I am using ESP32C6miniDev kit
ESP-IDF 5.1.2
Here is my approach
Create a function to handle semaphore
SemaphoreHandle_t sem_mutex=NULL;
void IRAM_ATTR GOPIisr_handler(void* arg) {
BaseType_t xHigherPriorityTaskWoken = pdFALSE;
xSemaphoreGiveFromISR(sem_mutex, &xHigherPriorityTaskWoken);
portYIELD_FROM_ISR(xHigherPriorityTaskWoken);
void configure_spi() {
spi_bus_config_t bus_config = {
.miso_io_num = 2,
.mosi_io_num = -1, // MOSI not used
.sclk_io_num = 6,
.quadwp_io_num = -1,
.quadhd_io_num = -1,
spi_device_interface_config_t dev_config = {
.clock_speed_hz = SCLK_FREQ,
.mode = 0, // SPI mode 1
.spics_io_num = CS_PIN, //this is actually not needed
.queue_size = 1,
spi_bus_initialize(SPI_BUS, &bus_config, SPI_DMA_CH_AUTO);
spi_bus_add_device(SPI_BUS, &dev_config, &spi);
}Code: Select all
void initialize_IntrGPIO() {
gpio_config_t io_conf = {};
io_conf.pin_bit_mask = (1ULL <<Intr_GPIO);
io_conf.mode = GPIO_MODE_INPUT;
io_conf.intr_type = GPIO_INTR_NEGEDGE;
io_conf.pull_up_en = GPIO_PULLUP_ENABLE;
gpio_config(&io_conf);
}Code: Select all
void task_SPIsampler(void *pvParameters) {
while (1) {
for (int i = 0; i < PacketSize; i++){
xSemaphoreTake(sem_mutex, portMAX_DELAY); // Wait for DRDY interrupt
gpio_set_level(CS_PIN, 0);
spi_transaction_t t;
memset(&t, 0, sizeof(t));
t.length = 24;
t.tx_buffer = NULL;
t.rx_buffer = &(SPI_data[buffer_index]);
spi_device_transmit(spi, &t);
gpio_set_level(CS_PIN, 1);
buffer_index += 3;
// Send data over UDP
ESP_LOGI("UDP", "packet is ready");
//will send to UDP
ESP_LOGI("UDP", "sent");
buffer_index = 0;
}Code: Select all
void app_main() {
ESP_ERROR_CHECK(ret);
sem_mutex = xSemaphoreCreateMutex();
ESP_ERROR_CHECK(gpio_install_isr_service(0));
initialize_IntrGPIO();
configure_spi();
gpio_intr_enable(Intr_GPIO);
gpio_isr_handler_add(Intr_GPIO, GOPIisr_handler, (void*)0);
xTaskCreate(task_SPIsampler, "task_SPIsampler", configMINIMAL_STACK_SIZE + 8192, NULL, 2, NULL);
}The problem is that if there is no interrupt on the pin, the code just sits there waiting for the interrupt. However, as soon as it sees a falling edge on Intr_GPIO, the code exits without an error message.
I have no idea what is going on and why would it exit without a warning or a message.
Kind regards
Ssk
