esp-matter installation error in RPI-4
saikrishnaa
Postby saikrishnaa » Wed Feb 28, 2024 6:22 pm
Hi All,
I am trying to install esp-matter in my Raspberry Pi4 with 2 GB RAM and 32 GB Micro SD Card and it is installed with 22.04.4 server 64 bit OS.
But I am not able to install.
Please find the below logs for your reference.
It is always hangs at installation of matter, a shippent is given below and details log also provided.
ninja: Entering directory `/home/matter/esp/esp-matter/connectedhomeip/connectedhomeip/out/host'
[413/660] c++ obj/src/app/util/data_model.generic-callback-stubs.cpp.o
matter@ubuntu:~$ [ 7976.000237] INFO: task kworker/3:1:5534 blocked for more than 120 seconds.
[ 7976.007467] Tainted: G C E 5.15.0-1046-raspi #49-Ubuntu
[ 7976.014507] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Here is the links and steps followed for the installation
https://docs.espressif.com/projects/esp ... setup.html
Code: Untitled.bsh Select all
mkdir -p ~/esp
cd ~/esp
git clone --recursive https://github.com/espressif/esp-idf.git
cd ~/esp/esp-idf
./install.sh all
matter@ubuntu:~/esp/esp-idf$ . ./export.sh
Setting IDF_PATH to '/home/matter/esp/esp-idf'
Detecting the Python interpreter
Checking "python3" ...
Python 3.10.12
"python3" has been detected
Checking Python compatibility
Checking other ESP-IDF version.
Adding ESP-IDF tools to PATH...
Checking if Python packages are up to date...
Constraint file: /home/matter/.espressif/espidf.constraints.v5.3.txt
Requirement files:
- /home/matter/esp/esp-idf/tools/requirements/requirements.core.txt
Python being checked: /home/matter/.espressif/python_env/idf5.3_py3.10_env/bin/python
Python requirements are satisfied.
Added the following directories to PATH:
/home/matter/esp/esp-idf/components/espcoredump
/home/matter/esp/esp-idf/components/partition_table
/home/matter/esp/esp-idf/components/app_update
/home/matter/.espressif/tools/xtensa-esp-elf-gdb/12.1_20231023/xtensa-esp-elf-gdb/bin
/home/matter/.espressif/tools/riscv32-esp-elf-gdb/12.1_20231023/riscv32-esp-elf-gdb/bin
/home/matter/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin
/home/matter/.espressif/tools/riscv32-esp-elf/esp-13.2.0_20230928/riscv32-esp-elf/bin
/home/matter/.espressif/tools/esp32ulp-elf/2.35_20220830/esp32ulp-elf/bin
/home/matter/.espressif/tools/openocd-esp32/v0.12.0-esp32-20230921/openocd-esp32/bin
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
https://docs.espressif.com/projects/esp ... oping.html
matter@ubuntu:~/esp/esp-idf$ cd ../
matter@ubuntu:~/esp$ git clone --depth 1 https://github.com/espressif/esp-matter.git
cd esp-matter
git submodule update --init --depth 1
cd ./connectedhomeip/connectedhomeip
./scripts/checkout_submodules.py --platform esp32 linux --shallow
cd ../..
./install.sh
cd ..
Cloning into 'esp-matter'...
remote: Enumerating objects: 566, done.
remote: Counting objects: 100% (566/566), done.
remote: Compressing objects: 100% (473/473), done.
remote: Total 566 (delta 144), reused 425 (delta 73), pack-reused 0
Receiving objects: 100% (566/566), 4.81 MiB | 4.35 MiB/s, done.
Resolving deltas: 100% (144/144), done.
Submodule 'connectedhomeip/connectedhomeip' (https://github.com/espressif/connectedhomeip.git) registered for path 'connectedhomeip/connectedhomeip'
Cloning into '/home/matter/esp/esp-matter/connectedhomeip/connectedhomeip'...
remote: Total 0 (delta 0), reused 0 (delta 0), pack-reused 0
remote: Enumerating objects: 16899, done.
remote: Counting objects: 100% (16899/16899), done.
remote: Compressing objects: 100% (11285/11285), done.
remote: Total 15647 (delta 6756), reused 8683 (delta 3501), pack-reused 0
Receiving objects: 100% (15647/15647), 36.54 MiB | 7.73 MiB/s, done.
Resolving deltas: 100% (6756/6756), completed with 652 local objects.
