ESP32 S2 serial2 not working
PepeTheGreat
Postby PepeTheGreat » Mon May 06, 2024 5:35 am
The S2 has usb plus 2 hardware uart.
Serial usb
Serial1 = hardware first
Serial2 = hardware second
Arduino IDE:
Code: Untitled.c Select all
void setup()
Serial1.begin(9600,SERIAL_8N1,13,12);
Serial2.begin(4800,SERIAL_8N1,10,11);
void loop()
Serial1.println("hello 1");
Serial2.println("hello 2");
delay(100);
gives compile error "'Serial2' was not declared in this scope"
PepeTheGreat
Re: ESP32 S2 serial2 not working
Postby PepeTheGreat » Mon May 06, 2024 5:42 am
This compiles, has outpunt on pin 12 but no output pin 11
#include <hardwareserial.h>
HardwareSerial Seriala(1);
HardwareSerial Serialb(2);
void setup()
  Seriala.begin(9600,SERIAL_8N1,13,12);
  Serialb.begin(4800,SERIAL_8N1,10,11);
void loop()
  Seriala.println("hello 1");
  Serialb.println("hello 2");
  delay(100);
Output tested on 2-chan oscilloscope.
lbernstone
Postby lbernstone » Mon May 06, 2024 6:34 am
They start counting at zero. Serial == Serial0 (aka the default console). Serial1 == HardwareSerial(1)
PepeTheGreat
Postby PepeTheGreat » Mon May 06, 2024 7:02 am
Serial == Serial0 (aka the default console). <-- not hardwareserial, but USB
Serial2 == HardwareSerial(2) <-- this one not working in arduino ide
I interpret "2 uart" as "2 hardwareserial".
See "uart" here:
https://docs.espressif.com/projects/esp ... rison.html
or doc here – 2 × UART
https://www.espressif.com/sites/default ... eet_en.pdf
Does the S2 have only one hardwareserial?
lbernstone
Postby lbernstone » Mon May 06, 2024 4:47 pm
There are two UART devices- 0 & 1. UART0 (Serial0) is still attached to console at boot, even if you are using HWCDC. This means that you would need to burn the UART_PRINT_CONTROL eFuse if the boot messages will interrupt your device on that port.
PepeTheGreat
Postby PepeTheGreat » Mon May 06, 2024 9:42 pm
Me thinks console, serial0, is not uart but usb.
I did read with esp-idf both serial do work. Seems an arduino-ide problem.
lbernstone
Postby lbernstone » Tue May 07, 2024 12:07 am
You are, quite simply, incorrect.
If you have an S3 devkit with both UART and USB, you can test this easily. Set CDC On Boot to enabled, and run the following (requires v3.0.0). You will get different prints on the different ports.
  Serial0.begin(115200);
  Serial.begin(9600);
  Serial1.begin(115200);
  if (HWCDCSerial) Serial.println("Testing USB");
  Serial0.println("Testing UART0");
  Serial1.println("Testing UART1");
  delay(1000);
PepeTheGreat
Postby PepeTheGreat » Tue May 07, 2024 9:36 am
How do you explain this works?
#include "driver/uart.h"
// ESP32S2 usb cdc on boot on, usb dfu on boot off, upload mode internal usb.
const int VEBUS_RXD1=13, VEBUS_TXD1=12;
const int VEBUS_RXD2=10, VEBUS_TXD2=11;
const int UART_USED1 = 0; //UART_NUM_1; // serial1
const int UART_USED2 = 1; // serial2
const int LED = 15;
esp_err_t err11,err12,err13,err21,err22,err23;
void setup()
  pinMode(LED, OUTPUT);
  digitalWrite(LED, LOW);
  delay(5000);
  Serial.println("Start");
  uart_config_t uart_config1 =
        .baud_rate = 9600,
        .parity = UART_PARITY_EVEN,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
        .rx_flow_ctrl_thresh = 32,
  err11 = uart_driver_install(UART_USED1, 256, 256, 0, NULL, 0);
  err12 = uart_param_config(UART_USED1, &uart_config1);
  err13 = uart_set_pin(UART_USED1, VEBUS_TXD1, VEBUS_RXD1, -1, -1);
  Serial.println(err11);
  Serial.println(err12);
  Serial.println(err13);
  uart_config_t uart_config2 =
        .baud_rate = 9600,
  err21 = uart_driver_install(UART_USED2, 256, 256, 0, NULL, 0);
  err22 = uart_param_config(UART_USED2, &uart_config2);
  err23 = uart_set_pin(UART_USED2, VEBUS_TXD2, VEBUS_RXD2, -1, -1);
  Serial.println(err21);
  Serial.println(err22);
  Serial.println(err23);
  Serial.println("Done");
char buf1[3] = { 0xaF, 0x00, 0x55 };
char buf2[3] = { 0xa0, 0xFF, 0x55 };
void loop()
  uart_write_bytes(UART_USED1, buf1, 3);
  buf1[2]++;
  uart_write_bytes(UART_USED2, buf2, 3);
  buf2[2]++;
  delay(100);
  digitalWrite(LED, !digitalRead(LED));
usb output
Start
0
0
0
0
0
0
Done
This shows two hardware UART and the usb console working by circumnavigating the arduino functions.
"You are, quite simply, incorrect."
pic measured pin 11 and 12
PepeTheGreat
Postby PepeTheGreat » Thu May 09, 2024 3:23 pm
I wonder if this will be corrected or if arduino usesrs will be limited to one serial on the ESP32S2 for eternity?
Users browsing this forum: ChatGPT-User, Qwantbot and 8 guests
