I'm looking for a lowest battery consumption, and the battery size not very heavy.
With ESP32-CAM in deep sleep mode I have 4mA current draw. The battery capacity is 1500mA. This configuration will run maximum 15 days.
Now I tested a PIR sensor SR-602. It takes only 1uA or 0.001mA! The lowest battery consumption I have ever seen. Only this sensor will work about 62500 days from 1500mA battery.
Now the wanted scenario: In the idle time, only PIR sensor is powered on. It waits for the event. When the PIR sensor triggers, it powers on the ESP32-CAM. ESP32-CAM takes a picture, save it on the memory card and cut off the power so only the PIR sensor remains active. I need a external circuit to do this.
The SR-602 sensor output signal is 3.3v for only about 2.4 seconds (not modifiable). If I use a transistor like a switch, the ESP32-CAM will be powered on for only 2.4 seconds. How to increase this time? Even when the PIR signal will fall from high to low, I need to maintain the ESP board powered on to finish the task, then cut off the power.
Any ideas will be apreciated
ESP32-CAM and PIR sensor
Re: ESP32-CAM and PIR sensor
You probably want some kind of latching circuit (like an S-R flipflop) where the PIR turns the ESP-CAM on and a GPIO on the ESP-CAM can turn it off.
Wow! This is the circuit I'm looking for. I will try it.
Thank you very much
Thank you very much
I found using 2n7000 n-channel mosfets instead of the npn BJTs works better. You can get 100 2n7000 for less than $8 on Amazon.
Users browsing this forum: Bing [Bot], Bytespider and 2 guests
