I am programming ESP32-WROOM-32D with Arduino IDE. In this website (https://docs.espressif.com/projects/esp ... %2D%2027).), it says that the ADC2 module can only be used when WiFi driver is not activated.
In my case, I try to use the BluetoothSerial library (the commands start with SerialBT) together with the ADC2 module, and I found that ADC2 GPIOs seem to be not working. Therefore, I would like to ask if the BluetoothSerial library is also using the WiFi driver which leads to the problem.
I also read from this website (https://docs.espressif.com/projects/esp ... hannel_tPi) that the adc_oneshot_read() is thread safe and can be used with WiFi. Is my understanding correct? It would be great if anyone can provide some experiences.
Thank you very much for any information.
ESP32: can BluetoothSerial be used with ADC2 module?
Re: ESP32: can BluetoothSerial be used with ADC2 module?
I think you'll find your answer here: https://esp32.com/viewtopic.php?t=20057
lbernstone
Short answer is no. The radio uses the ADC2 exclusively.
Thank you very much for pointing me to the post.I think you'll find your answer here: https://esp32.com/viewtopic.php?t=20057
Thank you for your information. By using the word "radio," are you referring to both Bluetooth and WiFi?Short answer is no. The radio uses the ADC2 exclusively.
And do you have any idea if adc_oneshot_read() will work for ADC2 when Bluetooth is on?
lbernstone
yes
no
tl;dr Don't do this. Use ADC1 for analog reads.
no
Thank you very much for your help.yes
no
Users browsing this forum: Applebot and 2 guests
