I've installed ESP-IDF on VSCode on macOS. However, installing the Matter extension results in the following problem which I cannot find a solution to anywhere. I have Python3.12 installed and pip etc.
> Executing task: source /Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/scripts/activate.sh <
WELCOME TO...
BOOTSTRAP! Bootstrap may take a few minutes; please be patient.
Downloading and installing packages into local source directory:
Setting up CIPD package manager...done (1.5s)
Setting up Project actions........skipped (0.1s)
Setting up Python environment.....[|]
ninja: Entering directory `/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out'
[1/576] python3 ../../third_party/pigweed/repo/pw_build/py/pw_build/python_runner.py --gn-root ../../ --current-path ../.. --default-toolchain=//build/toolchain/host:mac_arm64_gcc --current-toolchain=//third_party/pigweed/repo/pw_build/python_toolchain:python --capture-output --module piptools --python-virtualenv-config python/gen/matter_build_venv/venv_metadata.json --python-dep-list-files python/gen/matter_build_venv._compile_requirements_metadata_path_list.txt -- compile --resolver=backtracking --allow-unsafe --output-file python/gen/matter_build_venv/compiled_requirements.txt python/gen/matter_build_venv/generated_requirements.txt ../../scripts/setup/requirements.build.txt
FAILED: python/gen/matter_build_venv/compiled_requirements.txt
error: subprocess-exited-with-error
× Getting requirements to build wheel did not run successfully.
│ exit code: 1
╰─> [54 lines of output]
running egg_info
writing lib/PyYAML.egg-info/PKG-INFO
writing dependency_links to lib/PyYAML.egg-info/dependency_links.txt
writing top-level names to lib/PyYAML.egg-info/top_level.txt
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 118, in get_requires_for_build_wheel
return hook(config_settings)
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 325, in get_requires_for_build_wheel
return self._get_build_requires(config_settings, requirements=['wheel'])
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 295, in _get_build_requires
self.run_setup()
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/build_meta.py", line 311, in run_setup
exec(code, locals())
File "<string>", line 288, in <module>
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/__init__.py", line 103, in setup
return distutils.core.setup(**attrs)
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
self.run_command(cmd)
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/dist.py", line 963, in run_command
super().run_command(command)
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 321, in run
self.find_sources()
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 329, in find_sources
mm.run()
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 551, in run
self.add_defaults()
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/command/egg_info.py", line 589, in add_defaults
sdist.add_defaults(self)
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/command/sdist.py", line 112, in add_defaults
super().add_defaults()
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/sdist.py", line 251, in add_defaults
self._add_defaults_ext()
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/_distutils/command/sdist.py", line 336, in _add_defaults_ext
self.filelist.extend(build_ext.get_source_files())
File "<string>", line 204, in get_source_files
File "/private/var/folders/cc/k8vnp7px375cvm7dxz100k200000gn/T/pip-build-env-qypyt_dm/overlay/lib/python3.12/site-packages/setuptools/_distutils/cmd.py", line 107, in __getattr__
raise AttributeError(attr)
AttributeError: cython_sources
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/piptools/__main__.py", line 19, in <module>
cli()
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/click/core.py", line 1130, in __call__
return self.main(*args, **kwargs)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/click/core.py", line 1657, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/click/decorators.py", line 26, in new_func
return f(get_current_context(), *args, **kwargs)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/piptools/scripts/compile.py", line 659, in cli
results = resolver.resolve(max_rounds=max_rounds)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/piptools/resolver.py", line 604, in resolve
is_resolved = self._do_resolve(
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/piptools/resolver.py", line 636, in _do_resolve
resolver.resolve(
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/resolver.py", line 92, in resolve
result = self._result = resolver.resolve(
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_vendor/resolvelib/resolvers.py", line 546, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_vendor/resolvelib/resolvers.py", line 397, in resolve
self._add_to_criteria(self.state.criteria, r, parent=None)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_vendor/resolvelib/resolvers.py", line 173, in _add_to_criteria
if not criterion.candidates:
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_vendor/resolvelib/structs.py", line 156, in __bool__
return bool(self._sequence)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 155, in __bool__
return any(self)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 143, in <genexpr>
