This is how I declared the water level sensor device:
static Device water_level_sensor("Water Level Sensor");Code: Select all
static Param water_level_param("Water Level", "percentage", RMAKER_VAL_TYPE_INTEGER, 0);Code: Select all
water_level_param.updateAndReport((param_val_t)water_level_percentage); Code: Select all
static Param water_level_param("Water Level", "percentage", RMAKER_VAL_TYPE_INTEGER, 0); Code: Select all
error: no matching function for call to 'Param::Param(const char [12], const char [11], esp_rmaker_val_type_t, int)'
static Param water_level_param("Water Level", "percentage", RMAKER_VAL_TYPE_INTEGER, 0); This is my full source code (wherein it captures the temperature and humidity (from DHT11 sensor) and water level results (from water level sensor) and passes them to the ESP Rainmaker App):
#include "RMaker.h"
#include <RMakerParam.h>
#include <RMakerDevice.h>
#include <RMakerNode.h>
#include <WiFi.h>
#include <WiFiProv.h>
#include <DHT.h>
#include <SimpleTimer.h>
#include <wifi_provisioning/manager.h>
// Set Default Values
#define DEFAULT_Temperature 0
#define DEFAULT_Humidity 0
// BLE Credentials
const char *service_name = "myservice";
const char *pop = "mypass";
// GPIO
static uint8_t gpio_reset = 0;
static uint8_t DHTPIN = 23;
bool wifi_connected = false;
DHT dht(DHTPIN, DHT11);
SimpleTimer Timer;
// Declaring Devices
static TemperatureSensor temperature("Temperature");
static TemperatureSensor humidity("Humidity");
void sysProvEvent(arduino_event_t *sys_event) {
switch (sys_event->event_id) {
case ARDUINO_EVENT_PROV_START:
#if CONFIG_IDF_TARGET_ESP32
Serial.printf("\nProvisioning Started with name \"%s\" and PoP \"%s\" on BLE\n", service_name, pop);
printQR(service_name, pop, "ble");
#else
Serial.printf("\nProvisioning Started with name \"%s\" and PoP \"%s\" on SoftAP\n", service_name, pop);
printQR(service_name, pop, "softap");
#endif
case ARDUINO_EVENT_WIFI_STA_CONNECTED:
Serial.printf("\nConnected to Wi-Fi!\n");
wifi_connected = true;
delay(500);
case ARDUINO_EVENT_PROV_CRED_RECV: {
Serial.println("\nReceived Wi-Fi credentials");
Serial.print("\tSSID : ");
Serial.println((const char *)sys_event->event_info.prov_cred_recv.ssid);
Serial.print("\tPassword : ");
Serial.println((char const *)sys_event->event_info.prov_cred_recv.password);
case ARDUINO_EVENT_PROV_INIT:
wifi_prov_mgr_disable_auto_stop(10000);
case ARDUINO_EVENT_PROV_CRED_SUCCESS:
Serial.println("Stopping Provisioning!!!");
wifi_prov_mgr_stop_provisioning();
void write_callback(Device *device, Param *param, const param_val_t val, void *priv_data, write_ctx_t *ctx) {
const char *device_name = device->getDeviceName();
Serial.println(device_name);
const char *param_name = param->getParamName();
// Configure the input GPIOs
pinMode(gpio_reset, INPUT);
// Beginning Sensor
dht.begin();
// Declaring Node
Node my_node = RMaker.initNode("ESP32 Project 2");
// Adding Devices in Node
my_node.addDevice(temperature);
my_node.addDevice(humidity);
my_node.addDevice(water_level_sensor);
// Enable OTA
RMaker.enableOTA(OTA_USING_PARAMS);
// Enable timezone service
RMaker.enableTZService();
// Enable scheduling
RMaker.enableSchedule();
Serial.printf("\nStarting ESP-RainMaker\n");
RMaker.start();
// Timer for Sending Sensor's Data
Timer.setInterval(3000);
WiFi.onEvent(sysProvEvent);
WiFiProv.beginProvision(WIFI_PROV_SCHEME_BLE, WIFI_PROV_SCHEME_HANDLER_FREE_BTDM, WIFI_PROV_SECURITY_1, pop, service_name);
#else
WiFiProv.beginProvision(WIFI_PROV_SCHEME_SOFTAP, WIFI_PROV_SCHEME_HANDLER_NONE, WIFI_PROV_SECURITY_1, pop, service_name);
#endif
// Add water level parameter
water_level_sensor.addParam(water_level_param);
if (Timer.isReady() && wifi_connected) {
// Check if the timer is ready
Serial.println("Sending Sensor's Data");
Send_Sensor();
Timer.reset(); // Reset the timer
// Logic to Reset RainMaker
if (digitalRead(gpio_reset) == LOW) {
// Push button pressed
Serial.printf("Reset Button Pressed!\n");
// Key debounce handling
delay(100);
int startTime = millis();
while (digitalRead(gpio_reset) == LOW)
delay(50);
int endTime = millis();
if ((endTime - startTime) > 10000) {
// If key pressed for more than 10secs, reset all
Serial.printf("Reset to factory.\n");
RMakerFactoryReset(2);
} else if ((endTime - startTime) > 3000) {
Serial.printf("Reset Wi-Fi.\n");
// If key pressed for more than 3secs, but less than 10, reset Wi-Fi
RMakerWiFiReset(2);
delay(100);
void Send_Sensor() {
// Read temperature, humidity, and water level
float h = dht.readHumidity();
float t = dht.readTemperature();
int water_level_reading = readWaterLevel();
// Check if the readings are valid
if (isnan(h) || isnan(t) || water_level_reading == -1) {
Serial.println("Failed to read from sensors");
return;
// Print sensor readings
Serial.print("Temperature - ");
Serial.println(t);
Serial.print("Humidity - ");
Serial.println(h);
Serial.print("Water Level - ");
Serial.println(water_level_reading);
// Update and report temperature parameter
temperature.updateAndReportParam("Temperature", t);
// Update and report humidity parameter
humidity.updateAndReportParam("Humidity", h);
// Update and report water level parameter
float water_level_percentage = map(water_level_reading, 0, 4095, 0, 100);
water_level_percentage = constrain(water_level_percentage, 0, 100);
int readWaterLevel() {
const int POWER_PIN = 17; // GPIO pin connected to power pin of water level sensor
const int SIGNAL_PIN = 36; // GPIO pin connected to signal pin of water level sensor
int value = -1;
// Power on the sensor
pinMode(POWER_PIN, OUTPUT);
digitalWrite(POWER_PIN, HIGH);
delay(10);
// Read the analog value from the sensor
pinMode(SIGNAL_PIN, INPUT);
value = analogRead(SIGNAL_PIN);
// Power off the sensor
digitalWrite(POWER_PIN, LOW);
return value;
