ESP32 - Hostname
antonins
ESP32 - Hostname
Postby antonins » Wed Mar 27, 2024 4:49 pm
Hello all,
I'm working on ESP32-WROOM-32E.
I made a connection to a wifi but I want to change the hostname but it doesn't work.
I don't understand from when the issue come.
Please find below the code
#include <Arduino.h>  //Basique ESP32
#include <WiFi.h>             //Wifi ??
const char* ssid = "Bbox-641xxxxx";
const char* password = "xxxxxxxxxxxxx";
  delay(1000);
  // Se connecter au réseau WiFi
  Serial.println();
  Serial.print("Connexion au réseau ");
  Serial.println(ssid);
  WiFi.disconnect(true,true);
  delay(1000);
  WiFi.setHostname("test1324");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    delay(1000);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connecté");
  Serial.print("Adresse IP: ");
  Serial.println("Hostname : ");
  Serial.println(WiFi.getHostname());
When I have a look on the BBox interface, the hostname is still ESP32-FCDKDML
Have you any idea of where the problem is coming from ?
Thanks for your help,
Antonin
Basalt
Re: ESP32 - Hostname
Postby Basalt » Wed Mar 27, 2024 8:07 pm
I've been working on changing the hostname lately, this is roughly my solution:
- in setup, add ARDUINO_EVENT_WIFI_STA_DISCONNECTED callback event: start 10 sec reconnect timer (Ticker, once)
- Add reconnect timer callback function: IF (WiFi.status() != WL_CONNECTED) THEN call WiFi.reconnect() ELSE ignore
- In setup, add ARDUINO_EVENT_WIFI_STA_CONNECTED callback event: stop the reconnect timer (just in case we got connected before timeout)
- To change hostname:
-- optionally, stop MDNS
-- call WiFi.setHostname(name)
-- call WiFi.disconnect(false, false) => this will trigger ARDUINO_EVENT_WIFI_STA_DISCONNECTED => WiFi will reconnect
-- optionally, startup MDNS again
Windows (Chrome, ping, ...) could find the new hostname quite fast.
My Asus router is very slow in showing the new name in the connected devices list, but does show it quickly in the DHCP leases
Also, my iPhone had some brief struggles finding the new hostname.
Users browsing this forum: Applebot and 2 guests
