My MASTER terminal:
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:6940
ho 0 tail 12 room 4
load:0x40078000,len:15500
load:0x40080400,len:3844
0x40080400: _init at ??:?
entry 0x4008064c
I (29) boot: ESP-IDF v5.0.2 2nd stage bootloader
I (29) boot: compile time 11:29:06
I (29) boot: chip revision: v3.0
I (32) boot.esp32: SPI Speed : 40MHz
I (37) boot.esp32: SPI Mode : DIO
I (41) boot.esp32: SPI Flash Size : 2MB
I (46) boot: Enabling RNG early entropy source...
I (51) boot: Partition Table:
I (55) boot: ## Label Usage Type ST Offset Length
I (62) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (70) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (77) boot: 2 factory factory app 00 00 00010000 00100000
I (85) boot: End of partition table
I (89) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=1b8b0h (112816) map
I (138) esp_image: segment 1: paddr=0002b8d8 vaddr=3ffbdb60 size=04214h ( 16916) load
I (145) esp_image: segment 2: paddr=0002faf4 vaddr=40080000 size=00524h ( 1316) load
I (146) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=6dc54h (449620) map
I (315) esp_image: segment 4: paddr=0009dc7c vaddr=40080524 size=18b18h (101144) load
I (369) boot: Loaded app from partition at offset 0x10000
I (369) boot: Disabling RNG early entropy source...
I (381) cpu_start: Pro cpu up.
I (381) cpu_start: Starting app cpu, entry point is 0x40081454
0x40081454: call_start_cpu1 at C:/Users/konec/esp/esp-idf/components/esp_system/port/cpu_start.c:141
I (367) cpu_start: App cpu up.
I (397) cpu_start: Pro cpu start user code
I (397) cpu_start: cpu freq: 160000000 Hz
I (397) cpu_start: Application information:
I (402) cpu_start: Project name: BT_SPP_MASTER_v00-01
I (408) cpu_start: App version: 1
I (413) cpu_start: Compile time: Dec 22 2023 11:28:30
I (419) cpu_start: ELF file SHA256: afc26a0c4e5e045a...
Warning: checksum mismatch between flashed and built applications. Checksum of built application is dc5b3c2a9f640360416dbcbbff7a9388eecf3be72d708db51fa34cafb11d45d1
I (425) cpu_start: ESP-IDF: v5.0.2
I (430) cpu_start: Min chip rev: v0.0
I (434) cpu_start: Max chip rev: v3.99
I (439) cpu_start: Chip rev: v3.0
I (444) heap_init: Initializing. RAM available for dynamic allocation:
I (451) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (457) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
I (463) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (469) heap_init: At 3FFC7D68 len 00018298 (96 KiB): DRAM
I (475) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (482) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (488) heap_init: At 4009903C len 00006FC4 (27 KiB): IRAM
I (496) spi_flash: detected chip: generic
I (499) spi_flash: flash io: dio
W (503) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (518) cpu_start: Starting scheduler on PRO CPU.
I (528) gpio: GPIO[27]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (538) SPP_INITIATOR_DEMO: Init DATA LED completed
I (538) gpio: GPIO[2]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (548) SPP_INITIATOR_DEMO: Init BT LED completed
I (568) BTDM_INIT: BT controller compile version [2c56073]
I (578) system_api: Base MAC address is not set
I (578) system_api: read default base MAC address from EFUSE
I (578) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
I (1238) SPP_INITIATOR_DEMO: ESP_SPP_INIT_EVT
I (1238) SPP_INITIATOR_DEMO: Own address:[70:b8:f6:5b:90:d6]
I (1248) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
I (1478) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_RES_EVT
I (1478) SPP_INITIATOR_DEMO: 48 e7 29 c8 9c 8a
I (1478) SPP_INITIATOR_DEMO: ESP_SPP_ACCEPTOR
I (1488) SPP_INITIATOR_DEMO: Peer device name: ESP_SPP_ACCEPTOR
I (1498) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
I (1508) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
I (1518) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
W (1768) BT_HCI: hcif conn complete: hdl 0x81, st 0x0
I (1948) SPP_INITIATOR_DEMO: ESP_SPP_DISCOVERY_COMP_EVT scn_num:1
I (1948) SPP_INITIATOR_DEMO: -- [0] scn:1 service_name:SPP_SERVER
I (1958) SPP_INITIATOR_DEMO: ESP_SPP_CL_INIT_EVT handle:129 sec_id:55
I (2058) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_RES_EVT
I (2058) SPP_INITIATOR_DEMO: 48 e7 29 c8 9c 8a
I (2058) SPP_INITIATOR_DEMO: ESP_SPP_ACCEPTOR
I (2068) SPP_INITIATOR_DEMO: Peer device name: ESP_SPP_ACCEPTOR
I (2078) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
I (2088) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
I (2098) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
I (2238) SPP_INITIATOR_DEMO: ESP_SPP_DISCOVERY_COMP_EVT scn_num:1
I (2238) SPP_INITIATOR_DEMO: -- [0] scn:1 service_name:SPP_SERVER
