Problems with provisioned chip and esp-matter
AnonTheEngenius
Postby AnonTheEngenius » Tue Jan 16, 2024 11:02 am
Chip: ESP32-C3
ESP-IDF in VSCode + ESP-Matter
Hi, i have code that hosts a webpage on a network in STA mode (esp is client in network hosting a webpage). On this webpage there is a button that if pushed is supposed to turn matter on and make the device discoverable and and controllable through matter while keeping the input possibility from the hosted webpage. Now currently there are two tasks running. One with the webpage stuff with idlestatus priority and another one that starts the matter part that has priority idle + 1.
When i start matter, i get the below added logs. With the chip tool i tried to connect to the esp with onnetwork pairing but it seems the device is not even found (nodeid and passcode are guaranteed right). When using amazon alexa to discover the device, the device is found but Alexa tells me to enter wifi creds in a loop while never fully connecting. (2nd logs).
Maybe someone here has an idea what exactly is going wrong or what i can change. The matter code is 99% based on the light example from esp-matter.
Code: 1.rtf Select all
Code: 2.rtf Select all
2.rtf
(37.22 KiB) Downloaded 439 times
1.rtf
(6.97 KiB) Downloaded 394 times
Users browsing this forum: ChatGPT-User, Qwantbot and 1 guest
