Unable to program ESP32-WROVER-E
joe_fang_iD
Postby joe_fang_iD » Tue Jan 09, 2024 1:53 am
I'm trying to program a custom ESP32-WROVER-E using a ESP-PROG, and I'm receiving this issue when programming:
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: Wrong boot mode detected (0x12)! The chip needs to be in download mode.
For troubleshooting steps visit: https://github.com/espressif/esptool#troubleshooting
CMake Error at run_serial_tool.cmake:56 (message):
  C:/Users/joe.fang/Desktop/esp-idf-44/python_env/idf4.4_py3.8_env/Scripts/python.exe
  C:/Espressif/frameworks/esp-idf-v4.4/components/esptool_py/esptool/esptool.py
  --chip esp32 failed
when I monitor the board, I receive:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fffeba4,len:4
load:0x4009f000,len:3248
entry 0x4009f574
�OHAI�ets Jul 29 2019 12:21:46
entry 0x4009f574
�OHAI�
Any suggestions would be greatly appreciated!
Re: Unable to program ESP32-WROVER-E
Postby Sprite » Tue Jan 09, 2024 9:29 am
Check your bootstrap pins. At the very least, GPIO0 should be low. Could be that you need to look at the ESP-PROG jumpers if that is connected to GPIO0.
Roland
Postby Roland » Tue Jan 09, 2024 10:34 am
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 8 guests
