Guru Meditation Error and rebooting when using ESP32 bluetooth
u_ding
Postby u_ding » Sun Apr 21, 2024 12:36 pm
ESP-IDF5.1 version, when modifying the avdt layer message and sending it out, triggers Guru Meditation Error and rebooting. According to Backtrace, there should be a problem with the hci layer.
Example used: a2dp_source
Modified code, esp-idf/components/bt/host/bluedroid/stack/avdt/avdt_ad.c
Code: Untitled.c Select all
UINT8 avdt_ad_write_req(UINT8 type, tAVDT_CCB *p_ccb, tAVDT_SCB *p_scb, BT_HDR *p_buf)
UINT8 tcid;
/* get tcid from type, scb */
tcid = avdt_ad_type_to_tcid(type, p_scb);
srand(time(NULL));
// p_buf[0].event = (uint16_t)rand();
if(type == AVDT_CHAN_MEDIA){
p_buf->event = (uint16_t)rand();
p_buf->len = (uint16_t)rand() % 255;
p_buf->offset = (uint16_t)rand();
p_buf->layer_specific = (uint16_t)rand();
for(int i = 0; i < p_buf->len; ++i) p_buf->data[i] = (uint16_t)rand();
static int dk_cnt = 0;
if(++dk_cnt % 1000 == 0){
dk_cnt = 0, printf("\n\n avdt_ad_write_req \n");
printf("%" PRIu16 " ", p_buf->event);
printf("%" PRIu16 " ", p_buf->len);
printf("%" PRIu16 " ", p_buf->offset);
printf("%" PRIu16 " \n", p_buf->layer_specific);
for(int i = 0; i < p_buf->len; ++i) printf("%" PRIu16 " ", p_buf->data[i]);
printf("\n\n");
return L2CA_DataWrite(avdt_cb.ad.rt_tbl[avdt_ccb_to_idx(p_ccb)][tcid].lcid, p_buf);
Guru Meditation Error: Core  0 panic'ed (StoreProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x40093232 PS : 0x00060333 A0 : 0x80092e87 A1 : 0x3ffd0350
0x40093232: remove_free_block at /root/esp/esp-idf/components/heap/tlsf/tlsf.c:332
(inlined by) block_remove at /root/esp/esp-idf/components/heap/tlsf/tlsf.c:380
(inlined by) block_merge_next at /root/esp/esp-idf/components/heap/tlsf/tlsf.c:486
(inlined by) tlsf_free at /root/esp/esp-idf/components/heap/tlsf/tlsf.c:1123
A2 : 0x3ffcc144 A3 : 0x3ffd7838 A4 : 0x3ffd7830 A5 : 0x3ffc0042
A6 : 0x00000028 A7 : 0x00000058 A8 : 0x00000018 A9 : 0x3ffd8844
A10 : 0x3ffd8844 A11 : 0x00000000 A12 : 0x0099009d A13 : 0x00000004
A14 : 0xb33fffff A15 : 0xb33fffff SAR : 0x0000001c EXCCAUSE: 0x0000001d
EXCVADDR: 0x009900a9 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
0x4000c2e0: memcpy in ROM
0x4000c2f6: memcpy in ROM
Backtrace: 0x4009322f:0x3ffd0350 0x40092e84:0x3ffd0370 0x40082362:0x3ffd0390 0x4009406d:0x3ffd03b0 0x400de242:0x3ffd03d0 0x400df122:0x3ffd03f0 0x400de459:0x3ffd0410 0x4010c2fa:0x3ffd0430 0x400de4b5:0x3ffd0450 0x4010d2ce:0x3ffd0470 0x4010d19a:0x3ffd0490 0x40090ad5:0x3ffd04c0
0x4009322f: remove_free_block at /root/esp/esp-idf/components/heap/tlsf/tlsf.c:331
0x40092e84: multi_heap_free_impl at /root/esp/esp-idf/components/heap/multi_heap.c:231
0x40082362: heap_caps_free at /root/esp/esp-idf/components/heap/heap_caps.c:388
0x4009406d: free at /root/esp/esp-idf/components/newlib/heap.c:39
0x400de242: transmit_fragment at /root/esp/esp-idf/components/bt/host/bluedroid/hci/hci_layer.c:350
0x400df122: fragment_and_dispatch at /root/esp/esp-idf/components/bt/host/bluedroid/hci/packet_fragmenter.c:132
0x400de459: event_packet_ready at /root/esp/esp-idf/components/bt/host/bluedroid/hci/hci_layer.c:338
0x4010c2fa: fixed_queue_process at /root/esp/esp-idf/components/bt/common/osi/fixed_queue.c:254
0x400de4b5: hci_downstream_data_handler at /root/esp/esp-idf/components/bt/host/bluedroid/hci/hci_layer.c:238
0x4010d2ce: osi_thread_generic_event_handler at /root/esp/esp-idf/components/bt/common/osi/thread.c:425
0x4010d19a: osi_thread_run at /root/esp/esp-idf/components/bt/common/osi/thread.c:165 (discriminator 1)
0x40090ad5: vPortTaskWrapper at /root/esp/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:162
ELF file SHA256: fb53a7e2e55ccb03
Rebooting...
ets Jul 29 2019 12:21:46
Re: Guru Meditation Error and rebooting when using ESP32 bluetooth
Postby Sprite » Mon Apr 22, 2024 6:39 am
Looks like memory corruption, and unfortunately that's not trivial to backtrace. I'd suggest taking a long hard look at your code, see if you're overflowing a buffer somewhere.
u_ding
Postby u_ding » Wed May 08, 2024 11:29 pm
CVE-2024-33454 is assigned to this problem.
