I need to add a patch (https://github.com/espressif/esptool/co ... a611072103) in order to fix the ESP32-S3 exit bootloader issue. I also need to use the exe version of esptool. How can i create it? I tried using pyinstaller with no luck...
Thanks,
Antonio
Esptool.py - How do i make my own Esptool.exe
antonio.mazzanti
Re: Esptool.py - How do i make my own Esptool.exe
Here you can find how we do it: https://github.com/espressif/esptool/bl ... sptool.yml
antonio.mazzanti
Thanks, i also found out how to build directly from git workflow. I then directly downloaded the version that had the dev patch i need.
https://github.com/espressif/esptool/ac ... 8391093485
Cheers.
Cheers.
Users browsing this forum: ChatGPT-User, Semrush [Bot] and 4 guests
