I've searched the forums for any methods for esp32s3 chip input voltage (3.3v) monitoring and found nothing. I assume this would be a common issue for battery powered applications. So I have two questions :
1. Is there a API function specifically for monitoring the esp32s3 3.3v chip input?
2. if not, is there a recommended method to implement voltage monitoring?
if not, I'll build the functionality using the APIs for ADC.
Thanks.
ESP32-s3 3.3v monitoring
Re: ESP32-s3 3.3v monitoring
You can use one of the ADC channels available on the ESP32-S3 to measure the voltage. Connect the input voltage (3.3V in your case) to one of the ADC pins, and then use the ADC API to read the voltage.
Users browsing this forum: Semrush [Bot] and 3 guests
