call xTimerStop() too often cause "assert failed: prvProcessReceivedCommands timers.c:858 (xResult)" error and restart
policeman0077
Postby policeman0077 » Tue Jan 30, 2024 5:44 pm
We have several robots have wonky limit switches which always pull high. So I put some code that when the robot move away from the end stop(limit switch from triggered state to release), I start a timer and wait for the release of the switch(interrupt). If robot detects the release(interrupt), it stop the timer. I tested the code and it works fine.
But one day, I found another robot has a limit switch toggling the high/low frequently and it restart itself. With some digging I found if xTimerStop() is being called too often too fast would "assert failed: prvProcessReceivedCommands timers.c:858 (xResult)" error.
Backtrace: 0x40081b4e:0x3ffbb5f0 0x40088cd9:0x3ffbb610 0x4008f52d:0x3ffbb630 0x4008be9a:0x3ffbb750
0x40081b4e: panic_abort at C:/Users/Sam/esp/esp-idf/components/esp_system/panic.c:408
0x40088cd9: esp_system_abort at C:/Users/Sam/esp/esp-idf/components/esp_system/esp_system.c:137
0x4008f52d: __assert_func at C:/Users/Sam/esp/esp-idf/components/newlib/assert.c:85
0x4008be9a: prvProcessReceivedCommands at C:/Users/Sam/esp/esp-idf/components/freertos/timers.c:858
 (inlined by) prvTimerTask at C:/Users/Sam/esp/esp-idf/components/freertos/timers.c:600
My code look likes this:
main code start the robot from the end stop
void robot_start()
	xTimerStart( xTimerSenChk, 0 );//Set a timer and wait for sensor interrupt from other direction
        starMotor(CLEANING_DUTY);
interrupt handler send an event through the event queue
static void IRAM_ATTR gpio_isr_handler(void* arg)
    uint32_t gpio_num = (uint32_t) arg;
    sensorTriggerTime=xTaskGetTickCountFromISR();
    xQueueSendFromISR(gpio_evt_queue, &gpio_num, NULL);
task for receiving event queue and clear timer.
static void gpio_task_example(void* arg)
    uint32_t io_num;
    for(;;) {
        if(xQueueReceive(gpio_evt_queue, &io_num,  1000/ portTICK_PERIOD_MS)) { //portMAX_DELAY
            ESP_LOGD(TAG,"GPIO[%d] intr, val: %d\n", io_num, gpio_get_level(io_num));
            leftSensorStatus = gpio_get_level(GPIO_LEFT_SENSOR);
            rightSensorStatus = gpio_get_level(GPIO_RIGHT_SENSOR);
            ESP_LOGD(TAG,"leftSensorStatus: %d rightSensorStatus: %d", leftSensorStatus, rightSensorStatus);
            if(gpio_callback && ((sensorTriggerTime-LastSensorTriggerTime)*1000/configTICK_RATE_HZ>20)){
		    //code determine if it is the correct sensor released
		    //if it is the correct sensor we call xTimerStop() to stop the timer
		    //else timer callback we let us know the sensor is not released
		    if( correct sensor is released)
		    	xTimerStop();
            else
                ESP_LOGI(TAG, "sensor trigger interval <20ms, debouce.");
            LastSensorTriggerTime=sensorTriggerTime;
I thought it might not proper to call xTimerStop() if the timer is already stopped so I modified the code a bit and check the xTimer is dormant or not before by using xTimerIsTimerActive(). The code looks like this:
	if(xTimerIsTimerActive() != pdFALSE)//stop timer only when timer is active
		xTimerStop();
The problem seems gone after I did the modification. I also look the official document of xTimerStop() https://www.freertos.org/FreeRTOS-timer ... rStop.html It does not mention I could not call it if the timer is already stopped.
So what is the correct practice for it. Thank you in advance for any advice.
enviroment:
esp-idf 4.4.5
FreeRTOS Kernel V10.4.3
MicroController
Re: call xTimerStop() too often cause "assert failed: prvProcessReceivedCommands timers.c:858 (xResult)" error and resta
Postby MicroController » Tue Jan 30, 2024 11:26 pm
I also look the official document of xTimerStop(). It does not mention I could not call it if the timer is already stopped.
It does mention though that you actually don't control the timer directly; in fact, under the hood you send 'commands' to the timer task via a queue. If you do that too quickly the queue may not be processed fast enough and become full, which in your case causes the assertion failure.
You can look into using the IDF's High Resolution Timer which you can control more directly. You should also consider electrically debouncing the signal before it even enters the ESP where it may trigger a burst of interrupts before the switch settles.
policeman0077
Postby policeman0077 » Thu Feb 01, 2024 2:34 am
Thank you MicroController for your reply. I will have a look the xTimer queue and command.
The circuit has a rc filter and a schmitter trigger for debouncing and the firmware checks if two consecutive interrupts is within 20ms.
Users browsing this forum: Baidu [Spider], Qwantbot, Semrush [Bot] and 3 guests