E (2238) BT_RFCOMM: RFCOMM_CreateConnection - already opened state:1, RFC state:1, MCB state:5
E (2248) BT_APPL: bta_jv_rfcomm_connect, RFCOMM_CreateConnection failed
E (2258) SPP_INITIATOR_DEMO: ESP_SPP_CL_INIT_EVT status:1
I (2268) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_RES_EVT
I (2268) SPP_INITIATOR_DEMO: 48 e7 29 c8 9c 8a
I (2278) SPP_INITIATOR_DEMO: ESP_SPP_ACCEPTOR
I (2278) SPP_INITIATOR_DEMO: Peer device name: ESP_SPP_ACCEPTOR
W (2298) BT_APPL: new conn_srvc id:26, app_id:1
W (2298) BT_APPL: bta_dm_pm_ssr conn_srvc id:26, app_id:1
W (2298) BT_APPL: bta_dm_pm_ssr:2, lat:1200
I (2308) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
I (2308) SPP_INITIATOR_DEMO: ESP_SPP_OPEN_EVT handle:129 rem_bda:[48:e7:29:c8:9c:8a]
I (2318) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
I (2328) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
I (2338) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
I (2338) SPP_INITIATOR_DEMO: ESP_SPP_WRITE_EVT
I (2388) SPP_INITIATOR_DEMO: ESP_SPP_DATA_IND_EVT
I (2388) SPP_INITIATOR_DEMO: DATA LED ON
I (2388) SPP_INITIATOR_DEMO: ************************************Received data START***************************************************
I (2398) Received data (HEX): : 41 68 6f 6a 20 74 61 64 79 20 53 4c 41 56 45
I (2408) SPP_INITIATOR_DEMO: Received data (TEXT): Ahoj tady SLAVE
I (2418) SPP_INITIATOR_DEMO: ************************************Received data END*****************************************************
I (2488) SPP_INITIATOR_DEMO: ESP_SPP_DISCOVERY_COMP_EVT scn_num:1
I (2488) SPP_INITIATOR_DEMO: -- [0] scn:1 service_name:SPP_SERVER
E (2488) BT_RFCOMM: RFCOMM_CreateConnection - already opened state:2, RFC state:4, MCB state:5
E (2498) BT_APPL: bta_jv_rfcomm_connect, RFCOMM_CreateConnection failed
E (2508) SPP_INITIATOR_DEMO: ESP_SPP_CL_INIT_EVT status:1
I (2658) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_RES_EVT
I (2668) SPP_INITIATOR_DEMO: 48 e7 29 c8 9c 8a
I (2668) SPP_INITIATOR_DEMO: ESP_SPP_ACCEPTOR
I (2668) SPP_INITIATOR_DEMO: Peer device name: ESP_SPP_ACCEPTOR
I (2678) SPP_INITIATOR_DEMO: ESP_BT_GAP_DISC_STATE_CHANGED_EVT
W (7588) BT_HCI: hci cmd send: sniff: hdl 0x81, intv(400 800)
W (7588) BT_HCI: hcif mode change: hdl 0x81, mode 2, intv 800, status 0x0
W (9168) BT_HCI: hcif ssr evt: st 0x0, hdl 0x81, tx_lat 800 rx_lat 800Code: Select all
PS C:\Users\konec\ESP-IDF\BR_SPP_SLAVE_v00-01> set IDF_PATH=C:\Users\konec\esp\esp-idf
PS C:\Users\konec\ESP-IDF\BR_SPP_SLAVE_v00-01> c:\Espressif\python_env\idf5.0_py3.8_env\Scripts\python.exe C:\Users\konec\esp\esp-idf\tools\idf_monitor.py -p COM11 -b 115200 --toolchain-prefix xtensa-esp32-elf- --target esp32 c:\Users\konec\ESP-IDF\BR_SPP_SLAVE_v00-01\build\BR_SPP_SLAVE_v00-01.elf
--- WARNING: GDB cannot open serial ports accessed as COMx
--- Using \\.\COM11 instead...
--- idf_monitor on \\.\COM11 115200 ---
ho 0 tail 12 room 4
entry 0x4008064c
I (29) boot: compile time 11:35:21
I (89) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=1b700h (112384) map
I (138) esp_image: segment 1: paddr=0002b728 vaddr=3ffbdb60 size=04214h ( 16916) load
I (145) esp_image: segment 2: paddr=0002f944 vaddr=40080000 size=006d4h ( 1748) load
I (146) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=6d72ch (448300) map
I (314) esp_image: segment 4: paddr=0009d754 vaddr=400806d4 size=18968h (100712) load
I (368) boot: Loaded app from partition at offset 0x10000
I (368) boot: Disabling RNG early entropy source...
I (380) cpu_start: Pro cpu up.
I (380) cpu_start: Starting app cpu, entry point is 0x40081454
I (0) cpu_start: App cpu up.
I (396) cpu_start: Pro cpu start user code
I (396) cpu_start: cpu freq: 160000000 Hz
I (396) cpu_start: Application information:
I (401) cpu_start: Project name: BR_SPP_SLAVE_v00-01
I (407) cpu_start: App version: 1
I (412) cpu_start: Compile time: Dec 22 2023 11:34:44
I (418) cpu_start: ELF file SHA256: 4df698889dac1c5c...
I (424) cpu_start: ESP-IDF: v5.0.2
I (429) cpu_start: Min chip rev: v0.0
I (433) cpu_start: Max chip rev: v3.99
I (438) cpu_start: Chip rev: v3.0
I (443) heap_init: Initializing. RAM available for dynamic allocation:
I (450) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (456) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
I (462) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (468) heap_init: At 3FFC7C58 len 000183A8 (96 KiB): DRAM
I (474) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (481) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (487) heap_init: At 4009903C len 00006FC4 (27 KiB): IRAM
I (495) spi_flash: detected chip: generic
I (498) spi_flash: flash io: dio
W (502) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (516) cpu_start: Starting scheduler on PRO CPU.
