ESP8266 NodeMCU v3 and DS18B20: Sensors not detected
TomaszFilipek
Postby TomaszFilipek » Wed May 08, 2024 11:36 am
I have a WiFi module ESP8266 + NodeMCU v3 to which I have connected two DS18B20 sensors to pin D7.
For some reason, the sensors are not being detected.
Please advise why.
Code: main.cpp Select all
#include <Arduino.h>
#include "TemperatureSensorController.cpp"
TemperatureSensorController temperatureSensorController;
void setup()
temperatureSensorController = TemperatureSensorController(D7);
void loop()
temperatureSensorController.printTemperatures();
delay(1000);
Code: TemperatureSensorController.cpp Select all
#include <DallasTemperature.h>
#ifndef MYCLASS_H
#define MYCLASS_H
class TemperatureSensorController
public:
TemperatureSensorController()
TemperatureSensorController(uint8_t oneWireBus) : TemperatureSensorController()
_oneWire = OneWire(oneWireBus);
_sensors = DallasTemperature(&_oneWire);
void printTemperatures()
Serial.println("Print Temperatures");
Serial.println("");
delay(100);
_sensors.begin();
delay(100);
_sensors.requestTemperatures();
Serial.print("Device count: ");
Serial.println(_sensors.getDeviceCount());
Serial.println("");
for (int i = 0; i < _sensors.getDeviceCount(); i++)
Serial.print("Device no. ");
Serial.print(i + 1);
Serial.print(" Temperature: ");
Serial.print(_sensors.getTempCByIndex(i));
Serial.println(" °C");
delay(100);
Serial.println("");
Serial.println("-----------------------");
Serial.println("");
public:
OneWire _oneWire;
DallasTemperature _sensors;
#endif
Output of the program:
The physical connections are fine - running the code where everything is in the main.cpp file, the readings are done correctly.
OneWire oneWire = OneWire(D7);
DallasTemperature sensors = DallasTemperature(&oneWire);
void setup()
sensors.begin();
void loop()
Serial.println("");
delay(100);
sensors.begin();
delay(100);
Serial.println(sensors.getDeviceCount());
Serial.println("");
for (int i = 0; i < sensors.getDeviceCount(); i++)
Serial.print(sensors.getTempCByIndex(i));
delay(100);
Serial.println("");
Serial.println("");
delay(5000);
Output:
Thank you in advance for your help.
