ESP32 ethernet API
zavovi
ESP32 ethernet API
Postby zavovi » Tue Nov 28, 2017 10:30 am
Hi all,
is it existing API for use ESP32 with only ethernet packets and connect/disconnect WiFi radio?
I mean, that I am using application with TCP/IP stack on the other microcontroller and communication via cable ethernet and I want connect ESP32 with my microcontroller and with my TCP/IP stack. Is it possible with any sample code? I think connection via UART or SPI, for example.
Thank you,
Vilem
