Help to recompile code fro Ard nano to ESP32 bluetooth
chabanca
Postby chabanca » Sat Feb 10, 2024 3:49 pm
Code: Untitled.txt Select all
hello World. this is code to control stepper motor focuser on astro telescope via Indi driver - usb cable -arduino nano. I need to recompile it to ESP32 wroom 32U and use esp bluetooth instead cable. Is it possible? thank you.
Z
 #include <AccelStepper.h>
// Motor pin definitions:
#define motorPin1  4      // IN1 on the ULN2003 driver
#define motorPin2  5     // IN2 on the ULN2003 driver
#define motorPin3  6    // IN3 on the ULN2003 driver
#define motorPin4  7    // IN4 on the ULN2003 driver
// Define the AccelStepper interface type; 4 wire motor in half step mode:
#define MotorInterfaceType 4
// Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper library with 28BYJ-48 stepper motor:
AccelStepper stepper = AccelStepper(MotorInterfaceType, motorPin1, motorPin3, motorPin2, motorPin4);
#define HOMEPOSITION 32000
#define MAXSPEED 600
#define SPEEDMULT 3
#define MAXCOMMAND 8
#define BACKLASHSTEPS 200
char inChar;
char cmd[MAXCOMMAND];
char param[MAXCOMMAND];
char line[MAXCOMMAND];
long pos;
int isRunning = 0;
int previousDirection = 0;
long backlashApplied = 0;
int speed = 32;
int eoc = 0;
int idx = 0;
long millisLastMove = 0;
void setup()
  Serial.begin(9600);
  stepper.setMaxSpeed(MAXSPEED);
  stepper.setSpeed(MAXSPEED);
  stepper.setAcceleration(MAXSPEED * .75);
  stepper.enableOutputs();
  stepper.setCurrentPosition(HOMEPOSITION);
  memset(line, 0, MAXCOMMAND);
  millisLastMove = millis();
  // run the stepper if there's no pending command and if there are pending movements
  if (!Serial.available())  {
    if (isRunning) {
      stepper.run();
    else {
      // reported on INDI forum that some steppers "stutter" if disableOutputs is done repeatedly
      // over a short interval; hence we only disable the outputs and release the motor some seconds
      // after movement has stopped
      if ((millis() - millisLastMove) > 1000) {
        stepper.disableOutputs();
    if (stepper.distanceToGo() == 0) {
      stepper.run();
      isRunning = 0;
      if (backlashApplied != 0) {
        stepper.setCurrentPosition(stepper.currentPosition() - backlashApplied);
  else {
    // read the command until the terminating # character
    while (Serial.available() && !eoc) {
      inChar = Serial.read();
      if (inChar != '#' && inChar != ':') {
        line[idx++] = inChar;
        if (idx >= MAXCOMMAND) {
          idx = MAXCOMMAND - 1;
      else {
        if (inChar == '#') {
          eoc = 1;
  // process the command we got
  if (eoc) {
    memset(cmd, 0, MAXCOMMAND);
    memset(param, 0, MAXCOMMAND);
    int len = strlen(line);
    if (len >= 2) {
      strncpy(cmd, line, 2);
    if (len > 2) {
      strncpy(param, line + 2, len - 2);
    eoc = 0;
    idx = 0;
    // LED backlight value, always return "00"
    if (!strcasecmp(cmd, "GB")) {
      Serial.print("00#");
    // home the motor, hard-coded, ignore parameters since we only have one motor
    if (!strcasecmp(cmd, "PH")) {
      stepper.moveTo(0);
      isRunning = 1;
    // firmware value, always return "10"
    if (!strcasecmp(cmd, "GV")) {
      Serial.print("10#");
    // get the current motor position
    if (!strcasecmp(cmd, "GP")) {
      pos = stepper.currentPosition();
      char tempString[6];
      sprintf(tempString, "%04X", pos);
      Serial.print(tempString);
      Serial.print("#");
    // get the new motor position (target)
    if (!strcasecmp(cmd, "GN")) {
      pos = stepper.targetPosition();
      char tempString[6];
      Serial.print("#");
    // get the current temperature, hard-coded
    if (!strcasecmp(cmd, "GT")) {
      Serial.print("20#");
    // get the temperature coefficient, hard-coded
    if (!strcasecmp(cmd, "GC")) {
      Serial.print("02#");
    // get the current motor speed, speed change not supported
    if (!strcasecmp(cmd, "GD")) {
      char tempString[6];
      sprintf(tempString, "%02X", speed);
      Serial.print("#");
    // set speed. Unsupported
    if (!strcasecmp(cmd, "SD")) {
      speed = hexstr2long(param);
    // whether half-step is enabled or not, always return "00"
    if (!strcasecmp(cmd, "GH")) {
    // motor is moving - 01 if moving, 00 otherwise
    if (!strcasecmp(cmd, "GI")) {
      if (abs(stepper.distanceToGo()) > 0) {
        Serial.print("01#");
    // set current motor position
    if (!strcasecmp(cmd, "SP")) {
      pos = hexstr2long(param);
      stepper.setCurrentPosition(pos);
    // set new motor position and compensate for backlash
    if (!strcasecmp(cmd, "SN") and !isRunning) {
      long curPos = stepper.currentPosition();
      if (curPos != pos) {
        int newDirection = 1;
        if (pos < curPos) {
          newDirection = -1;
        if (previousDirection != 0) {
          if (newDirection != previousDirection) {
            pos = pos + (BACKLASHSTEPS * newDirection);
            backlashApplied = BACKLASHSTEPS * newDirection;
        previousDirection = newDirection;
        stepper.moveTo(pos);
    // initiate a move
    if (!strcasecmp(cmd, "FG") and !isRunning) {
      isRunning = 1;
    // stop a move
    if (!strcasecmp(cmd, "FQ")) {
      isRunning = 0;
      stepper.moveTo(stepper.currentPosition());
      stepper.run();
long hexstr2long(char *line) {
  long ret = 0;
  ret = strtol(line, NULL, 16);
  return (ret);
lbernstone
Re: Help to recompile code fro Ard nano to ESP32 bluetooth
Postby lbernstone » Sun Feb 11, 2024 12:14 pm
The code compiles cleanly on esp32, but it may not work out the way you like. esp32 has an OS, so it needs some cpu cycles to run background tasks. This may break code written for Arduino which expects to have 100% real-time control of the processor. There are work-arounds for this with hardware peripherals, but if you expect to just drop existing microsecond-managed code onto a new cpu, that is unlikely to work.
Users browsing this forum: Amazon [Bot] and 1 guest
