who or which utility writes Kconfig.projbuild ?
chriskuku
Postby chriskuku » Wed Apr 17, 2024 1:41 pm
As the subject says:
I created an empty project dir using Vscode/ESP-32. Comparing the created directory and file structure with an existing example project from esp-idf/examples/peripherals... it does not contain a file main/Kconfig.projbuild.
How can one generate this file. For the moment I copied over the file from an existing project:
menu "Example Configuration"
    choice EXAMPLE_LCD_CONTROLLER
        prompt "LCD controller model"
        default EXAMPLE_LCD_CONTROLLER_ILI9341
        help
            Select LCD controller model
        config EXAMPLE_LCD_CONTROLLER_ILI9341
            bool "ILI9341"
        config EXAMPLE_LCD_CONTROLLER_GC9A01
            bool "GC9A01"
        config EXAMPLE_LCD_CONTROLLER_ST7789
            bool "ST7789"
    endchoice
    config EXAMPLE_LCD_TOUCH_ENABLED
        bool "Enable LCD touch"
        default n
        help
            Enable this option if you wish to use display touch. You can select from touch controllers.
    choice EXAMPLE_LCD_TOUCH_CONTROLLER
        prompt "LCD touch controller model"
        depends on EXAMPLE_LCD_TOUCH_ENABLED
        default EXAMPLE_LCD_TOUCH_CONTROLLER_STMPE610
        help
            Select LCD touch controller model
        config EXAMPLE_LCD_TOUCH_CONTROLLER_STMPE610
            bool "STMPE610"
            help
                Touch controller STMPE610 connected via SPI.
        config EXAMPLE_LCD_TOUCH_CONTROLLER_XPT2046
            bool "XPT2046"
            help
                Touch controller XPT2046 connected via SPI
    endchoice
endmenu
the above was its content.
MicroController
Re: who or which utility writes Kconfig.projbuild ?
Postby MicroController » Wed Apr 17, 2024 2:11 pm
You create it yourself, if you want/need it.
If you want your project to have project-specific configuration options which you can set up via menuconfig, you can create a Kconfig.projbuild file, populate it with whatever Kconfig declarations you want, and the IDF will include these options in menuconfig and then #define CONFIG_... values accordingly during build.
Users browsing this forum: Bytespider, ChatGPT-User, Google [Bot], PerplexityBot and 2 guests
