I (1409) gpio: GPIO[48]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
E (1540) ESP-BOX-3: Touch not found
ESP_ERROR_CHECK failed: esp_err_t 0x105 (ESP_ERR_NOT_FOUND) at 0x420101ff
0x420101ff: bsp_display_indev_init at /Users/lomon/esp-box/examples/chatgpt_demo/managed_components/espressif__esp-box-3/esp-box-3.c:541
(inlined by) bsp_display_start_with_config at /Users/lomon/esp-box/examples/chatgpt_demo/managed_components/espressif__esp-box-3/esp-box-3.c:570
file: "./managed_components/espressif__esp-box-3/esp-box-3.c" line 541
func: bsp_display_indev_init
expression: bsp_touch_new(((void *)0), &tp)
abort() was called at PC 0x403802ab on core 0
0x403802ab: _esp_error_check_failed at /Users/lomon/esp/esp-idf/components/esp_system/esp_err.c:50
Backtrace: 0x40375f0a:0x3fcabdf0 0x403802b5:0x3fcabe10 0x40387bea:0x3fcabe30 0x403802ab:0x3fcabea0 0x420101ff:0x3fcabed0 0x42010259:0x3fcabf20 0x4200b097:0x3fcabf60 0x4211ecc7:0x3fcabf80
0x40375f0a: panic_abort at /Users/lomon/esp/esp-idf/components/esp_system/panic.c:452
0x403802b5: esp_system_abort at /Users/lomon/esp/esp-idf/components/esp_system/port/esp_system_chip.c:84
0x40387bea: abort at /Users/lomon/esp/esp-idf/components/newlib/abort.c:38
0x42010259: bsp_display_start at /Users/lomon/esp-box/examples/chatgpt_demo/managed_components/espressif__esp-box-3/esp-box-3.c:558
0x4200b097: app_main at /Users/lomon/esp-box/examples/chatgpt_demo/main/main.c:137 (discriminator 2)
0x4211ecc7: main_task at /Users/lomon/esp/esp-idf/components/freertos/app_startup.c:208 (discriminator 13)
我是mac装了esp-idf,参照esp-box-3的chatgpt demo教程操作的。
https://github.com/espressif/esp-box/tr ... atgpt_demo
想问下这个问题如何解决,谢谢。
Re: E (1540) ESP-BOX-3: Touch not found
您好,首先您需要确保软硬件版本一致,您可以通过 idf.py menuconfig 命令打开配置菜单,在配置菜单中找到 HMI Board Config 项中,选择您的开发板。选择成功后请再次尝试,如果仍存在问题,可以提供更多日志信息以便排查问题。
