I'm trying to connect to a wifi network with my ESP32 devKitC. I can connect when I use macros as ssid and password, however when I try with variables it fails even if the byte sequence is the same.
With macros
void wifi_connect()
int i;
if(NULL == self)
ERROR("Wifi was not created");
else
ESP_ERROR_CHECK(esp_event_loop_init(esp32_wifi_eventHandler, NULL));
nvs_flash_init();
tcpip_adapter_init();
wifi_init_config_t wifiConfig = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&wifiConfig));
ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
wifi_config_t sta_config = {
.sta =
.ssid = AP_SSID,
.password = AP_PWD,
.bssid_set = 0
printf("SSID : ");
for(i=0; i<32; i++)
printf("%x ", sta_config.sta.ssid[i]);
printf("\n");
printf("PWD : ");
for(i=0; i<64; i++)
printf("%x ", sta_config.sta.password[i]);
printf("\n");
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &sta_config));
ESP_ERROR_CHECK(esp_wifi_start());
ESP_ERROR_CHECK(esp_wifi_connect());
I (1019) wifi: wifi firmware version: 8a1ad86
I (1019) wifi: config NVS flash: enabled
I (1019) wifi: config nano formating: disabled
I (1024) wifi: Init dynamic tx buffer num: 32
I (1025) wifi: Init dynamic rx buffer num: 32
I (1029) wifi: wifi driver task: 3ffbc9f8, prio:23, stack:4096
I (1034) wifi: Init static rx buffer num: 10
I (1038) wifi: Init dynamic rx buffer num: 32
I (1042) wifi: Init rx ampdu len mblock:7
I (1046) wifi: Init lldesc rx ampdu entry mblock:4
I (1050) wifi: wifi power manager task: 0x3ffc1dd0 prio: 21 stack: 2560
SSID : 56 56 56 5f 52 4e 4e 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
PWD : 78 4e 12 24 37 4e 51 62 5f 72 42 71 2a 33 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
I (1077) wifi: wifi timer task: 3ffc2e60, prio:22, stack:3584
I (1097) wifi: mode : sta (24:0a:c4:05:71:88)
I (1220) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
I (1877) wifi: state: init -> auth (b0)
I (1881) wifi: state: auth -> assoc (0)
I (1886) wifi: state: assoc -> run (10)
I (1905) wifi: connected with VVV_RNN, channel 1
[INFO] Connected to VVV_RNN
IP: 192.168.128.105
Netmask: 255.255.255.0
Gateway: 192.168.128.254
[INFO] PASSED
void wifi_connect()
int ssid_length = strlen(self->ssid);
int password_length = strlen(self->password);
int i;
if(NULL == self)
else
nvs_flash_init();
wifi_config_t sta_config;
memcpy(sta_config.sta.ssid, self->ssid, ssid_length);
memcpy(sta_config.sta.password, self->password, password_length);
for(i=ssid_length; i<32; i++)
sta_config.sta.ssid[i] = '\0';
for(i=password_length; i<64; i++)
sta_config.sta.password[i] = '\0';
printf("SSID : ");
for(i=0; i<32; i++)
printf("\n");
printf("PWD : ");
for(i=0; i<64; i++)
printf("\n");
I (1125) wifi: mode : sta (24:0a:c4:05:71:88)
I'm using the following structure as my wifi "object" and the wifi_isConnected function to check if the connection is ok.
The wifi handler is also presented here.
typedef struct
char* ssid;
char* password;
ip4_addr_t net_ip;
ip4_addr_t net_gw;
ip4_addr_t net_msk;
bool isConnected;
}wifi_t;
bool wifi_isConnected()
int ret;
if(NULL == self)
ret = false;
else
ret = self->isConnected;
return ret;
esp_err_t esp32_wifi_eventHandler(void *ctx, system_event_t *event)
if (event->event_id == SYSTEM_EVENT_STA_GOT_IP)
self->net_ip = event->event_info.got_ip.ip_info.ip;
self->net_gw = event->event_info.got_ip.ip_info.gw;
self->net_msk = event->event_info.got_ip.ip_info.netmask;
self->isConnected = true;
INFO("Connected to %s", self->ssid);
printf("\tIP: %s\n", inet_ntoa(self->net_ip));
printf("\tNetmask: %s\n", inet_ntoa(self->net_msk));
printf("\tGateway: %s\n\n", inet_ntoa(self->net_gw));
return ESP_OK;
void app_main(void)
wifi_t* wifiConnection = NULL;
wifi_constructor(wifiConnection, <ssid>, <password>);
wifi_connect();
while(!wifi_isConnected())
INFO("PASSED");
}I'm certainly missing something but I can't found out what is it
Thanks in advance
