Using ULP without deep_sleep
davdav
Postby davdav » Fri Dec 15, 2017 9:23 am
Hi everybody,
is it possible to use ULP without forcing the module to go in deep_sleep?
In the examples provided in the SDK the program calls
esp_deep_sleep_start();
I would like to use the ULP, reading inputs and ADC, in both case when module is full power and deep sleep. Is this possible?
krzychb
Contact:
Re: Using ULP without deep_sleep
Postby krzychb » Fri Dec 15, 2017 9:58 am
Hi davdav,
Yes, see https://github.com/espressif/esp-idf/tr ... system/ulp
davdav
Postby davdav » Fri Dec 15, 2017 10:43 am
Thank you krzychb. I will take a look at the example
urbanze
Postby urbanze » Fri Dec 15, 2017 11:08 am
Fortunately it does and makes it a very useful tool if you can use it well. If your project is too heavy, using the "third core" to read sensors or perform some operations can rid the Main Core of this and not interrupt your application.
Just be careful with wake up timer and halt, maybe you want it to run "infinitely" like in a loop and without the care about the above items, it can act in a "weird" way.
davdav
Postby davdav » Fri Dec 15, 2017 11:43 am
Ok @urbanze, thanks for highlighting.
You got exactly what I would like to do..let the ULP to read ADC and talking to an I2C port expander to read some inputs and set some outputs without need of main processor.
In theory I do not want to go in deep sleep and wake up continuosly, maybe only when external power supply is lost (I have battery backup). Do you know some docs or resource (examples, forum threads) I can check to avoid the "weird" behaviour?
