Hi All,
I just getting into the EXP-IDF via Visual Studio Code, since I usually use the Arduino IDE or PlatformIO via Visual Studio Code. I need a simple code example showing how to access the internal registers of the LAN8710A, basically dump out all the LAN8710A registers contents.
Thanks in advance.
Kind Regards
Mike Zomo
Simple example code to dump LAN8710A registers
Re: Simple example code to dump LAN8710A registers
I had to do the same thing recently to diagnose some of our ethernet faults with a SMSC LAN8710A phy chip interfacing with an ESP32-WROVER-E.
The esp-idf driver that supports LAN8710A has some code that reads Phy registers
https://github.com/espressif/esp-idf/bl ... _lan87xx.c
I'm using an old copy of esp-idf 4.1, but I modified my copy of esp_eth_phy_lan8720.c by adding a report method to dump various regsiter values to UART using ESP_LOGI(). I exposed this method to my application.
This is the git diff on my esp-idf
diff --git a/components/esp_eth/include/esp_eth.h b/components/esp_eth/include/esp_eth.h
index 34ee91594..6e2b7c43b 100644
--- a/components/esp_eth/include/esp_eth.h
+++ b/components/esp_eth/include/esp_eth.h
@@ -147,6 +147,8 @@ esp_err_t esp_eth_driver_uninstall(esp_eth_handle_t hdl);
esp_err_t esp_eth_start(esp_eth_handle_t hdl);
+esp_err_t esp_link_report(esp_eth_handle_t hdl);
* @brief Stop Ethernet driver
diff --git a/components/esp_eth/include/esp_eth_phy.h b/components/esp_eth/include/esp_eth_phy.h
index 4aedff111..05caadd0a 100644
--- a/components/esp_eth/include/esp_eth_phy.h
+++ b/components/esp_eth/include/esp_eth_phy.h
@@ -171,6 +171,8 @@ struct esp_eth_phy_s {
esp_err_t (*del)(esp_eth_phy_t *phy);
+ esp_err_t (*report_link)(esp_eth_phy_t *phy);
diff --git a/components/esp_eth/src/esp_eth.c b/components/esp_eth/src/esp_eth.c
index a895b5b09..011dbabcd 100644
--- a/components/esp_eth/src/esp_eth.c
+++ b/components/esp_eth/src/esp_eth.c
@@ -250,6 +250,20 @@ err:
return ret;
+/// @brief Prints out values from registers on the Phy chip
+/// LAN8710A to give an indication of the ethernet status
+/// @param hdl ethernet driver handle
+/// @return ESP_OK
+ esp_err_t ret = ESP_OK;
+ esp_eth_driver_t *eth_driver = (esp_eth_driver_t *)hdl;
+ eth_driver->phy->report_link(eth_driver->phy);
+ return ret;
diff --git a/components/esp_eth/src/esp_eth_phy_lan8720.c b/components/esp_eth/src/esp_eth_phy_lan8720.c
index bd6437605..a48cde550 100644
--- a/components/esp_eth/src/esp_eth_phy_lan8720.c
+++ b/components/esp_eth/src/esp_eth_phy_lan8720.c
@@ -165,6 +165,56 @@ typedef struct {
int reset_gpio_num;
} phy_lan8720_t;
+static esp_err_t lan8720_report_link(esp_eth_phy_t *phy)
+ phy_lan8720_t *lan8720 = __containerof(phy, phy_lan8720_t, parent);
+ esp_eth_mediator_t *eth = lan8720->eth;
+ eth_speed_t speed = ETH_SPEED_10M;
+ eth_duplex_t duplex = ETH_DUPLEX_HALF;
+ bmsr_reg_t bmsr;
+ bmcr_reg_t bmcr;
+ pscsr_reg_t pscsr;
+ PHY_CHECK(eth->phy_reg_read(eth, lan8720->addr, ETH_PHY_BMSR_REG_ADDR, &(bmsr.val)) == ESP_OK,
+ "read BMSR failed", err);
+ //eth_link_t link = bmsr.link_status ? ETH_LINK_UP : ETH_LINK_DOWN;
+ ESP_LOGI(TAG, "Phy BMSR val 0x%04X, link_status %u (%s)",
+ bmsr.val, bmsr.link_status, bmsr.link_status ? "UP" : "DOWN");
+ PHY_CHECK(eth->phy_reg_read(eth, lan8720->addr, ETH_PHY_PSCSR_REG_ADDR, &(pscsr.val)) == ESP_OK,
+ "read PSCSR failed", err);
+ switch (pscsr.speed_indication) {
+ case 1: //10Base-T half-duplex
+ speed = ETH_SPEED_10M;
+ duplex = ETH_DUPLEX_HALF;
+ break;
+ case 2: //100Base-TX half-duplex
+ speed = ETH_SPEED_100M;
+ break;
+ case 5: //10Base-T full-duplex
+ duplex = ETH_DUPLEX_FULL;
+ break;
+ case 6: //100Base-TX full-duplex
+ break;
+ default:
+ break;
+ ESP_LOGI(TAG, "Phy SCSR val 0x%04X, SI %u, LinkSpeed %u (%s), Duplex %u (%s)",
+ pscsr.val, pscsr.speed_indication,
+ speed, speed ? "100M" : "10M",
+ duplex, duplex ? "FULL" : "HALF");
+ ESP_LOGI(TAG, "Phy SCSR val 0x%04X auto_neg_done %u", pscsr.val, pscsr.auto_nego_done);
+ PHY_CHECK(eth->phy_reg_read(eth, lan8720->addr, ETH_PHY_BMCR_REG_ADDR, &(bmcr.val)) == ESP_OK,
+ "read basic control reg failed", err);
+ ESP_LOGI(TAG, "Phy BMCR val 0x%04X, Loopback mode %u", bmcr.val, bmcr.en_loopback);
+ return ESP_OK;
+err: return ESP_FAIL;
static esp_err_t lan8720_update_link_duplex_speed(phy_lan8720_t *lan8720)
@@ -425,6 +475,7 @@ esp_eth_phy_t *esp_eth_phy_new_lan8720(const eth_phy_config_t *config)
lan8720->parent.get_addr = lan8720_get_addr;
lan8720->parent.set_addr = lan8720_set_addr;
lan8720->parent.del = lan8720_del;
+ lan8720->parent.report_link = lan8720_report_link;
return &(lan8720->parent);
err:
Here is a code example to dump PHY registers:
esp_err_t dump_phy_regs(esp_eth_handle_t *eth_handle, uint32_t start_addr, uint32_t end_addr)
esp_eth_phy_reg_rw_data_t reg;
uint32_t reg_val;
reg.reg_value_p = ®_val;
printf("--- PHY Registers Dump ---\n");
for (uint32_t curr_addr = start_addr; curr_addr <= end_addr; curr_addr++) {
reg.reg_addr = curr_addr;
ESP_RETURN_ON_ERROR(esp_eth_ioctl(eth_handle, ETH_CMD_READ_PHY_REG, ®), TAG, "ioctl read PHY register failed");
printf("Addr: 0x%02lx, value: 0x%04lx\n", curr_addr, reg_val);
printf("\n");
return ESP_OK;
}Who is online
Users browsing this forum: Baidu [Spider], Google [Bot], Semrush [Bot] and 1 guest
