Issue with ESP-NOW functionality when connecting to WebSocket server in Node.js
agoktugaydin
Postby agoktugaydin » Wed Jan 10, 2024 4:32 pm
Hello everyone,
I'm currently working on a project where I have a server written in Node.js that utilizes WebSocket functionality. However, when I connect my ESP32 device (running the Arduino code provided below) to this server, the ESP-NOW functionality stops working.
Code: Untitled.c Select all
#include <Arduino.h>
#include <Wire.h>
#include <WiFi.h>
#include <esp_now.h>
#include <WebSocketsClient.h>
#include <ArduinoJson.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <config.h>
IPAddress webSocketServer(WEBSOCKET_SERVER_IP1, WEBSOCKET_SERVER_IP2, WEBSOCKET_SERVER_IP3, WEBSOCKET_SERVER_IP4);
int webSocketPort = WEBSOCKET_SERVER_PORT;
const char * ssid = WIFI_SSID;
const char * password = WIFI_PASSWORD;
WebSocketsClient wsClient;
const int analogIn = A0;
int rawValue = 0;
double voltage = 0;
double rawSum = 0;
int limit = 2000;
int percentage = 0;
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
typedef struct struct_message {
int id;
int x;
int y;
struct_message;
struct_message myData;
struct_message board1;
struct_message boardsStruct[1] = {
board1
void OnDataRecv(const uint8_t * mac_addr,
const uint8_t * incomingData, int len) {
char macStr[18];
Serial.print("Packet received from: ");
snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
Serial.println(macStr);
memcpy( & myData, incomingData, sizeof(myData));
Serial.printf("Board ID %u: %u bytes\n", myData.id, len);
boardsStruct[myData.id - 1].x = myData.x;
boardsStruct[myData.id - 1].y = myData.y;
Serial.printf("x value: %d \n", boardsStruct[myData.id - 1].x);
Serial.printf("y value: %d \n", boardsStruct[myData.id - 1].y);
Serial.println("Data received from ESP-NOW");
void displayValues() {
rawSum = analogRead(analogIn);
for (int i = 0; i < 500; i++) {
rawSum += analogRead(analogIn);
rawValue = rawSum / 500;
voltage = (rawValue / 4096.0) * 3300;
percentage = map(rawValue, 1400, 4096, 0, 100);
display.setTextColor(WHITE);
display.setTextSize(1);
display.setCursor(0, 0);
if (rawValue < limit) {
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(18, LOW);
display.print("NORMAL");
display.setCursor(0, 10);
display.print("raw value:");
display.print(rawValue);
display.print("\n");
display.print("received value:");
display.print(boardsStruct[0].x);
display.print("Percentage: ");
display.print(percentage);
display.print("%");
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(18, HIGH);
display.print("LEAK");
display.print("%");
display.display();
delay(300);
display.clearDisplay();
void sendData() {
StaticJsonDocument < 200 > jsonData;
jsonData["deviceId"] = "3bf76280-6ca9-4d83-9ffb-db112de00c24";
jsonData["gasIntensity"] = percentage;
jsonData["zone"] = "43C72";
String serializedData;
serializeJson(jsonData, serializedData);
wsClient.sendTXT(serializedData);
Serial.println(serializedData);
void wsEvent(WStype_t type, uint8_t * payload, size_t length) {
if (type == WStype_DISCONNECTED) {
Serial.println("Disconnected from WebSocket server.");
} else if (type == WStype_CONNECTED) {
Serial.println("Connected to WebSocket server.");
} else if (type == WStype_TEXT) {
Serial.println("Received data from WebSocket server:");
Serial.println((char * ) payload);
pinMode(LED_BUILTIN, OUTPUT);
pinMode(18, OUTPUT);
Wire.begin();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
WiFi.mode(WIFI_AP_STA);
WiFi.begin(ssid, password);
delay(1000);
Serial.println("Connecting to WiFi...");
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
esp_now_register_recv_cb(OnDataRecv);
delay(300);
wsClient.begin(webSocketServer, webSocketPort);
wsClient.onEvent(wsEvent);
Serial.println("WebSocket client started...");
displayValues();
delay(300);
wsClient.loop();
static unsigned long lastSent = 0;
unsigned long now = millis();
if (wsClient.isConnected() && now - lastSent >= 2000) {
sendData();
Problem:
The ESP32 device is designed to communicate using ESP-NOW, which works perfectly when not connected to the WebSocket server.
Upon connecting to the WebSocket server using the WebSocketsClient library, the ESP-NOW functionality seems to cease, and no data is received through ESP-NOW.
Expected Behavior:
The ESP-NOW functionality should continue to work seamlessly even when the WebSocket connection is established.
Additional Information:
The WebSocket server is implemented in Node.js.
The WebSocket library used on the ESP32 side is WebSocketsClient
The ESP-NOW functionality is used for communication between multiple ESP32 devices.
Possible Causes:
The WebSocket library may be interfering with ESP-NOW operations.
Attempts to Resolve:
I have checked for any conflicts in network configurations.
I've tried adjusting the order of initialization for ESP-NOW and WebSocket.
I appreciate any insights or suggestions on how to troubleshoot and resolve this issue. If you need additional details, feel free to ask.
Thank you in advance!
Users browsing this forum: Amazon [Bot] and 1 guest
