Serial bytes not as expected
markoc
Postby markoc » Tue Feb 27, 2024 11:48 am
I'm hoping someone can help point me in the right direction to solve a problem I'm having with reading serial data from an external device.
The device outputs 6 bytes of data via serial that I need to interpret. The device sends at 19200 baud with 8N1. The serial data packets are organised as 16 bit words in big endian order.
When I connect the device to a PC and use Realterm to see the data in Hex form I get exactly what I'm supposed to and it looks like this:
B2 82 5B 13 00 02
When I connect the device to an ESP32 Dev board and run the simple code below I get 6 bytes but they look like this:
93 9F 2A F7 FB 00
At first I thought it was an endian issue but swapping bytes around doesn't help here. Any help with explaining why the data is so different on the ESP32 would be greatly appreciated.
My code:
int LC2bytePOS = 0;
byte LC2msg[7];
  Serial1.begin(19200, SERIAL_8N1, RXD1, TXD1);   //Setup the Lambda (LC-1) serial UART
  char LC2byte;
  while (Serial1.available() > 0) {
    LC2byte=Serial1.read();
    if  (LC2byte == 0x93) {    // Should be B2 but lets go with this as a header byte for now
      LC2msg[0] = LC2byte;     // Start building the message from the beginning
      LC2bytePOS = 0;          // Reset byte counter
      Serial.print("\n\r");
    else {
      LC2bytePOS++;
      LC2msg[LC2bytePOS]=LC2byte;               // Add the byte to the message
      if (LC2bytePOS > 6) {LC2bytePOS=6;}
    Serial.printf("%02X ", LC2byte);
Thank you