I (527) gpio: GPIO[27]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (537) SPP_ACCEPTOR_DEMO: Init DATA LED completed
I (537) gpio: GPIO[2]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (547) SPP_ACCEPTOR_DEMO: Init BT LED completed
I (577) BTDM_INIT: BT controller compile version [2c56073]
I (577) system_api: Base MAC address is not set
I (577) system_api: read default base MAC address from EFUSE
I (587) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
I (1237) SPP_ACCEPTOR_DEMO: ESP_SPP_INIT_EVT
I (1247) SPP_ACCEPTOR_DEMO: ESP_SPP_START_EVT handle:129 sec_id:55 scn:1
W (14947) BT_HCI: hcif conn complete: hdl 0x80, st 0x0
W (14957) BT_HCI: hcif link supv_to changed: hdl 0x80, supv_to 8000
W (15317) BT_APPL: new conn_srvc id:26, app_id:255
W (15317) BT_APPL: bta_dm_pm_ssr conn_srvc id:26, app_id:255
W (15317) BT_APPL: bta_dm_pm_ssr:2, lat:1200
I (15327) SPP_ACCEPTOR_DEMO: ESP_SPP_SRV_OPEN_EVT
I (15327) SPP_ACCEPTOR_DEMO: Remote device address: 70:b8:f6:5b:90:d6
I (15337) SPP_ACCEPTOR_DEMO: ESP_SPP_WRITE_EVT
I (15387) SPP_ACCEPTOR_DEMO: DATA LED ON
I (15387) SPP_ACCEPTOR_DEMO: ************************************Received data START***************************************************
I (15397) Received data (HEX): : 41 68 6f 6a 20 74 61 64 79 20 4d 41 53 54 45 52
I (15407) SPP_ACCEPTOR_DEMO: Received data (TEXT): Ahoj tady MASTER
I (15407) SPP_ACCEPTOR_DEMO: ************************************Received data END*****************************************************
W (20627) BT_HCI: hcif mode change: hdl 0x80, mode 2, intv 800, status 0x0
W (22237) BT_HCI: hcif ssr evt: st 0x0, hdl 0x80, tx_lat 800 rx_lat 800
W (135227) BT_RFCOMM: port_rfc_closed RFCOMM connection in server:1 state 2 closed: Peer connection failed (res: 16)
W (135237) BT_HCI: hcif disc complete: hdl 0x80, rsn 0x8
I (135237) SPP_ACCEPTOR_DEMO: ESP_SPP_CLOSE_EVT status:0 handle:129 close_by_remote:1
W (135907) BT_HCI: hcif conn complete: hdl 0x81, st 0x0
W (135907) BT_HCI: hcif link supv_to changed: hdl 0x81, supv_to 8000
W (136447) BT_APPL: new conn_srvc id:26, app_id:255
W (136447) BT_APPL: bta_dm_pm_ssr conn_srvc id:26, app_id:255
W (136447) BT_APPL: bta_dm_pm_ssr:2, lat:1200
I (136457) SPP_ACCEPTOR_DEMO: ESP_SPP_SRV_OPEN_EVT
I (136457) SPP_ACCEPTOR_DEMO: Remote device address: 70:b8:f6:5b:90:d6
I (136467) SPP_ACCEPTOR_DEMO: ESP_SPP_WRITE_EVT
I (136517) SPP_ACCEPTOR_DEMO: DATA LED ON
I (136517) SPP_ACCEPTOR_DEMO: ************************************Received data START***************************************************
I (136527) Received data (HEX): : 41 68 6f 6a 20 74 61 64 79 20 4d 41 53 54 45 52
I (136537) SPP_ACCEPTOR_DEMO: Received data (TEXT): Ahoj tady MASTER
I (136547) SPP_ACCEPTOR_DEMO: ************************************Received data END*****************************************************
W (141767) BT_HCI: hcif mode change: hdl 0x81, mode 2, intv 800, status 0x0
W (143357) BT_HCI: hcif ssr evt: st 0x0, hdl 0x81, tx_lat 800 rx_lat 800
W (162357) BT_RFCOMM: port_rfc_closed RFCOMM connection in server:1 state 2 closed: Peer connection failed (res: 16)
W (162357) BT_HCI: hcif disc complete: hdl 0x81, rsn 0x8
I (162357) SPP_ACCEPTOR_DEMO: ESP_SPP_CLOSE_EVT status:0 handle:385 close_by_remote:1
W (164477) BT_HCI: hcif conn complete: hdl 0x80, st 0x0
W (164487) BT_HCI: hcif link supv_to changed: hdl 0x80, supv_to 8000
W (164957) BT_APPL: new conn_srvc id:26, app_id:255
W (164957) BT_APPL: bta_dm_pm_ssr conn_srvc id:26, app_id:255
W (164957) BT_APPL: bta_dm_pm_ssr:2, lat:1200
I (164957) SPP_ACCEPTOR_DEMO: ESP_SPP_SRV_OPEN_EVT
I (164967) SPP_ACCEPTOR_DEMO: Remote device address: 70:b8:f6:5b:90:d6
I (164977) SPP_ACCEPTOR_DEMO: ESP_SPP_WRITE_EVT
I (165087) SPP_ACCEPTOR_DEMO: DATA LED ON
I (165087) SPP_ACCEPTOR_DEMO: ************************************Received data START***************************************************
I (165097) Received data (HEX): : 41 68 6f 6a 20 74 61 64 79 20 4d 41 53 54 45 52
I (165097) SPP_ACCEPTOR_DEMO: Received data (TEXT): Ahoj tady MASTER
I (165107) SPP_ACCEPTOR_DEMO: ************************************Received data END*****************************************************