return (c for c in iterator if id(c) not in self._incompatible_ids)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 47, in _iter_built
candidate = func()
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/factory.py", line 206, in _make_candidate_from_link
self._link_candidate_cache[link] = LinkCandidate(
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 293, in __init__
super().__init__(
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 156, in __init__
self.dist = self._prepare()
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 225, in _prepare
dist = self._prepare_distribution()
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 304, in _prepare_distribution
return preparer.prepare_linked_requirement(self._ireq, parallel_builds=True)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/operations/prepare.py", line 538, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/operations/prepare.py", line 653, in _prepare_linked_requirement
dist = _get_prepared_distribution(
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/operations/prepare.py", line 69, in _get_prepared_distribution
abstract_dist.prepare_distribution_metadata(
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/distributions/sdist.py", line 48, in prepare_distribution_metadata
self._install_build_reqs(finder)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/distributions/sdist.py", line 118, in _install_build_reqs
build_reqs = self._get_build_requires_wheel()
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/distributions/sdist.py", line 95, in _get_build_requires_wheel
return backend.get_requires_for_build_wheel()
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/utils/misc.py", line 697, in get_requires_for_build_wheel
return super().get_requires_for_build_wheel(config_settings=cs)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_impl.py", line 166, in get_requires_for_build_wheel
return self._call_hook('get_requires_for_build_wheel', {
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_impl.py", line 311, in _call_hook
self._subprocess_runner(
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/utils/subprocess.py", line 252, in runner
call_subprocess(
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out/python-venv/lib/python3.12/site-packages/pip/_internal/utils/subprocess.py", line 224, in call_subprocess
raise error
pip._internal.exceptions.InstallationSubprocessError: Getting requirements to build wheel exited with 1
['ninja', '-C', '/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out', '-v', ':python_packages.install']
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/virtualenv_setup/install.py", line 421, in install_packages
subprocess.check_call(ninja_cmd, stdout=outs, stderr=outs)
File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/subprocess.py", line 413, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['ninja', '-C', '/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/.environment/gn_out', '-v', ':python_packages.install']' returned non-zero exit status 1.
During handling of the above exception, another exception occurred:
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 995, in <module>
sys.exit(main())
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 987, in main
return EnvSetup(**vars(parse())).setup()
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 577, in setup
result = step(spin)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 766, in virtualenv
if not virtualenv_setup.install(
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/virtualenv_setup/install.py", line 443, in install
install_packages(gn_target)
File "/Users/nabeelahmed/.espressif/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/virtualenv_setup/install.py", line 424, in install_packages
raise subprocess.CalledProcessError(
Installing pip requirements for all...
_install_additional_pip_requirements:29: command not found: pip
Here is the result of the Doctor command if that helps:
---------------------------------------------- ESP-IDF Extension for Visual Studio Code report ---------------------------------------------
OS darwin arm64 22.3.0
System environment variable IDF_PYTHON_ENV_PATH
undefined
System environment variable PATH
/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin
System environment variable PYTHON
undefined
Visual Studio Code version 1.68.1
Visual Studio Code language en
Visual Studio Code shell /bin/zsh
ESP-IDF Extension version 1.6.5
Workspace folder <HOMEPATH>/Documents/testESPproject/hello_world
---------------------------------------------------- Extension configuration settings ------------------------------------------------------
ESP-ADF Path (idf.espAdfPath) ${env:ADF_PATH}
ESP-IDF Path (idf.espIdfPath) <HOMEPATH>/esp/esp-idf
ESP-MDF Path (idf.espMdfPath) ${env:MDF_PATH}
ESP-Matter Path (idf.espMatterPath) <HOMEPATH>/.espressif/esp-matter
Custom extra paths (idf.customExtraPaths) <HOMEPATH>/.espressif/tools/xtensa-esp-elf-gdb/11.2_20220823/xtensa-esp-elf-gdb/bin:<HOMEPATH>/.espressif/tools/riscv32-esp-elf-gdb/11.2_20220823/riscv32-esp-elf-gdb/bin:<HOMEPATH>/.espressif/tools/xtensa-esp32-elf/esp-2022r1-11.2.0/xtensa-esp32-elf/bin:<HOMEPATH>/.espressif/tools/xtensa-esp32s2-elf/esp-2022r1-11.2.0/xtensa-esp32s2-elf/bin:<HOMEPATH>/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin:<HOMEPATH>/.espressif/tools/riscv32-esp-elf/esp-2022r1-11.2.0/riscv32-esp-elf/bin:<HOMEPATH>/.espressif/tools/esp32ulp-elf/2.35_20220830/esp32ulp-elf/bin:<HOMEPATH>/.espressif/tools/cmake/3.24.0/CMake.app/Contents/bin:<HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20230921/openocd-esp32/bin:<HOMEPATH>/.espressif/tools/ninja/1.10.2:<HOMEPATH>/.espressif/tools/esp-rom-elfs/20220823
