Greetings -
Im looking into creating an remote controlled ESP32, which should use WIFI.
The setup should be an windows PC with an PS3/PS4 controller connected to USB, The ESP32 and the PC will be connected to the same WIFI.
How should I setup the link between the pc/controller/esp32?
should i host an windows form application, that the esp32 should connect to, or could the ESP32 host something?
Anyone worked with anything near this / have an example i could read up on?
best regards Martin
Using joystick to control ESP32 (Ps4/ps3 controller) - what WIFI setup?
Martin1454
Re: Using joystick to control ESP32 (Ps4/ps3 controller) - what WIFI setup?
I would first try something simple like UDP.