W (170307) BT_HCI: hcif mode change: hdl 0x80, mode 2, intv 800, status 0x0
W (171887) BT_HCI: hcif ssr evt: st 0x0, hdl 0x80, tx_lat 800 rx_lat 800Code: Select all
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <stdio.h>
#include <inttypes.h>
#include "nvs.h"
#include "nvs_flash.h"
#include "freertos/task.h"
#include "freertos/timers.h" // přidáno pro blikající BT_LED
#include "esp_log.h"
#include "esp_bt.h"
#include "esp_bt_main.h"
#include "esp_gap_bt_api.h"
#include "esp_bt_device.h"
#include "esp_spp_api.h"
#include "time.h"
#include "sys/time.h"
#include "driver/gpio.h"
#define SPP_TAG "SPP_INITIATOR_DEMO"
#define EXAMPLE_DEVICE_NAME "ESP_SPP_INITIATOR"
#define SPP_SHOW_MODE SPP_SHOW_DATA /*Choose show mode: show data SPP_SHOW_DATA or speed SPP_SHOW_SPEED*/
#define LED_BT_PIN 2 // GPIO2 LED BT
#define LED_DATA_PIN 27 // GPIO27 LED DATA
static const esp_spp_mode_t esp_spp_mode = ESP_SPP_MODE_CB;
static const bool esp_spp_enable_l2cap_ertm = true;
static struct timeval time_new, time_old;
//? static long data_num = 0;
static const esp_spp_sec_t sec_mask = ESP_SPP_SEC_AUTHENTICATE;
static const esp_spp_role_t role_master = ESP_SPP_ROLE_MASTER;
esp_bd_addr_t peer_bd_addr = {0}; // Proměnná pro uchování BDA vzdáleného zařízení
static uint8_t peer_bdname_len; // Proměnná pro uchování délky vzdáleného zařizení
static char peer_bdname[ESP_BT_GAP_MAX_BDNAME_LEN + 1]; // Proměnná pro uchování jména vzdáleného zařízení; velikost pole = max. délka jména +1 znak
static const char remote_device_name[] = "ESP_SPP_ACCEPTOR"; // Proměnná pro uchování jména zařízení ke kterému se snažíme připojit
static const esp_bt_inq_mode_t inq_mode = ESP_BT_INQ_MODE_GENERAL_INQUIRY; // Proměnná určuje režim vyhledávání Bluetoth. "General Inquiry" je standardní režim pro vyhledávání zařízení v dosahu
static const uint8_t inq_len = 30; // Proměnná pro určenídélky vyhldávání v jednotkách 1.28 sec. Určuje, jak dlouho se budou vyhledávat ostatní zařízení
static const uint8_t inq_num_rsps = 0; // Proměnná určuje maximální počet odpovědí, které se mají zpracovat během jednoho vyhledávacího cyklu- 0 = bez limitu
//DEL #define SPP_DATA_LEN 85 // Délka odesílaných dat
//DEL static uint8_t spp_data[SPP_DATA_LEN];
//DEL static uint8_t *s_p_data = NULL; /* data pointer of spp_data */
// Proměnné pro obsluhu BT_LED
static TimerHandle_t blink_timer = NULL;
static bool is_connected = false;
// Proměnná pro reconnect timer
static TimerHandle_t reconnect_timer = NULL;
/*Převod Bluetooth Device Address (BDA) do četelného formátu*/
static char *bda2str(uint8_t * bda, char *str, size_t size)
if (bda == NULL || str == NULL || size < 18) {
return NULL;
uint8_t *p = bda;
sprintf(str, "%02x:%02x:%02x:%02x:%02x:%02x",
p[0], p[1], p[2], p[3], p[4], p[5]);
return str;
/* Funkce pro extrakci jména Bluetooth zařízení z Extended Inquiry Response (EIR) dat, která jsou obdržena během procesu vyhledávání */
static bool get_name_from_eir(uint8_t *eir, char *bdname, uint8_t *bdname_len)
uint8_t *rmt_bdname = NULL;
uint8_t rmt_bdname_len = 0;
if (!eir) {
return false;
rmt_bdname = esp_bt_gap_resolve_eir_data(eir, ESP_BT_EIR_TYPE_CMPL_LOCAL_NAME, &rmt_bdname_len);
if (!rmt_bdname) {
rmt_bdname = esp_bt_gap_resolve_eir_data(eir, ESP_BT_EIR_TYPE_SHORT_LOCAL_NAME, &rmt_bdname_len);
if (rmt_bdname) {
if (rmt_bdname_len > ESP_BT_GAP_MAX_BDNAME_LEN) {
rmt_bdname_len = ESP_BT_GAP_MAX_BDNAME_LEN;
if (bdname) {
memcpy(bdname, rmt_bdname, rmt_bdname_len);
bdname[rmt_bdname_len] = '\0';
if (bdname_len) {
*bdname_len = rmt_bdname_len;
return true;
return false;
// Zapnutí DATA_LED na daném pinu (1) nebo vypnutí (0)
void toggle_data_led(bool state_data_led) {
gpio_set_level(LED_DATA_PIN, state_data_led ? 1 : 0);
// Prototypy funkcí pro BT_LED
void toggle_led_bt(bool state_bt_led);
void blink_timer_callback(TimerHandle_t xTimer);
// Funkce pro blikání BT_LED
void blink_timer_callback(TimerHandle_t xTimer) {
if (!is_connected) {
// Přepínání stavu LED
static bool led_state = false;
toggle_led_bt(led_state);
led_state = !led_state;
// Upravená funkce pro zapnutí/vypnutí BT_LED
void toggle_led_bt(bool state_bt_led) {