From https://github.com/espressif/connectedhomeip
* branch d38a6496c3abeb3daf6429b1f11172cfa0112a1a -> FETCH_HEAD
Submodule path 'connectedhomeip/connectedhomeip': checked out 'd38a6496c3abeb3daf6429b1f11172cfa0112a1a'
Checking out: nlassert, nlio, nlunit-test, mbedtls, qrcode, m5stack-tft, pigweed, openthread, ot-br-posix, cirque, nanopb, freertos, third_party/pybind11/repo, third_party/jsoncpp/repo, editline, third_party/boringssl/repo/src, third_party/libwebsockets/repo, third_party/imgui/repo, perfetto
Running Matter Setup
Synchronizing submodule url for 'examples/common/QRCode/repo'
Synchronizing submodule url for 'examples/common/m5stack-tft/repo'
Synchronizing submodule url for 'third_party/boringssl/repo/src'
Synchronizing submodule url for 'third_party/cirque/repo'
Synchronizing submodule url for 'third_party/editline/repo'
Synchronizing submodule url for 'third_party/freertos/repo'
Synchronizing submodule url for 'third_party/imgui/repo'
Synchronizing submodule url for 'third_party/jsoncpp/repo'
Synchronizing submodule url for 'third_party/libwebsockets/repo'
Synchronizing submodule url for 'third_party/mbedtls/repo'
Synchronizing submodule url for 'third_party/nanopb/repo'
Synchronizing submodule url for 'third_party/nlassert/repo'
Synchronizing submodule url for 'third_party/nlio/repo'
Synchronizing submodule url for 'third_party/nlunit-test/repo'
Synchronizing submodule url for 'third_party/openthread/repo'
Synchronizing submodule url for 'third_party/ot-br-posix/repo'
Synchronizing submodule url for 'third_party/perfetto/repo'
Synchronizing submodule url for 'third_party/pigweed/repo'
Synchronizing submodule url for 'third_party/pybind11/repo'
WELCOME TO...
BOOTSTRAP! Bootstrap may take a few minutes; please be patient.
Downloading and installing packages into local source directory:
Setting up CIPD package manager...done (5m47.7s)
Setting up Project actions........skipped (0.1s)
Setting up Python environment.....done (6m49.2s)
Setting up pw packages............skipped (0.1s)
Setting up Host tools.............done (0.1s)
Activating environment (setting environment variables):
Setting environment variables for CIPD package manager...done
Setting environment variables for Project actions........skipped
Setting environment variables for Python environment.....done
Setting environment variables for pw packages............skipped
Setting environment variables for Host tools.............done
Checking the environment:
20240228 17:00:19 INF Environment passes all checks!
Environment looks good, you are ready to go!
To reactivate this environment in the future, run this in your
terminal:
source ./activate.sh
To deactivate this environment, run this:
deactivate
Installing pip requirements for all...
[notice] A new release of pip is available: 23.2.1 -> 24.0
[notice] To update, run: pip install --upgrade pip
Building host tools
Done. Made 7672 targets from 364 files in 2091ms
Build is stopped at this moment and RPI-4 is hanged
output coming in Seiral port of RPI-4
[ 8096.835314] INFO: task kworker/3:1:5534 blocked for more than 241 seconds.
[ 8096.842339] Tainted: G C E 5.15.0-1046-raspi #49-Ubuntu
[ 8096.849364] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 8217.670043] INFO: task kworker/3:1:5534 blocked for more than 362 seconds.
[ 8217.677072] Tainted: G C E 5.15.0-1046-raspi #49-Ubuntu
[ 8217.684094] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 8459.338619] INFO: task kworker/3:1:5534 blocked for more than 120 seconds.
[ 8459.345638] Tainted: G C E 5.15.0-1046-raspi #49-Ubuntu
[ 8459.352647] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 8580.172604] INFO: task kworker/3:1:5534 blocked for more than 241 seconds.
[ 8580.179625] Tainted: G C E 5.15.0-1046-raspi #49-Ubuntu
[ 8580.186640] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Can anyone suggest how to fix this and why it is coming.
I am using the latest git repo i.e. main(latest) for ESP-IDF. even I tried with 5.2 and 5.1.2 same issue is observed.
Is there any settings need to be changed from matter git folder, Please suggest.
Regards,
Sai Krishna
Users browsing this forum: ChatGPT-User, meta-externalagent, Qwantbot and 3 guests
