What are hardware issues behind Vl6180x didnot light up or blink?
engkhaledeisa
hi ...how are you .....what cause the sensor(Vl6180X) when it gets the power (3.24 volt if I connect it to 3.3v output pin and 5.4 volt if I connect it to vu output pin ) and in both cases it didnot respond and the led light in it didnot blink or lights up...what are the main reasons behind that ....the auther of the project code his design uses espminid1 and he told me I can use the main code on esp8266 nodemcu v3 as that is the one I bought as I found it only in the store (my design uses nodemcu v3 ) ....so what are the hardware differences or issues that cause that ?
- AgilityLights_Master.png (297.5 KiB) Viewed 3261 times
- Screenshot (5).png (225.07 KiB) Viewed 3261 times
engkhaledeisa