gpio_set_level(LED_BT_PIN, state_bt_led ? 1 : 0);
// Inicializace LED
static void init_led(void) {
gpio_reset_pin(LED_DATA_PIN);
gpio_set_direction(LED_DATA_PIN, GPIO_MODE_OUTPUT);
ESP_LOGI(SPP_TAG, "Init DATA LED completed");
gpio_reset_pin(LED_BT_PIN);
gpio_set_direction(LED_BT_PIN, GPIO_MODE_OUTPUT);
ESP_LOGI(SPP_TAG, "Init BT LED completed");
// Funkce pro pokus o opětovné připojení
void reconnect_timer_callback(TimerHandle_t xTimer) {
// Pokus o opětovné připojení
if (!is_connected)
esp_spp_start_discovery(peer_bd_addr);
static void esp_spp_cb(esp_spp_cb_event_t event, esp_spp_cb_param_t *param)
uint8_t i = 0;
char bda_str[18] = {0};
switch (event) {
case ESP_SPP_INIT_EVT:
if (param->init.status == ESP_SPP_SUCCESS) {
ESP_LOGI(SPP_TAG, "ESP_SPP_INIT_EVT");
esp_bt_dev_set_device_name(EXAMPLE_DEVICE_NAME);
esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE);
esp_bt_gap_start_discovery(inq_mode, inq_len, inq_num_rsps);
ESP_LOGE(SPP_TAG, "ESP_SPP_INIT_EVT status:%d", param->init.status);
case ESP_SPP_DISCOVERY_COMP_EVT:
if (param->disc_comp.status == ESP_SPP_SUCCESS) { // Bylo vyhledávání zařízení úspěšné ?
ESP_LOGI(SPP_TAG, "ESP_SPP_DISCOVERY_COMP_EVT scn_num:%d", param->disc_comp.scn_num); // Logování počtu nalezených služeb
for (i = 0; i < param->disc_comp.scn_num; i++) { // Cyklus prochází všechny nalezené služby, loguje jejich SCN a jméno služby
ESP_LOGI(SPP_TAG, "-- [%d] scn:%d service_name:%s", i, param->disc_comp.scn[i],
param->disc_comp.service_name[i]);
/* We only connect to the first found server on the remote SPP acceptor here */
esp_spp_connect(sec_mask, role_master, param->disc_comp.scn[0], peer_bd_addr); // Pokus o navázání spojení s prvním nalezeným serverem
ESP_LOGE(SPP_TAG, "ESP_SPP_DISCOVERY_COMP_EVT status=%d", param->disc_comp.status); // Pokud pokus o spojení selže, loguje se chyba
// Pokud není zařízení připojeno, restartovat proces vyhledávání
case ESP_SPP_OPEN_EVT:
if (param->open.status == ESP_SPP_SUCCESS) {
ESP_LOGI(SPP_TAG, "ESP_SPP_OPEN_EVT handle:%"PRIu32" rem_bda:[%s]", param->open.handle,
bda2str(param->open.rem_bda, bda_str, sizeof(bda_str)));
// Když je spojení navázáno
is_connected = true;
toggle_led_bt(true); // Trvale zapnout LED
xTimerStop(blink_timer, 0); // Zastavit blikání
/* Start to write the first data packet */
//DEL ESP_LOGI(SPP_TAG, "*****************************Sent first data: SESP_SPP_OPEN_EVT**********************************************************");
//DEL esp_log_buffer_hex(SPP_TAG, spp_data, SPP_DATA_LEN);
//DEL esp_spp_write(param->open.handle, SPP_DATA_LEN, spp_data);
//DEL s_p_data = spp_data;
//DEL gettimeofday(&time_old, NULL);
//DEL ESP_LOGI(SPP_TAG, "*************************************************************************************************************************");
// Odeslání textové zprávy "Ahoj tady MASTER"
const char *message = "Ahoj tady MASTER";
esp_spp_write(param->open.handle, strlen(message), (uint8_t *)message);
ESP_LOGE(SPP_TAG, "ESP_SPP_OPEN_EVT status:%d", param->open.status);
case ESP_SPP_CLOSE_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_CLOSE_EVT status:%d handle:%"PRIu32" close_by_remote:%d", param->close.status,
param->close.handle, param->close.async);
// Když je spojení ukončeno
xTimerStart(blink_timer, 0); // Začít blikat
xTimerStart(reconnect_timer, 0); // Spustit timer pro opětovné připojení
case ESP_SPP_START_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_START_EVT");
case ESP_SPP_CL_INIT_EVT:
if (param->cl_init.status == ESP_SPP_SUCCESS) {
ESP_LOGI(SPP_TAG, "ESP_SPP_CL_INIT_EVT handle:%"PRIu32" sec_id:%d", param->cl_init.handle, param->cl_init.sec_id);
ESP_LOGE(SPP_TAG, "ESP_SPP_CL_INIT_EVT status:%d", param->cl_init.status);
case ESP_SPP_DATA_IND_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_DATA_IND_EVT");
* We only show the data in which the data length is less than 128 here. If you want to print the data and
* the data rate is high, it is strongly recommended to process them in other lower priority application task
* rather than in this callback directly. Since the printing takes too much time, it may stuck the Bluetooth
* stack and also have a effect on the throughput!
