ADC values less than half of expected
glrtheil
Postby glrtheil » Mon Mar 18, 2024 10:32 pm
I've got a project we're working on where we are implementing a hardware ID process, using the ADC and a GPIO for a vref. This is an ESP32_WROOM_32UE on ESP-IDF 4.3.7
Essentially we have a voltage divider that is on SENSOR_VP (GPIO36/ADC1_CHANNEL_0) and GPIO_13
The code is pretty straightforward. Sets the vref GPIO, attenuation, then gets a reading from ADC1 CH0.
    adc2_vref_to_gpio(GPIO_NUM_13);
    adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_0);
    adc1_config_width(ADC_WIDTH_BIT_12);
    while (1)
        int raw_val = adc1_get_raw(ADC1_CHANNEL_0);
        printf("ADC value: %d\n", raw_val);
        vTaskDelay(pdMS_TO_TICKS(500));
The voltage on GPIO13 is 1.029v. The voltage on GPIO36 is 90mV. The expected value is around 358 ((90/1029) * 4095 = 358), however I'm only getting about 90.
When I short GPIO13 to GPIO36, to give it the full reference voltage, I expect to see 4095, but it ends up as this:
Any idea why these numbers are so far off what's expected?
Re: ADC values less than half of expected
Postby Sprite » Tue Mar 19, 2024 4:04 am
The ADC is not very linear in that region on our original ESP32; also the internal reference voltage varies a bit from chip to chip. Try to use the calibration driver, that should compensate for the reference voltage and partly for the nonlinearity, but you may be better off also changing the resistor divider so the value is more in the middle of the ADC range.
chegewara
Postby chegewara » Tue Mar 19, 2024 4:16 am
Reference voltage 1029mV does not mean you will get 4095 measuring 1029mV on ADC pin.
With this line you get 4095 when you connect 3.3V (assuming ideal conditions)
adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_0); <---- ADC_ATTEN_DB_0
Users browsing this forum: Applebot, Google [Bot], meta-externalagent, MicroController, Qwantbot and 7 guests
