ZephyrRTOS - esp32c3 can't connect to WiFi when there is any security
Piotrulo1
Postby Piotrulo1 » Mon Mar 04, 2024 12:56 pm
As in the subject, I can't connect to any network that uses e.g. WPA2, when there is network without password it connects everytime.
connectTo method:
Code: Untitled.cpp Select all
bool WifiDriver::connectTo(const SSIDstring& ssid, const PSKstring& password) {
if (k_sem_count_get(&connectionSemaphore) > 0) {
return false;
strncpy(reinterpret_cast<char*>(_ssid), ssid.c_str(), WIFI_SSID_MAX_LEN);
_wifiParams.ssid_length = ssid.length();
strncpy(
reinterpret_cast<char*>(_password), password.c_str(), WIFI_PSK_MAX_LEN);
_wifiParams.psk_length = password.length();
_wifiParams.sae_password_length = password.length();
printk("before connection request\n");
int res = net_mgmt(NET_REQUEST_WIFI_CONNECT,
_netInterface,
&_wifiParams,
sizeof(_wifiParams));
if (res) {
printk("connection request failed: %d\n", res, strerror(res));
return false;
printk("connection succeded\n");
_connected = true;
return true;
Init method:
void WifiDriver::init() {
k_sem_init(&connectionSemaphore, 0, 1);
net_mgmt_init_event_callback(
&_wifiCallback,
WifiDriver::wifiCallbackHandler,
NET_EVENT_WIFI_CONNECT_RESULT | NET_EVENT_WIFI_DISCONNECT_RESULT);
net_mgmt_init_event_callback(&_ipv4Callback,
WifiDriver::ipv4CallbackHandler,
NET_EVENT_IPV4_ADDR_ADD);
net_mgmt_add_event_callback(&_wifiCallback);
net_mgmt_add_event_callback(&_ipv4Callback);
_netInterface = net_if_get_default();
if (_netInterface == NULL) {
printk("net_if_get_default failed! No default interface configured!\n");
_wifiParams.ssid = _ssid;
_wifiParams.ssid_length = 0;
_wifiParams.psk = _password;
_wifiParams.psk_length = 0;
_wifiParams.sae_password = _password;
_wifiParams.sae_password_length = 0;
_wifiParams.band = WIFI_FREQ_BAND_2_4_GHZ;
_wifiParams.channel = WIFI_CHANNEL_ANY;
_wifiParams.security = WIFI_SECURITY_TYPE_UNKNOWN;
_wifiParams.mfp = WIFI_MFP_DISABLE;
_wifiParams.timeout = SYS_FOREVER_MS;
_connected = false;
logs:
Code: Untitled.txt Select all
*** Booting Zephyr OS build v3.6.0 ***
[00:00:00.152,000] <inf> net_config: Initializing network
[00:00:00.152,000] <inf> net_config: Waiting interface 1 (0x3fcc0b00) to be up.
[00:00:00.153,000] <inf> net_config: Interface 1 (0x3fcc0b00) coming up
[00:00:00.153,000] <inf> net_config: Running dhcpv4 client...
connection request failed: -22
Users browsing this forum: Baidu [Spider], Qwantbot and 3 guests
