Alternatively, is there a recommended extension for VSCode that will handle these Esc character sequences?
Thanks for that - I'm still see-sawing between using the VSCode extension and the command line.. so I'll make a note of that just in caseTo get rid of the escape characters, as you said, you could use a color enabled terminal.
If you can't use a color enabled terminal, then, I believe the setting CONFIG_LOG_COLORS in sdkconfig should not be set.
At least, that god rid of them for me.
Users browsing this forum: Baidu [Spider], Bing [Bot], Bytespider, DuckDuckGo [Bot], PerplexityBot and 1 guest