if (param->data_ind.len > 0) { // From S
// Pokud byla přijata nějaká data, rozsvítí se LED // From S
toggle_data_led(true); // From S
ESP_LOGI(SPP_TAG, "DATA LED ON"); // From S
toggle_data_led(false); // From S
ESP_LOGI(SPP_TAG, "************************************Received data START***************************************************");
// Vypisuje data v HEX
esp_log_buffer_hex("Received data (HEX): ", param->data_ind.data, param->data_ind.len);
// Vypisuje data v textové podobě
char received_text[param->data_ind.len + 1];
memcpy(received_text, param->data_ind.data, param->data_ind.len);
received_text[param->data_ind.len] = '\0'; // Přidání nulového ukončovacího znaku
ESP_LOGI(SPP_TAG, "Received data (TEXT): %s", received_text);
ESP_LOGI(SPP_TAG, "************************************Received data END*****************************************************");
} else { // From S
// Pokud nebyla přijata žádná data, LED se zhasne // From S
ESP_LOGI(SPP_TAG, "DATA LED OFF"); // From S
} // From S
// From S
//DEL ESP_LOGI(SPP_TAG, "ESP_SPP_DATA_IND_EVT len:%d handle:%d", // From S
//DEL param->data_ind.len, param->data_ind.handle); // From S
//DEL if (param->data_ind.len < 128) { // From S
//DEL ESP_LOGI(SPP_TAG, "************************************Received data START***************************************************");
//DEL esp_log_buffer_hex("Received data: ", param->data_ind.data, param->data_ind.len); // Vypisuje data v HEX
//DEL // ESP_LOGI(SPP_TAG, "Received data: %.*s", param->data_ind.len, (char *)param->data_ind.data); // Vypisuje data v ASCII napři při použítí s Serial BT Terminalem na mobilu
//DEL ESP_LOGI(SPP_TAG, "************************************Received data END*****************************************************"); // Vypisuje data v ASCII napři při použítí s Serial BT Terminalem na mobilu
//DEL } // From S
case ESP_SPP_WRITE_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_WRITE_EVT");
//DEL if (param->write.status == ESP_SPP_SUCCESS) {
//DEL if (s_p_data + param->write.len == spp_data + SPP_DATA_LEN) {
//DEL /* Means the previous data packet be sent completely, send a new data packet */
//DEL } else {
//DEL /*
//DEL * Means the previous data packet only be sent partially due to the lower layer congestion, resend the
//DEL * remainning data.
//DEL */
//DEL s_p_data += param->write.len;
//DEL }
//DEL /*
//DEL * We only show the data in which the data length is less than 128 here. If you want to print the data and
//DEL * the data rate is high, it is strongly recommended to process them in other lower priority application task
//DEL * rather than in this callback directly. Since the printing takes too much time, it may stuck the Bluetooth
//DEL * stack and also have a effect on the throughput!
//DEL */
//DEL ESP_LOGI(SPP_TAG, "ESP_SPP_WRITE_EVT len:%d handle:%d cong:%d", param->write.len, param->write.handle,
//DEL param->write.cong);
//DEL if (param->write.len < 128) {
//DEL // esp_log_buffer_hex("", spp_data, param->write.len); // původní vyýpis dat k odeslání
//DEL /* Delay a little to avoid the task watch dog */
//DEL vTaskDelay(pdMS_TO_TICKS(10));
//DEL }
//DEL } else {
//DEL /* Means the prevous data packet is not sent at all, need to send the whole data packet again. */
//DEL ESP_LOGE(SPP_TAG, "ESP_SPP_WRITE_EVT status:%d", param->write.status);
//DEL }
//DEL if (!param->write.cong) {
//DEL /* The lower layer is not congested, you can send the next data packet now. */
//DEL ESP_LOGI(SPP_TAG, "*****************************Sent Next data packet: ESP_SPP_WRITE_EVT**********************************************************");
//DEL esp_spp_write(param->write.handle, spp_data + SPP_DATA_LEN - s_p_data, s_p_data);
//DEL ESP_LOGI(SPP_TAG, "*******************************************************************************************************************************");
//DEL } else {
//DEL /*
//DEL * The lower layer is congested now, don't send the next data packet until receiving the
//DEL * ESP_SPP_CONG_EVT with param->cong.cong == 0.
//DEL */
//DEL ;
//DEL }
//DEL
//DEL /*
//DEL * If you don't want to manage this complicated process, we also provide the SPP VFS mode that hides the
//DEL * implementation details. However, it is less efficient and will block the caller until all data has been sent.