Custom extra vars (idf.customExtraVars)
OPENOCD_SCRIPTS: <HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20230921/openocd-esp32/share/openocd/scripts
ESP_ROM_ELF_DIR: <HOMEPATH>/.espressif/tools/esp-rom-elfs/20220823/
Virtual env Python Path (idf.pythonBinPath) <HOMEPATH>/.espressif/python_env/idf5.0_py3.12_env/bin/python
Serial port (idf.port) /dev/ttyUSB1
OpenOCD Configs (idf.openOcdConfigs) board/esp32-wrover-kit-3.3v.cfg
ESP-IDF Tools Path (idf.toolsPath) <HOMEPATH>/.espressif
Git Path (idf.gitPath) git
-------------------------------------------------------- Configurations access -------------------------------------------------------------
Access to ESP-ADF Path (idf.espAdfPath) false
Access to ESP-IDF Path (idf.espIdfPath) true
Access to ESP-MDF Path (idf.espMdfPath) false
Access to ESP-Matter Path (idf.espMatterPath) true
Access to ESP-IDF Custom extra paths
Access to <HOMEPATH>/.espressif/tools/xtensa-esp-elf-gdb/11.2_20220823/xtensa-esp-elf-gdb/bin: true
Access to <HOMEPATH>/.espressif/tools/riscv32-esp-elf-gdb/11.2_20220823/riscv32-esp-elf-gdb/bin: true
Access to <HOMEPATH>/.espressif/tools/xtensa-esp32-elf/esp-2022r1-11.2.0/xtensa-esp32-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/xtensa-esp32s2-elf/esp-2022r1-11.2.0/xtensa-esp32s2-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/riscv32-esp-elf/esp-2022r1-11.2.0/riscv32-esp-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/esp32ulp-elf/2.35_20220830/esp32ulp-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/cmake/3.24.0/CMake.app/Contents/bin: true
Access to <HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20230921/openocd-esp32/bin: true
Access to <HOMEPATH>/.espressif/tools/ninja/1.10.2: true
Access to <HOMEPATH>/.espressif/tools/esp-rom-elfs/20220823: true
Access to Virtual env Python Path (idf.pythonBinPath) true
Access to CMake in environment PATH undefined
Access to Ninja in environment PATH undefined
Access to ESP-IDF Tools Path (idf.toolsPath) true
-------------------------------------------------------- Configurations has spaces -------------------------------------------------------------
Spaces in system environment Path undefined
Spaces in ESP-ADF Path (idf.espAdfPath) undefined
Spaces in ESP-IDF Path (idf.espIdfPath) undefined
Spaces in ESP-MDF Path (idf.espMdfPath) undefined
Spaces in ESP-Matter Path (idf.espMatterPath) undefined
Spaces in ESP-IDF Custom extra paths
Spaces in Virtual env Python Path (idf.pythonBinPath) undefined
Spaces in ESP-IDF Tools Path (idf.toolsPath) undefined
----------------------------------------------------------- Executables Versions -----------------------------------------------------------
Git version undefined
ESP-IDF version undefined
Python version undefined
Python's pip version undefined
-------------------------------------------------- Project configuration settings ----------------------------------------------------------
-------------------------------------------------- Python packages in idf.pythonBinPath ----------------------------------------------------
---------------------------------------------------- Check ESP-IDF python requirements.txt -------------------------------------------------
Check ESP-IDF Python packages undefined
---------------------------------------------------- Check extension requirements.txt ------------------------------------------------------
Check Extension Python packages undefined
---------------------------------------------------- Check ESP-IDF debug adapter requirements.txt ------------------------------------------
Check Debug AdapterPython packages undefined
----------------------------------------------------------- Latest error -----------------------------------------------------------------
Latest error at Unknown error in ESP-IDF doctor command
Any help is appreciated. Not sure why using ESP-IDF tools is this frustrating.
Regards,
Nabeel
ESP-IDF Matter extension trouble installing on VSCode on MacOS
nabeel@helloryse.com
AnonTheEngenius
Re: ESP-IDF Matter extension trouble installing on VSCode on MacOS
I have the same issue. The documentation is f***ing ridiculous.
Got the same issue. What helped me:
- switch to the Matter root repository: esp-matter
- open: connectedhomeip/connectedhomeip/.environment/gn_out/python/gen/matter_build_venv/generated_requirements.txt
- comment the following line:
I assume that the issue was with some version constraints specified in that constraints.txt file, for example:
I checked my pip environment and PyYAML==6.0.1 was already installed during ESP-IDF setup. Not sure how that file should look like as updating pyyaml==6.0.1 fixes original error, but then there are dozen new errors related to other dependencies.
So, I just commented out that file from the generated_requirements.txt and was able to build example applications.
Hope this helps.
-c ../../../../../scripts/setup/constraints.txt
pyyaml==6.0
Hope this helps.
