Version 5.2.1 - installation freezes
Jorgen
Postby Jorgen » Thu Mar 07, 2024 1:26 pm
When I run the universal Windows installer for the new version 5.2.1, the installation process freezes. Please, see the file attached.
What should I do to install the version 5.2.1?
Regards,
Jorgen
Version_521_install.pdf
(26.32 KiB) Downloaded 402 times
Jakub
Re: Version 5.2.1 - installation freezes
Postby Jakub » Fri Mar 08, 2024 9:03 am
Hello Jorgen,
I have tested your issue on a machine with a clean Windows installation and it looks like there is some trouble with the Universal Windows installer, we will have to investigate a bit more.
To install ESP-IDF v5.2.1 you can use the Offline installer from the installer download page: https://dl.espressif.com/dl/esp-idf/
This should work fine.
Regards,
Jakub
Users browsing this forum: Qwantbot, Semrush [Bot] and 1 guest
