Disable Interrupts for Legacy Serial Write
seb101
Postby seb101 » Fri Feb 09, 2024 3:07 pm
I need to send data to a very simple non-standard serial interface on a remote device, it is not UART compatible, so needs to be sent by driving a TX pin with precise timing from the CPU. It is a fixed length data frame, 9 data bytes and the checksum. I have this working fine, except for when I enable other functions on the ESP, like the WebSockets interface, as events messages received on the WebSocket cause interrupts that can (and often do) halt the processing of the serial write mid-frame, causing the frame to fail to the receiver.
How do I protect the execution of the serial write routine so that nothing can interrupt it while it's transmitting a frame?
I have looked at
taskENTER_CRITICAL
however this seems overkill as it prevents interrupts occuring on both cores, is there a function to just disable interrupts on the current execution core?
Re: Disable Interrupts for Legacy Serial Write
Postby Sprite » Sat Feb 10, 2024 6:22 am
Easier to just use hardware; e.g. look at the RMT peripheral.
Users browsing this forum: Applebot, PerplexityBot, Qwantbot, Semrush [Bot] and 3 guests
