue getting AEC to work with 2 way tcp
Rnd1AtMypromosysMY
Postby Rnd1AtMypromosysMY » Thu Nov 30, 2023 10:42 am
Code: Untitled.c Select all
Managed to get 2 way tcp to work, with i2s stream but attempting to get it to work with AEC ran into issues as echo is not canceled.
Micro-controller: ESP32-S3
Codec: es8388
ESP-ADF Version: v2.6
ESP-IDF Version: v4.4.6
#Note: Mic volume and speaker volume needs to be as loud as possible
//Pipeline configuration is as follows
// Audio Playback pipeline
    audio_pipeline_cfg_t pipeline_cfg = DEFAULT_AUDIO_PIPELINE_CONFIG();
    player = audio_pipeline_init(&pipeline_cfg);
    mem_assert(player);
    AUDIO_NULL_CHECK(TAG, player, return ESP_FAIL);
	ESP_LOGI(TAG, "----> Player_pipeline_open Start <----");
    ESP_LOGI(TAG, "Create tcp client stream to read data");
    tcp_stream_cfg_t tcp_cfg = TCP_STREAM_CFG_DEFAULT();
    tcp_cfg.type = AUDIO_STREAM_READER;
    tcp_cfg.port = CONFIG_PLAYBACK_TCP_PORT;
    tcp_cfg.host = CONFIG_PLAYBACK_TCP_URL;
	tcp_cfg.timeout_ms = 3600 * 1000;
	tcp_cfg.task_stack = (16 * 1024);
	tcp_cfg.ext_stack = true;
	tcp_cfg.task_core = 0;
    tcp_cfg.event_handler = tcp_read_stream_event_handle;
    tcp_cfg.event_ctx = (void *) &AdsT;
    tcp_stream_reader = tcp_stream_init(&tcp_cfg);
    AUDIO_NULL_CHECK(TAG, tcp_stream_reader, return 0);
    rsp_filter_cfg_t rsp_cfg_w = DEFAULT_RESAMPLE_FILTER_CONFIG();
    rsp_cfg_w.src_rate = 16000;
    rsp_cfg_w.src_ch = 1;
    rsp_cfg_w.dest_rate = 16000;
    rsp_cfg_w.dest_ch = 1;
	rsp_cfg_w.task_stack = (16 * 1024);
	rsp_cfg_w.out_rb_size = (4 * 1024);
	rsp_cfg_w.stack_in_ext = true;
	rsp_cfg_w.task_core = 0;
    rsp_cfg_w.complexity = 5;
    filter_w = rsp_filter_init(&rsp_cfg_w);
    AUDIO_NULL_CHECK(TAG, filter_w, return 0);
    audio_element_set_write_cb(filter_w, i2s_write_cb, NULL);
    audio_element_set_output_timeout(filter_w, portMAX_DELAY);
    ESP_LOGI(TAG, "Create i2s stream to write data to codec chip");
    ESP_LOGI(TAG, "Register all elements to audio player pipeline");
    audio_pipeline_register(player, tcp_stream_reader, "TCP_RD");
	audio_pipeline_register(player, filter_w, "filter_w");
    ESP_LOGI(TAG, "Link it together TCP_WR-->filter-->[codec_chip]");
    const char *link_tag[2] = {"TCP_RD", "filter_w"};
    audio_pipeline_link(player, &link_tag[0], 2);
    ESP_LOGI(TAG, "VOIP player has been created");
    ESP_LOGI(TAG, "----> Player_pipeline_open End <----");
// Audio Record pipeline
    recorder = audio_pipeline_init(&pipeline_cfg);
    mem_assert(recorder);
    AUDIO_NULL_CHECK(TAG, recorder, return ESP_FAIL);
	ESP_LOGI(TAG, " ----> Recorder_pipeline_open Start <----");
    ESP_LOGI(TAG, "Create algorithm stream for aec");
    algorithm_stream_cfg_t algo_config = ALGORITHM_STREAM_CFG_DEFAULT();
	algo_config.input_type = ALGORITHM_STREAM_INPUT_TYPE2;
    algo_config.sample_rate = I2S_SAMPLE_RATE;
	algo_config.task_core = 1;
	algo_config.stack_in_ext = 1;
	algo_config.task_prio = 22;
	algo_config.algo_mask = (ALGORITHM_STREAM_USE_AEC|ALGORITHM_STREAM_USE_AGC|ALGORITHM_STREAM_USE_NS);
	algo_config.rec_linear_factor = 1;
	algo_config.ref_linear_factor = 1;
	algo_config.agc_gain = 20;
	algo_config.task_stack = (16 * 1024);
	algo_config.out_rb_size = (8 * 1024);
    element_algo = algo_stream_init(&algo_config);
    AUDIO_NULL_CHECK(TAG, element_algo, return 0);
    audio_element_set_music_info(element_algo, I2S_SAMPLE_RATE, I2S_CHANNELS, I2S_BITS);
    audio_element_set_read_cb(element_algo, i2s_read_cb, NULL);
    audio_element_set_input_timeout(element_algo, portMAX_DELAY);
    ESP_LOGI(TAG, "Create tcp client stream to write data");
    tcp_cfg.type = AUDIO_STREAM_WRITER;
    tcp_cfg.host = CONFIG_RECORD_TCP_URL;
	tcp_cfg.task_core = 1;
	tcp_cfg.task_prio = 15;
    tcp_cfg.event_handler = tcp_write_stream_event_handle;
    tcp_stream_writer = tcp_stream_init(&tcp_cfg);
    AUDIO_NULL_CHECK(TAG, tcp_stream_writer, return 0);
    ESP_LOGI(TAG, "Register all elements to audio recorder pipeline");
	audio_pipeline_register(recorder, element_algo, "algo");
    audio_pipeline_register(recorder, tcp_stream_writer, "TCP_WR");
    ESP_LOGI(TAG, "Link it together Algo-->TCP_WR");
	const char *link_tag[2] = {"algo","TCP_WR"};
    audio_pipeline_link(recorder, &link_tag[0], 2);
    ESP_LOGI(TAG, "VOIP recorder has been created");
    ESP_LOGI(TAG, " ----> Recorder_pipeline_open End <----");
    //Please reference the way of ALGORITHM_STREAM_INPUT_TYPE2 in "algorithm_stream.h"
    ringbuf_ref = rb_create(256, 1);
    audio_element_set_multi_input_ringbuf(element_algo, ringbuf_ref, 0);
    /* When the playback signal far ahead of the recording signal,
        the playback signal needs to be delayed */
    algo_stream_set_delay(element_algo, ringbuf_ref, 5);
// Codec Config
	audio_hal_set_volume(board_handle->audio_hal, 95);
	es8388_set_mic_gain(24);
// I2s driver Config
      i2s_config_t i2s_cfg = {
        .mode = I2S_MODE_MASTER | I2S_MODE_TX | I2S_MODE_RX,
        .sample_rate = I2S_SAMPLE_RATE,
        .bits_per_sample = bits,
        .channel_format = channels,
        .communication_format = I2S_COMM_FORMAT_STAND_I2S,
        .intr_alloc_flags = ESP_INTR_FLAG_LEVEL2 | ESP_INTR_FLAG_IRAM,
        .dma_buf_count = 8,
        .dma_buf_len = 300,
		.use_apll = false,
        .tx_desc_auto_clear = true,
        .fixed_mclk = 0
RAW_TCP.c
(18.73 KiB) Downloaded 6673 times
