[ble mesh] ble mesh scene model
chegewara
Postby chegewara » Thu Mar 07, 2024 1:20 pm
not sure if its really abug or just misleading logs, since the scene models exists on non-primary elements
W (628) BLE_MESH: Scene Server not on the Primary element
W (633) BLE_MESH: Scene Setup Server not on the Primary element
According to MshMDLd1.1r10_PRr00.pdf can be assigned to any element and should control models per element
Figure 1.4: Example Composition Data showing the relationship between the states stored with each
scene server and the instantiated functionalities distributed on the elements
Screenshot from 2024-03-07 14-16-30.png (108.03 KiB) Viewed 12336 times
I think it is a bug, because i cant setup scenes when setup srv is not on primary element, or maybe SIG documentation is just ambiguous.
esp-idf: v5.3-dev-2087-g5f42493573
chegewara
Re: [ble mesh] ble mesh scene model
Postby chegewara » Fri Mar 08, 2024 3:15 pm
After digging more i can confirm its a bug. From nrf sdk
The Scene Server model must be instantiated in every node in the network that participates in scenes. A Scene Server model instance stores the scene data for every model on its own element, and every subsequent element until the next Scene Server.
https://developer.nordicsemi.com/nRF_Co ... ene-server
Users browsing this forum: Amazon [Bot] and 1 guest