//DEL */
case ESP_SPP_CONG_EVT:
//DEL ESP_LOGI(SPP_TAG, "ESP_SPP_CONG_EVT cong:%d", param->cong.cong);
//DEL if (param->cong.cong == 0) {
//DEL /* Send the privous (partial) data packet or the next data packet. */
//DEL ESP_LOGI(SPP_TAG, "*****************************Sent Previous partial data: ESP_SPP_WRITE_EVT**********************************************************");
//DEL ESP_LOGI(SPP_TAG, "************************************************************************************************************************************");
//DEL }
case ESP_SPP_SRV_OPEN_EVT:
case ESP_SPP_UNINIT_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_UNINIT_EVT");
default:
static void esp_bt_gap_cb(esp_bt_gap_cb_event_t event, esp_bt_gap_cb_param_t *param)
switch(event){
case ESP_BT_GAP_DISC_RES_EVT:
ESP_LOGI(SPP_TAG, "ESP_BT_GAP_DISC_RES_EVT");
esp_log_buffer_hex(SPP_TAG, param->disc_res.bda, ESP_BD_ADDR_LEN);
/* Find the target peer device name in the EIR data */
for (int i = 0; i < param->disc_res.num_prop; i++){
if (param->disc_res.prop[i].type == ESP_BT_GAP_DEV_PROP_EIR
&& get_name_from_eir(param->disc_res.prop[i].val, peer_bdname, &peer_bdname_len)){
esp_log_buffer_char(SPP_TAG, peer_bdname, peer_bdname_len);
// Print the peer device name
ESP_LOGI(SPP_TAG, "Peer device name: %.*s", peer_bdname_len, peer_bdname);
if (strlen(remote_device_name) == peer_bdname_len
&& strncmp(peer_bdname, remote_device_name, peer_bdname_len) == 0) {
memcpy(peer_bd_addr, param->disc_res.bda, ESP_BD_ADDR_LEN);
/* Have found the target peer device, cancel the previous GAP discover procedure. And go on
* dsicovering the SPP service on the peer device */
esp_bt_gap_cancel_discovery();
case ESP_BT_GAP_DISC_STATE_CHANGED_EVT:
ESP_LOGI(SPP_TAG, "ESP_BT_GAP_DISC_STATE_CHANGED_EVT");
case ESP_BT_GAP_RMT_SRVCS_EVT:
ESP_LOGI(SPP_TAG, "ESP_BT_GAP_RMT_SRVCS_EVT");
case ESP_BT_GAP_RMT_SRVC_REC_EVT:
ESP_LOGI(SPP_TAG, "ESP_BT_GAP_RMT_SRVC_REC_EVT");
default:
void app_main(void)
init_led(); // inicializace LED diod
esp_err_t ret = ESP_OK;
//DEL // Generování dat k odeslání
//DEL for (int i = 0; i < SPP_DATA_LEN; ++i) {
//DEL spp_data[i] = i;
//DEL }
ret = nvs_flash_init();
ESP_ERROR_CHECK( ret );
ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_BLE));
esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
if ((ret = esp_bt_controller_init(&bt_cfg)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s initialize controller failed: %s\n", __func__, esp_err_to_name(ret));
return;
if ((ret = esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s enable controller failed: %s\n", __func__, esp_err_to_name(ret));
return;
if ((ret = esp_bluedroid_init()) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s initialize bluedroid failed: %s\n", __func__, esp_err_to_name(ret));
return;
if ((ret = esp_bluedroid_enable()) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s enable bluedroid failed: %s\n", __func__, esp_err_to_name(ret));
return;
if ((ret = esp_bt_gap_register_callback(esp_bt_gap_cb)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s gap register failed: %s\n", __func__, esp_err_to_name(ret));
return;
#if (CONFIG_BT_SSP_ENABLED == true)
/* Set default parameters for Secure Simple Pairing */
esp_bt_sp_param_t param_type = ESP_BT_SP_IOCAP_MODE;
esp_bt_io_cap_t iocap = ESP_BT_IO_CAP_NONE; // ESP_BT_IO_CAP_NONE bez možnosti vstupu a zadání PIN (původní hodnota byla ESP_BT_IO_CAP_IO a vyžadovala PIN)
esp_bt_gap_set_security_param(param_type, &iocap, sizeof(uint8_t));
#endif
if ((ret = esp_spp_register_callback(esp_spp_cb)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s spp register failed: %s\n", __func__, esp_err_to_name(ret));
return;
esp_spp_cfg_t bt_spp_cfg = {
.mode = esp_spp_mode,
.enable_l2cap_ertm = esp_spp_enable_l2cap_ertm,
.tx_buffer_size = 0, /* Only used for ESP_SPP_MODE_VFS mode */
if ((ret = esp_spp_enhanced_init(&bt_spp_cfg)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s spp init failed: %s\n", __func__, esp_err_to_name(ret));
return;
ESP_LOGI(SPP_TAG, "Own address:[%s]", bda2str((uint8_t *)esp_bt_dev_get_address(), bda_str, sizeof(bda_str)));
// Inicializace timeru pro blikání
blink_timer = xTimerCreate("BlinkTimer", pdMS_TO_TICKS(250), pdTRUE, (void *)0, blink_timer_callback); // pdMS_TO_TICKS(250) nastavuje rychlost blikání v ms
xTimerStart(blink_timer, 0); // Spustit blikání hned na začátku
// Inicializace timeru pro opětovné připojení
