I'm using an external trigger to wake up my ESP32-S3 from deep sleep started with esp_deep_sleep_start
To configure the GPIO to use, I wrote that code:
esp_sleep_enable_ext0_wakeup(GPIO_NUM_9, 0);But reading the documentation about esp_sleep_enable_ext0_wakeup I saw the esp_sleep_enable_ext1_wakeup method that has this description:
Unlike ext0, this wakeup source supports wakeup even when the RTC peripheral is powered down
Does this mean the ESP32 would consume even less power if I was to use esp_sleep_enable_ext1_wakeup?
Also, I read about increased power consumption if esp_sleep_enable_timer_wakeup() is not called, as reported here
Is this applicable to my use case?
I'm using the arduino framework with PlatformIO and no variables have the RTC_DATA_ATTR attribute applied to them.
Thanks for any suggestion here.
