SD append to file fails to write when called from inside a function
ienaxxx
Postby ienaxxx » Mon Dec 04, 2023 9:36 pm
Hello everyone, I'm new to this forum.
long story short, when i call the SD Functions from inside setup, it works like a charm, but when calling from inside a function, called from another function, it doesn't. It can't open the file for appending (nor for writing).
The https://github.com/espressif/arduino-e ... D_Test.ino sketch works perfectly.
I use Arduino IDE to program My ESP32 NodeMCU-32s. Trying to reorganize some code here, I created a function "exec", that calls other functions when a command is received via Serial. This function will call the function that matches with the received command to behave accordingly. I wrote the functions in a secondary file and let the main program handle the
here the main file:
#include <EEPROM.h>
#include <FS.h>
#include <SD.h>
#define CCBUFFERSIZE 64
#define RECORDINGBUFFERSIZE 4096   // Buffer for recording the frames
#define EPROMSIZE 512              // Size of EEPROM in your Arduino chip. For ESP32 it is Flash simulated so very slow
#define BUF_LENGTH 128             // Buffer for the incoming command.
// defining PINs set for ESP32 WROOM module
byte sck = 18;     //  GPIO 18
byte miso = 19;    //  GPIO 19
byte mosi = 23;    //  GPIO 23
byte ss = 5;       //  GPIO 5
int gdo0 = 4;      //  GPIO 2
int gdo2 = 2;      //  GPIO 4
byte SDchipSelectPin = 17;
File myFile;
    // First of all, let' bring the MicroSD Card CS PIN HIGH, to disable it.
    pinMode(SDchipSelectPin, OUTPUT);
    digitalWrite(SDchipSelectPin, 255);
    pinMode(ss, OUTPUT);
     // initialize USB Serial Port CDC
    //Init EEPROM - for ESP32 based boards only
     EEPROM.begin(EPROMSIZE);
     // initialize CC1101 module with preffered parameters
     cc1101initialize();
      if (ELECHOUSE_cc1101.getCC1101()) {  // Check the CC1101 Spi connection.
      Serial.println(F("cc1101 initialized. Connection OK\n\r"));
      Serial.println(F("cc1101 connection error! check the wiring.\n\r"));
      // setup variables
     bigrecordingbufferpos = 0;
      delay(500);
      if(!SD.begin(SDchipSelectPin)){
          Serial.print(F("Card Mount Failed. CS PIN IS "));
          Serial.print(SDchipSelectPin);
        initCard();
       myFile = SD.open("/foo.txt", FILE_APPEND);
       if(!myFile){
         Serial.println(F("failed to open file"));
       myFile.print("qweuiyqwe87q98we7h1i23hqwlkjeuqj2e");
      myFile.print("\n");
       myFile.close();
  int i = 0;
  while (Serial.available()) {
   handleCLIMode();
  }; // end while Serial Available
  /* Process RF received packets  (if received) */
  ccProcessReceivedPackets();
}  // end of main LOOP
and here the relevant part of the other file
void ccSave2SD(){
  Serial.println(F("Saving to file, please wait..."));
  // spiEnableCC1101(false);
  // spiEnableSD(true);
  delay(500);
  // take 32 bytes at a time, convert To HEX and print it inline in the file.
  SD.begin(SDchipSelectPin);
  File myFile=SD.open("/foo.txt", FILE_APPEND);
  if(!myFile){
    Serial.println(F("unable to open file"));
    return;
  myFile.print("signal:");
   myFile.print("\n");// at the end go for it
   myFile.close();
  delay(300);
  // spiEnableSD(false);
  // spiEnableCC1101(true);
static void exec(char *cmdline)
    char *command = strsep(&cmdline, " ");
    int setting, setting2, len;
    byte j, k;
    float settingf1;
    float settingf2;
    if (strcmp_P(command, PSTR("help")) == 0) {
 	Serial.println(F("help function"));
 	// ... many more cases here.
  } else if (strcmp_P(command, PSTR("save2sd")) == 0) {
      //start saving recording buffer content into EEPROM non-volatile memory
      ccSave2SD();
      Serial.print(F("\r\nSaving complete.\r\n\r\n"));
        Serial.print(F("Error: Unknown command: "));
        Serial.println(command);
The problem is: each time the program is executed the file gets "qweuiyqwe87q98we7h1i23hqwlkjeuqj2e" appended to it, but when it comes to the function part it keeps returning "unable to open file" and nothing else is written to the file.
I dont' know why...
MicroController
Re: SD append to file fails to write when called from inside a function
Postby MicroController » Sun Dec 10, 2023 12:53 am
should only be called once, e.g. in setup().
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
