I'm sure this question has been asked - I've done some searches - didn't really find anything that was a structured procedure - assuming one exists.
I'm hoping there's a rather straightforward way to take the ESP-WHO examples that are built using the idf.py script process and import those into eclipse so that a proper debug environment can be run.
Please kindly point me to where this procedure is (hopefully) - I hope to do this it's not the complete process of putting the build environment together from scratch - but I suppose that will work if that's the only choice.
Thanks In Advance,
John W.
ESP-WHO Examples - idf.py projects -> possible to import into eclipse?
jwest247365
jwest247365
Re: ESP-WHO Examples - idf.py projects -> possible to import into eclipse?
Hello ESP_Sandra,
Yes I have - and I get the cmake error about not being able to load the cache.
I've tried all of the workarounds for that as well.
Can you try that and see how far you can get?
Doing cmake . in the dir(s) doesn't help really.
Also - I have an older user id - jwestmoreland - can you please reset the password on that and send a link to the email address
on record? I tried to get the system to do that - kept telling me it was sending the reset link - never got it.
Thanks,
John W.
Thanks,
John W.
kondalkolipaka
- Espressif staff
We have documented something on this here and please check and report us back if you see any issues with IDE.
https://github.com/espressif/idf-eclips ... ressif-ide