reconnect_timer = xTimerCreate("ReconnectTimer", pdMS_TO_TICKS(10000), pdFALSE, (void *)0, reconnect_timer_callback);
}Code: Select all
#include <stdint.h>
#include <string.h>
#include <stdio.h>
#include "nvs.h"
#include "esp_bt.h"
#include "time.h"
#define SPP_TAG "SPP_ACCEPTOR_DEMO"
#define SPP_SERVER_NAME "SPP_SERVER"
#define BT_DEVICE_NAME "ESP_SPP_ACCEPTOR" // Jmeńo pro párování, k zařízení s tímto jménem se bude chtít připojit INITIATOR
static const esp_spp_role_t role_slave = ESP_SPP_ROLE_SLAVE;
#define SPP_DATA_LEN 80 // From M // Délka odesílaných dat
static uint8_t spp_data[SPP_DATA_LEN]; // From M
static uint8_t *s_p_data = NULL; // From M /* data pointer of spp_data */
// Inicializace LED
switch (event) {
esp_spp_start_srv(sec_mask, role_slave, 0, SPP_SERVER_NAME);
ESP_LOGI(SPP_TAG, "ESP_SPP_DISCOVERY_COMP_EVT");
ESP_LOGI(SPP_TAG, "ESP_SPP_OPEN_EVT");
//DEL if (param->open.status == ESP_SPP_SUCCESS) {
//DEL /* Start to write the first data packet */ // From M
//DEL esp_spp_write(param->open.handle, SPP_DATA_LEN, spp_data); // From M
//DEL s_p_data = spp_data; // From M
//DEL gettimeofday(&time_old, NULL); // From M
//DEL } else { // From M
//DEL ESP_LOGE(SPP_TAG, "ESP_SPP_OPEN_EVT status:%d", param->open.status); // From M
//DEL } // From M
if (param->start.status == ESP_SPP_SUCCESS) {
ESP_LOGI(SPP_TAG, "ESP_SPP_START_EVT handle:%"PRIu32" sec_id:%d scn:%d", param->start.handle, param->start.sec_id,
param->start.scn);
esp_bt_dev_set_device_name(BT_DEVICE_NAME);
ESP_LOGE(SPP_TAG, "ESP_SPP_START_EVT status:%d", param->start.status);
ESP_LOGI(SPP_TAG, "ESP_SPP_CL_INIT_EVT");
//DEL
//DEL esp_log_buffer_hex("Received data: HEX: ", param->data_ind.data, param->data_ind.len); // Vypisuje data v HEX
//DEL }
//DEL if (param->write.status == ESP_SPP_SUCCESS) { // From M
//DEL if (s_p_data + param->write.len == spp_data + SPP_DATA_LEN) { // From M
//DEL /* Means the previous data packet be sent completely, send a new data packet */ // From M
//DEL /*
//DEL */
//DEL s_p_data += param->write.len; // From M
//DEL } // From M
//DEL
//DEL /*
//DEL */
//DEL ESP_LOGI(SPP_TAG, "ESP_SPP_WRITE_EVT len:%d handle:%d cong:%d", param->write.len, param->write.handle, // From M
//DEL param->write.cong); // From M
//DEL if (param->write.len < 128) { // From M
//DEL // esp_log_buffer_hex("", spp_data, param->write.len); // původní vyýpis dat k odeslání // From M
//DEL /* Delay a little to avoid the task watch dog */ // From M
//DEL vTaskDelay(pdMS_TO_TICKS(10)); // From M
//DEL } // From M
//DEL // From M
//DEL ESP_LOGE(SPP_TAG, "ESP_SPP_WRITE_EVT status:%d", param->write.status); // From M
//DEL } // From M
//DEL // From M
//DEL if (!param->write.cong) { // From M
//DEL /* The lower layer is not congested, you can send the next data packet now. */ // From M
//DEL esp_spp_write(param->write.handle, spp_data + SPP_DATA_LEN - s_p_data, s_p_data); // From M
//DEL /* // From M
//DEL */
//DEL ; // From M
//DEL } // From M
// From M
//DEL /*
//DEL */ // From M
case ESP_SPP_CONG_EVT: // From M
//DEL ESP_LOGI(SPP_TAG, "ESP_SPP_CONG_EVT"); // From M
//DEL ESP_LOGI(SPP_TAG, "ESP_SPP_CONG_EVT cong:%d", param->cong.cong); // From M
//DEL if (param->cong.cong == 0) { // From M
//DEL /* Send the privous (partial) data packet or the next data packet. */ // From M
//DEL } // From M
ESP_LOGI(SPP_TAG, "ESP_SPP_SRV_OPEN_EVT");
// Vypsání adresy vzdáleného zařízení
ESP_LOGI(SPP_TAG, "Remote device address: %02x:%02x:%02x:%02x:%02x:%02x",
param->srv_open.rem_bda[0], param->srv_open.rem_bda[1], param->srv_open.rem_bda[2],
param->srv_open.rem_bda[3], param->srv_open.rem_bda[4], param->srv_open.rem_bda[5]);
// Odeslání textové zprávy "Ahoj tady SLAVE"
const char *message = "Ahoj tady SLAVE";
//DEL ESP_LOGI(SPP_TAG, "*****************************Sent first data: SESP_SPP_SRV_OPEN_EVT**********************************************************");
//DEL // ESP_LOGI(SPP_TAG, "Data k odeslání: %.*s", SPP_DATA_LEN, (char *)spp_data);
//DEL ESP_LOGI(SPP_TAG, "*****************************************************************************************************************************");
case ESP_SPP_SRV_STOP_EVT:
ESP_LOGI(SPP_TAG, "ESP_SPP_SRV_STOP_EVT");
default:
void app_main(void)
//DEL }
ESP_ERROR_CHECK( ret ); // Ověření, zda předchozí volání funkce bylo úspašné
ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_BLE)); // Uvolnění paměti přidělené pro Bluetooth Low Energy (BLE)
return;
return;
return;
return;
return;
return;
#endif
